Question about Kitchen Ranges
After a $360 bill to replace two igniters in my 12 year-old Kenmore self-cleaning single wall oven —the broiler unit still does not work —I'm told that the safety valve will need to be replaced now (an additional $400). I'm wondering whether I should do it myself. It's located in a constricted place and it looks as if the regulator would need to be removed as well. Checking for gas leaks because of the clumsy location is also a concern.
    Sergeant:
  • 260 Answers
Wow. that is way too much money to have to spend on your oven. I like Kenmores but not that much. Have you considered purchasing a new oven?
If you are not completely comfortable with checking for gas leaks and changing the regulator then I have to recommend you talk to a repair serivice. That is too dangerous to work on yourself unless you have experience.
Good luck,
CH
Posted on Jul 30, 2008
  • Kitchen Ranges Master
  • 13,433 Answers
See if you can locate the part for sale here
http://www.repairclinic.com/
  • Ekse Jul 30, 2008
    Unless your oven costs more than 2 000 brand new I recommend you go and buy a new one. or replace the part yourself is you wish.
KENMORE GAS STOVE OVEN , how to check if power is coming to the ignitor
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Sep 07, 2014 | Kenmore 24 in. Gas Self-Clean Single Wall...
I have an old Whirlpool Self-Cleaning oven. I've followed the use guide instructions but still can't get the cleaning light to come on. I have both knobs to clean but the oven light comes on and the...
Probably, in some models both the bake and broil come on to help it heat faster and hotter. In some units the self cleaning light will not come on until a certain temperature is attained. Are you setting the start time for right now, and the stop time for 2 to 3 hours from now?
Jan 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Oct 02, 2009 | Kitchen Ranges
Wall oven not working at all
mine is broken too. exact same problem. same oven. email me if you fixed yours, please!!! quinnalisen@comcast.net
Sep 25, 2009 | Kenmore Ovens
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
My Kenmore oven wont ignite. The broiler works
The problem is your bake ignitor. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake and broil oven features each have their own separate igniters and operate independently of one another. That explains why the broiler still works. They are, however, fed from the same gas source. So...the logical conclusion would be to replace your bake igniter (the no glowing is usually a dead give-away).
Replacements can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Prices can vary amongst sites, so shop around for the best price. The sites I provided to you, I found, tend to offer the best service and prices.
If you have questions along the way, or require addtional service, please let me know. I hope you find this information helpful.
Feb 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven makes poofing sound when in use
hi. thanks for the question .Yes the igniter is at fault here. replace it. thanks the appliance doc
Oct 02, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Broiler Works/Oven Doesn't
Jrzy, even though you can see the bake igniter glowing, that doesn't mean it's good. Igniters actually get weak (unlike a light bulb that simply burns out). It's hooked up in series to a safety valve (the valve that allows main gas into the oven) which actually reads the amps flowing through the igniter. If the igniter is weak and the amps are too low, the valve won't open up. Replace your igniter and you'll be cookin' with gas again. Tip---> before you unscrew your old igniter, put a little liquid dish soap on the threads for lubrication. This'll ensure it comes out with no problems.
Sep 14, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
