Question about Jazz DV-179 Digital Camera
Can't get built ibn speaker to work?
I attsached the av jacks to the camera and hooked it to the TV after I unattached them i now get the tv -headphnone selector on the scren and it disables my camera speaker. Can anyone tell me hoe to get this stupid icon off the screen and get my speakers working? I would appreciate it very much
  • tyiruz Sep 03, 2008
    same
  • 90 Answers
I have forwarded your request to our QA department,
Posted on Aug 29, 2008
Ok so 1 of my kidos has the RCA 20F420T tv, and i guess there is no headphone jack hole, so i went and bought adapter that plugs into the av jacks, still doesnt work can you please help!!!
Without knowing the specifics on this adapter - I can provide only provide some clues as to how this works.
Basically, the A/V jacks on a TV has a "fixed" audio output level - this means that the sound levels on the A/V jacks is NOT controlled by the volume control of the TV itself. You should be able to set the TV volume to minimum and then use the adapter's volume control to make the earphone / headphone sound louder and softer. Your TV however, may have a setting in the menu that can change the audio from "fixed" to "variable". If set to "variable", when turning the volume down for the TV's built in speakers will also turn the volume down on the A/V jacks as well. You do not want this to work like that as the sound in the headphones and the TV speakers will be same - instead of the TV speakers being off and the headphones on.
I hope this helps and good luck! Please rate my reply. Thanks!
May 26, 2011 | RCA 20F420T 20" TV
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
How can I hook this cam up to my Television?
For this camera you will need to find in your equipment (or purchase) a "stereo video cable "
This cord features a 1/8th (male) headset jack on one end and 3 male RCA jacks on the other. (yellow/red/white).
Plug the 1/8th jack into the camera's AV input and the RCA plugs into your TVs RCA port input and select the correct AV input (AV 1, 2, etc)on your tv selector and the camera should play through your tv.
Nov 04, 2009 | Canon ES75 Camcorder
I need a small speaker to hook to the red and white jacks that normally connect to a TV
Cheapest ones are at Ross, the discount clothing, etc. store. They're made just for MP3 players and have a built in amplifier. About $20.
May 28, 2009 | Audio Players & Recorders
No sound from tv through unit
You may have to enter TV menu and see if you have a AUDIO setup option, some TV`s you have to enable TV AUDIO OUTPUT, this cancels the built in tv speakers and engages the AUDIO OUTPUT jacks on the TV
Feb 03, 2009 | Panasonic Home Theater System System
Problems hooking it to the television
The colored jacks match up to the jacks on tv. Tv must be turned to AV channel, Or input channel. The ports they are plugged into should have a channel printed by them.
If you are hooking it up through a VCR it is the same. Whatever it is hooked up to has to be on the right channel.
Channels are usually: AV or Input
Jan 18, 2009 | GoVideo DV2140 DVD Player/VCR
Sound Problems with JVC AV-35BP4 TV
The audio output stage for the speakers may have failed in the TV set. If the set has an earphone jack, it is also possible that the jack has a fault (very rare, but I have seen this).
Are there external speaker outputs to try other speakers?
Jerry G.
Apr 29, 2008 | Televison & Video
The instructions are very poor
You probably hooked it up wrong. Make sure you hooked up the right speakers to the corresponding jacks, and make sure that your video input jack isn't bad on your tv, or that u have all the av cords going from the output jacks in the dvd palyer, and they lead up to the input jacks on your tv. If the problem still exists, then call customer service, or try a different tv.
Nov 04, 2007 | Durabrand STS92 System
Jazz DV-179 Digital Camera Logo
26 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
