FWT449GFS1 front door buzzing Frigidaire front loading washer
My Frigidaire front loader's door sometimes buzzes while washing. Ihave cleaned the area where the door locks into the washer; sometimesif I push on the door slightly to make a tighter connection the buzzingstops. I have replaced the door latch on the door side as the bottom part was broken. Any suggestions would be greatly appreciated.
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
Posted on Jan 04, 2009
Door lock buzzing
sounds as if your door lock is broken and needs to be replaced.
Feb 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a two-year old Frigidaire GLTF2940FSO front loader washer that has stopped in the middle of a load leaving water in the drum and will produce a buzzing sound no matter what cycle you put it on. We...
did you try unplugging it and plugging it back in to see if you can get it to reset? Would it buzz when you try to drain it? Does the door latch lock when it goes into the wash cycle? Usually the door latch locks when it goes into the wash cycle and stays locked. So it filled up, the door latch should lock, then should go into wash cycle. Then you said few minutes later it stops. How did you get the door open? reason i ask is Usually i would see the clothes get stuck inside the washer because the door latch is still locked when it stops. Was the door unlocked when it stoped. If so maybe something going on with the communication from the board to the door latch maybe. Did you try operatin the drain?
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front door buzzing Frigidaire front loading washer
replace entire door lock assembly ..remove spring holding the door boot in place and roll boot back ..unless you have the one where the seal is glued then carefully slide knife under edge to cut through glue take the screws from lock and pull through opening remove wires and install new lock ..if noise is only issue use till it blows then replace
Jul 30, 2008 | Frigidaire FWT449
My fromt loader buzzes while running.
Try some WD40 on the mechanism of the lock, not on door. And open & close a few times, while disconnected from the mains.
May 11, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
456 people viewed this question
Top Washing Machines Experts
