Question about Kenwood Audio Players & Recorders
Kenwood amplifer KA-892 . Previously a bare speaker wire touched the outside cabinet and I found the 6amp fuse inside blown.replacment fuses blow as soon as the unit is turned on.Is there something else I should look for.
techman
  • 3130 Answers
SOURCE: Protector
If you took all the speakers off the reciver then it still goes into protect, the reciver detects DC on the output lines. That means there is a short in the output stage of the amp. It could be an output device, or a diffencal Transistor. If you can trouble shoot solid state electronics then you should be able to find the faulty, but if not your experienced at electronic repair, am afraid it may cost more then the reciveris worth. Good Luck PS please dont forget to rate this thread
Posted on Oct 23, 2006
  • 6 Answers
SOURCE: denon avr 5800
I can help you solve this problem. However you must describe to me which fuse you have replaced. Is it the fuse on the power line or is it a fuse in the speaker line (which I highly doubt). usually this type of amplifier uses two technologies. One is transistors the second is integrated chips. This is in regard to the output stages. I assumed you speaker cables shorted each other while the volume was set at a high level with music playing. Anyway if you are willing I am able to help.
Posted on Sep 01, 2007
  • 4234 Answers
SOURCE: I have a kenwood KA
Most likely the output transistors are shorted. This causes the output stage to draw too much current and blows the fuses. Expect a parts cost around $20-$40. Add in the local labor rate for the total repair cost.
Dan
Posted on Apr 17, 2008
SOURCE: Kenwood AR 404 burning w/ open flame.
You are literally playing with fire. Obviously the unit is in dire need of service! Please, take unit in for check out by a pro/tech
Posted on Apr 27, 2008
  • 4234 Answers
SOURCE: Kenwood KR-A4070 blowing 5a 125v fuses
I am guessing that the ceramic resistor is close to the output transistors. I would also guess that one or more of the output transistors has shorted. This causes a high current draw that is blowing the fuse. You could also have a power supply problem. The ceramic resistor is a .22ohm dual emitter resistor that is used in the output stage. The transistors located close by are probably shorted and should be replaced. Start there and let us know what happens once the transistors and the resistor are changed.
Dan
Posted on Oct 10, 2008
Blown 3A fuse
Check for a short in the thermostat wiring. Look for bare wires both inside and outside the cabinet
Jul 25, 2014 | Ruud Rheem 1012-920a Fan Control Board...
Amana AMH95 Blown control fuse
Control fuses only blow with a 24 volt problem. Make sure that you replace it with a fuse NO LARGER than 5 amps.You could have a thermostat wire pinched or some wire touching the cabinet inside the unit, but it is a 24 volt problem.
Jan 22, 2013 | Amana GMH950453BX Gas Furnace
The mini fuse(2A/240v) keeps on blowing up on the power supply port, what could be the problem
You can tell a lot from what the blown fuse looks like. If it's all black or even shattered, it's likely a short circuit somewhere. If it's just blown, then you have an overload.
Another way to find out is by figuring out when the fuse usually blows. If it blows when it's tapped, shaked or moved then you have a loose wire that's touching somewhere it shouldn't.
If it blows when you turn it up high, it might just not be able to handle that much power. Remember to ALWAYS turn down amplifiers when you hear noticeable distortion. Or, the sound pressure from the speaker might be jostling things inside the cabinet.
If it blows when you plug it in/ turn it on/ start using it you've got an electrical problem, not a mechanical one. You'll need to get the multimeter and start tracing faults.
Aug 12, 2010 | Gem Sound GemSound TR-15 Speaker
Keeps blowing fuse in woofer
Seems like the wires inside the woofers are crossed. Open the sub and make sure that there are no bare wires touching. If everything seems OK then the circuitry inside is blown.
Dec 13, 2009 | Infinity TSS-1100 System
I have a kenwood kac-7202 and it keeps blowing the in-line fuse
Are all the wires hooked in right? On the bare parts of the wires, are there any 2 wires touching? Most importantly, do you have the correct fuse for the stereo?
Oct 11, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Audiosource AST-Sub 10 subwoofer. it blows the fuse when turn on.
It sounds like your audio amplifer has a short (probably the out put transistors or module). This should not be an expensive epair.
To check your speaker you can use an ohm meter. First, pull of one of the two wires that connects at the speaker. You should read 4 to 8 Ohms. Also you will hear a little pop through the speaker as you touch the wire. You can also use a 9 volt battery in the same way.
Good Luck
Jul 25, 2009 | Audio Players & Recorders
Sony Home Stereo Fuse
When the wires touched, the output transistors overloaded before the fuse had a chance to blow. The outputs need to be changed. It is possible that the driver stage for the final outputs is bad also, but there is no way to know that without removing the bad outputs. Figure on $25-$45 in parts for this repair.
Dan
Aug 26, 2008 | Audio Players & Recorders
No sound
good day, check your spkr impedance, if 4oms use a posive spkr dividing network. if stills blows up replace a higher amperage of your fuse. ex.4A raise it up to 5A. the your amps consume higier current if more spkr wattage.
May 29, 2008 | Kenwood KAC-5203 Car Audio Amplifier
Kenwood mpe system flashing protect
"PROTECT" means that the unit's thermal protection units were activated, which in turn cut off output power to the speakers. The causes for this vary. Usually, it's a problem with the impedance load that the speakers present to the power amplifier inside the receiver. Occasionally, the circuit acts up and activates itself, or playing the unit too loudly has blown a fuse. First, check all the user servicable fuses. You'll find their location and amperage rating in the user's manual. If they're broken, replace them. Make sure that none of the bare wire from any speaker is touching any bare wire from any other speaker. If the unit still won't power up, then I'm afraid you'll have to take it into the shop for evaluation by a qualified repair technician. Best of Luck.
Sep 14, 2007 | Kenwood KDC-MP335 CD Player
165 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
