Configuration progress So far you guys are 2 for 2 with my problems, great job by the way. I do appreciate what you have done for me.... OK, I had to do a reinstall recently with windows xp pro 2000. Everything went smooth, no problems until I put in Microsoft office 2007 home and student version. That seemed to install just fine, until I go to open up any programs, such as word. Everytime I try to open one I get a Configuration Progress box that pops up, then it takes around 2 1/2- 3 minutes for it to load then open. Is there a settings I missed or clicked wrong. I have a Dell 8400 desktop. I did have this program in my system before I crashed it and it worked just fine, I think I might have skipped something in the install. But I did uninstall and reinstall a second time and I have the same problem. Thanks for all of your great help.....
  • 1 more comment
  • Anonymous Oct 11, 2008
    So annoying!
  • Anonymous Oct 27, 2008
    configuration progress pop up every time when open office2007
  • tbruceishome Nov 08, 2008
    I recently had to reformat and re-installed Office 2007. I go to open up word document and I get a Configuration Progress box that pops up, then it takes up to 2 minutes for it to load then open.
If the "Configuration Progress box" is coming up every time you run and Office 2007 product, Click on "Start" -> "Control panel "->"Add or Remove Programs ". Check to see if you Still have a previous version of the Microsoft product installed. For example, "Microsoft Word " from "Microsoft Office 2007" takes 2 to 3 minutes to load because the "Configuration Progress box" comes up, checking the "Add or Remove Programs", showed "Microsoft Office 2003 " was still installed. After remove "Microsoft Office 2003", "Microsoft Word 2007" opened quickly without the configuration bar.
Posted on Nov 19, 2009
I re-installed Microsoft Office 2007 and that seemed to have worked so far, fingers crossed
Posted on Nov 12, 2008
Terribly annoying and my time is wasted
Posted on Nov 10, 2008
Wont shift after remote start.
This is one deal that's kinda sad because you tried and it works to a point but now it's not good b honest probably should of left this one to guy that does this kind of work everyday I'm not perfect and do not claim to b but I also know when it comes to things I don't know or done I will not perform the job until I'm fully educated on the specifics of the job well I guess u better take it to the car audio guy and get the wiring straightened out or you will have more problems than u can shake a stick at !!!! Ok the best thing u can take from this is you are not afraid to fail which I commend u so when u take your truck in b a sponge ask questions and you will figure out why this happened I hope you are not upset because I did not spend this much time typing for u to b upset u seem to have a great attitude and I'm sure you will b fine so b cool you will go far I know it Chris
Mar 03, 2014 | Cars & Trucks
Test pgs print ok, jobs= no black only blue faintly appears.
Hi, check if the black toner is properly inserted and check the printing configuration
Dec 09, 2013 | HP PhotoSmart Office Equipment & Supplies
I am running Windows 7 professional ver 6.1.7600 build 7600. I am trying to install Nortel i2050 softphone software and it requires to be configured by the configuration tool. The problem is the...
I would prefer for you to call or chat so I can walk you through this because while the 2050 is not recommended for Windows 7 we can adjust it to work. You can reach me at: http://www.liveperson.com/nortel-guy
Thanks
Aug 04, 2011 | Nortel i2050
We understand that your problem is: I currently own and use on a regular basis the Kenmore Progressive upright bagged vacuum. Model number 116.35923500. The headlight flickers and the intelliclean light...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Kenmore Progressive 35922 Bagged Upright...
Screen Replacement
ok guys...i have had the same prob and it is now solved...finally...and what an *** about way to build a computer!
The bezel that covers the on and off switch is a snap in piece (it also screws in from underneath)tand you wedge a guitar pick under it and lift and it will pop out. Then you should be able to see the screws that hold the hinges to the main frame, there are two of the screws for each hinge...BRAD justanswer.com)
The screen bezel has 5 screws on the base..3 are acessible from here, 2 are not...These 2 are in the corner and blocked by the hinge...the hinge therefore must be taken apart via 4 screws (2 then you will see 2 more) on the circuitry board...and if you can get this far...the rest is straight forward
Jun 15, 2009 | Acer Aspire 6920 Notebook PC
How to replace my clutch.
ok,hi Carmen, im Robert from Venezuela.^
raise the front car, loose the nuts of drive shafts on fron vheels,disconnect the line of cluth fluid,disconnect the negative battery terminal and wires from shifter transm., put a jack under the transm. and remove the supports, loose the bolts ,its easy
Apr 16, 2009 | 1997 Mazda MX-5 Miata
My daughter has the Bolt Game for PS2. She is in
I think this is the same problem my son had. Do the enemies just keep coming?
Here's the solution.
After building up enough combos you get a lightning bolt in a yellow circle on the screen. Press down the top of both the analog sticks and before the countdown runs out do a superbark (L2) while facing the far wall. the wall collapses and you can progress!
Mar 02, 2009 | Dmm Disney's Bolt PS2 for PlayStation 2
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Computers & Internet Logo
3,943 people viewed this question
David Payne
David Payne
