Question about Samsung SCH-u540 Cellular Phone
Water damage Left phone in pocket and ran through washing machine.  Now the phone won't turn on.  I initially removed the battery and tried vacuuming out the moisture, and then allowing to dry in the sun for a couple days, to no avail.  At this point, I'm shopping for a new phone unless it can be fixed somehow.
  • 260 Answers
Water damaged phones do not get repaired. The electronics are way to sensitive. I recommend you go ahead and shop for the new phone.
Posted on Jul 30, 2008
Why is door leaking on washing machine
water leaks on washing machine, I suppose your washing machine is front load type therefore check the rubber gasket, it might have been damaged due to sharp object sometimes left inside clothes pockets.
May 03, 2014 | Washing Machines
How to Save a Wet Cell Phone
Ever dropped your cell phone in the sink, or even worse... the toilet? Did you ever leave it in your pocket and run it through the washer? Did you ever swim with your cell phone in your pocket? It usually means you have to replace your phone, but sometimes if you're fast, you can save the phone! It's not being wet that kills a cell phone, it's being on and wet at the same time. This can short the circuitry out. If you're able to turn your phone off before it fries, you may well be able to resuscitate your drowned phone!
Get it out of the water as soon as possible. The plastic covers on cell phones are fairly tight, but water can enter the phone in a short period of time, perhaps only 20 seconds or less. Grab your phone quickly! If you can't get to it in time, your best bet is to remove the battery while it is still under water. Water helps dissipate heat from shorts that can damage the phone, so most damage occurs when the inside of the phone is wet and connected to a power source. This can go both ways. Being under water is more likely to short the battery to even more sensitive contacts, so be careful.
  1. Don't panic. Your phone will probably not be too damaged if you take it out of the water right away.
  2. 3Remove the battery. This is one of the most important steps. Don't take time to think about it; electricity and water do not mix. Cutting power to your phone is a crucial first step in saving it. Many circuits inside the phone will survive immersion in water provided they are not attached to a power source when wet.
  3. 4Try putting your cell phone, with battery removed, in an oven on warm and hold. The dry heat will dry that ish out in no time.
  4. 5Remove the SIM card if you have a GSM carrier, . Some or all of your valuable contacts (along with other data) could be stored on your SIM. To some people, this could be more worth saving than the phone itself. SIM cards survive water damage well, but some of the following steps are unnecessary i.e. don't heat it. Just pat it dry and leave it aside until you need to connect your phone to your cellular network. (This step does not apply to CDMA carriers such as Verizon, Alltel, US Cellular, Sprint, etc.)
  5. 6Dry your phone. You can put it in a bag of rice. Obviously you need to remove as much of the water as soon as possible, so you can save it from getting into the phone. Shake it out without dropping it, then use a towel or paper towel (ideally trying not to clog the wet paper in the gaps and grooves of the phone) to gently remove as much of the remaining water as possible. Dry the excess moisture by hand.
  6. 7Remove any covers and external connectors to open up as many gaps, slots, and crevices in the phone as possible.
  7. 8Use a vacuum cleaner if possible. Do not use a hair dryer (even on a "cold" mode) to dry out the phone, as this may force moisture further into the small components and likely melt them, deep inside the phone. If moisture is driven deeper inside, corrosion and oxidation may result when minerals from liquids are deposited on the circuitry. Using a hairdryer might be a temporary fix, but this will eventually cause component failure inside the phone. Instead, remove all residual moisture by drawing it away with a vacuum cleaner held over the affected areas for up to 20 minutes in each accessible area. This is the fastest method and can completely dry out your phone and get it working in thirty minutes (however, unless the exposure to water was extremely short, it's not recommended to attempt to turn your phone on this soon). Be careful not to hold the vacuum too close to the phone, as a vacuum can create static electricity, which is even worse.
  8. 9Use a substance with a high affinity for water to help draw out moisture. Leave the phone in a bowl or bag of uncooked rice overnight. The rice would absorb any remaining moisture. If available, it is preferable to use desiccant instead. Desiccant will absorb moisture better than rice. Turn the phone to a different position every hour until you go to sleep. This will allow any water left inside to run down and hopefully find an opening to escape.
