Question about Frigidaire Kitchen Ranges
Frigidaire Gas Range GLGFS75DBA
Replace LP orifice to NG
  • 254 Answers
If you didn't keep the original orfices for natural then you need too buy the burner orfices seperatly, and the oven regulator just needs adjusted you can go the frigidaires web site and download the installation instructions for the proper settings.
Posted on Jul 30, 2008
Converting from LP back to natural gas. Frigidaire says it is too old to get orifice part numbers. They want me to buy the burner tubes. Ideas other than drilling?
Some ranges have a storage place for the orifices. They may be still in the range. Look near where the gas line connects to the range. NEVER drill an orifice. You will destroy the fine wires that swirl the gas into the burner. You'll get an un controllable flame.
Jun 24, 2015 | Frigidaire Kitchen Ranges
Parts gl38lkec
call me. converting a barbecue is simple; the kind of job a tech will get while still in training. The LP hole is smaller than the NG becuse of mass and air-mixture in NG so the orifices have to be plugged and re-drilled or replaced with new LP orifices.
Nov 07, 2013 | Sunbeam Grill Series 550
I need to convert from natural gas to lp. I cannot find my owners manual. Is there one online I can download?
Contact Nexgrill and ask them for the correct orifices for your model grill to go from NG to LP. Once you have the correct orifices you will also need the LP tank and a regulator and hose. It is farily straight forward to replace the orifices. You have to remove each burner, take out the NG orifice and install the LP orifice.
Jun 18, 2011 | Nexgrill 720-0234 (LP)
I bought a converson package for NG that included the regulator and a new set of burners. I'm getting very little gas. I can smell the gas but not light a flame
If the conversion kit came with new NG orifices, you need to install them as the LP orifices are to small to use with NG and all you will get is a very small flame, if any at all. If the NG conversion kit did not come with new NG orifices, then you will have to order some.
Jun 13, 2011 | Frigidaire FD30HONGDC (NG) Grill
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
How do i convert range from LP to natural gas?
You need to have the set of burner orifices which are for Natural Gas. LPG orifices are smaler than NG
Sep 27, 2010 | Kenmore 72012 / 72014 Kitchen Range
I converted my 40'' Figidaire range to LP a few years back when I did not have access to natural gas. Now I need to convert it back. I do not still have the old parts and there seems to be no ''Natural gas...
I am having almost the same problem. Frigidaire told me to replace all 5 mixing tubes, ~$385, yeah right. They don't have the orifices itemized as an individual part, so no-one carries them, just the LP conversion kit. Another repair/parts guy advised me to drill out the orifices. Some other threads/blogs give the diameter to drill. Basically, since natural gas is 0.5 psi, you need a larger hole than your current propane orifices provide. Please speak up if you find out anything, I will try to do the same. Good luck.
Sep 25, 2009 | Frigidaire PLCF489AC Dual Fuel (Electric...
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Conversion
call the dealer and get a converter.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
179 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
