Question about Whirlpool Duet GHW9150P Front Load Washer
Front load washer will not start
My duet front load washer will not start. It will display the 40 minutes for the normal wash but when I push the start button it will not start to wash. There is no error display it will just continue to show the minutes and will not click on to start.
    Problem Solver:
REPLACING BELLOWS
Posted on Jul 30, 2008
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When push the start button it will run for a minute and then beep the display window will read f 11
The MCU motor control unit is at fault.
Unplug the washer for 60 seconds.
Plug it back in and try again.
If the fault reoccurs,replace the MCU.
Apr 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport washer power button problem. I have to push power button a 10-15 times and the power will be on. Please help.
pushing the button that many time is not the problem on this type of unit you push the start and hold of about 5 sec's then you'll hear the unit start door lock and oper through a normal cyc a word of advice don't close the door very hard push into place these things are plastic and will break the latch assy then will cost $$$ for parts good luck
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
On the normal cycle of my Duet front load washer at 37 minutes the machine stops and flashes F5. I push the reset button then the start button and the machine works fine after that.
HI. This is a Water temperature sensor error.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.(Most common issue will be a failed water temp sensor)
Jul 25, 2009 | GE WBVH6240F Front Load Washer
Duet will not start
HI, The Central Control Unit has failed. you will need to replace this failed control board asap.
We recommended a service call for this type of repair.
Jun 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer not working
Okay...try unplugging the washer for AT LEAST 30 minutes. This will often cure momentary glitches with the washer computer. After the washer has been reset, attempt the start a load and let me know if it functions normally. If it doesn't, let me know what the front panel display reads.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
404 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