  9. 10Let the phone sit on absorbent towels, napkin, or other paper. Remember that the goal is to evacuate all the moisture and humidity, not to trap it or add even more. Check the absorbent material every hour for 4 to 6 hours. If moisture is evident, repeat the vacuuming step and desiccant steps.
  10. 11Test your phone. After you have waited a day or so, make sure everything is clean and looks dry, and re-attach the battery to the phone. Try turning it on. If your phone still does not work, try plugging it into its charger without the battery. If this works, you need a new battery. If not, try taking your cell phone to an authorized dealer. Sometimes they can fix it. Don't try to hide the fact that it has been wet. There are internal indicators that prove moisture.
  11. 12Take the phone apart if your phone doesn't turn on at all. If you feel comfortable doing this, try taking it apart. First, make sure that you have ALL the right parts and know exactly where they go. Be sure to put everything back in its proper place once finished. As you're disassembling it, pat each individual part dry with a small towel and use the vacuum cleaner once more on the crevices. If this doesn't work, go to the professionals.
on Jul 15, 2010 | Cell Phones
Recover data with pc nokia e7 water damaged and won't turn on
Well, friend! I am afriad that you can not recover data from the phone when it turns off. if your phone suffer from a water damage, you can try to put the phone into popcorn with a plastic pocket, and wait for the phone dry totally, then you can try to turn on the phone.
Apr 01, 2013 | Nokia E7 (16 GB) Smartphone
I have a fisher and Paykle GW612 washing machine, it won;t drain the water and won;t do the spin cycle. It now is making a huming noise. I think it is the motor that has an issue?
There should be a tech sheet located underneath the control panel that has the procedure for putting the machine in "diagnostic mode" and you can easily run the water pump by itself. Listen for a "hum" sound- If you hear a hum instead of a running water pump, then something is keeping that pump from turning for sure.
If this is the case, then you would need to check your water pump. It is located underneath the machine in the right front corner (as viewed from the front of the machine)
There is a black plastic external cooling fan impeller that you can spin with your finger (of course unplug the machine first) and see if the pump spins freely. You should also examine the pump for signs of leakage or corrosion. You may simply have an object that was left in someone's pocket that has become lodged in the pump. Pump removal requires no tools, however you need to first bail out as much of the remaining water in the wash tub as possible.
Jan 15, 2011 | Washing Machines
Phone in washing machine
Water damage causes corriosion on the phone's mother board, there is no assurance that the phone can still be repaired. You can try to go to a technician to have it checked.
Jul 04, 2009 | Samsung SGH-J600 Cellular Phone
Water damage
check the battery connections and see if theyre corroded and clean them ... if that don't work then your screwed
May 29, 2009 | Sony Ericsson W910i Cellular Phone
Katana II likely water damage... Help!
Take the battery off, unfold the phone, set it in a warm, dry place and pray like heck. plugging it in may help it stay warm but leave it off.
If its minor water exposure it'll likely be fine in 2-3 days.
Mar 02, 2008 | Sanyo Katana SCP-6600 Cellular Phone
You're gonna love this - 2 phones in a
My Grand daughter washed her phone. I took it apart.battery covers That stuff, then i used a hair dryer on it. that fixed it. that wasn't the last time she washed it. hehehe
Dec 28, 2007 | Motorola Mobility RAZR V3
Mp3 player went through washing machine
My daughter's Zune went through the washing machine and dryer in May 2008. I checked the internet & it looked pretty bleak. I couId see water inside the screen area & it would not turn on at all. I decided to just leave it sitting on the counter for awhile instead of just throwing it away. Three weeks later I tried to turn it on & got a low battery display. We plugged it in, charged it and it has been working ever since (it is now August 2008).
Aug 05, 2007 | RCA TH1101 MP3 Player
oooh doesnt sound too good! but my phone got a bit wet and stuffed up quite a bit so last night im my room on the shelf, i took out my sim card, battery, back cover and left it open to get some fresh air. and now it works fine:) goodluck you might want to try that but yours was alot wetter than mine!
Nov 23, 2006 | Motorola Mobility V265
Samsung SCH-u540 Cellular Phone Logo
94 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
