Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Dyson D17 I am trying to figure out where this thing goes. When I was taken everything apart it kind of pop off and did not see where it came from any help would be great.
I have the same problem and I am trying to see how to place it back inside on reassembly.
Posted on Aug 24, 2008
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a dyson animal d17 i have taken apart completly and cleaned all filters and clogs and i still have little to no suction and wont turn on in the upright position
With no suction you should check the venturis. They can become clogged if you suck up wet dust, wet cat litter, etc. You\'ll need a Torx Screwdriver to get it apart. See where that gets you.
Jan 07, 2014 | Dyson DC14 All Floors Upright Vacuum...
How do you put the belt on a Dyson D17
For advice on replacing the belt, it's probably best if you get in touch with us directly, so one of our experts can talk you through the process over the phone. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Dyson Online Customer Support
Jun 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I took my Dyson DC 25 Animal apart to clean it, and now the red foot pedal won't lock the vacuum into the upright position anymore. The trouble is the spring pin for the pedal popped out and I can't figure...
That spring thing goes where the pedal screws into the side. When 'facing' the dyson in the front, it's on the left side. The spring's circle part and short stem section goes into a divot area on the pedal. The other end is tensioned (braced) against some housing piece, but once you insert the spring part in the pedal end part, you should be able to figure it out from there.
This darned spring makes the pedal 'tensioned' to where it pops back up vs. flopping nonsensically.
Feb 09, 2011 | Dyson DC25 All Floors Bagless Upright...
Blockage in pipe of my dyson slim dc18
There sould be a rubber flap under the pipe.Pull it down to remove dust and **** that gets stuck.
Dec 27, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
My Dyson D17 won't work while upright.
check and make sure you have the gasket installed correctly that goes on the center of the cyclone and seals against the canister trap door. If this is backwards, you can lose a lot of suction and it will plug your permanent filter quickly.
Sep 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson slim upright has lost suction via the power head , floor wand is working normal
its either the power head is clogged up with debree or the belt is broken. if the belt is broken it wont wisp everything up. Take it to a shop to fix. DONT TRY TO FIX IT YOURSELF~!!! dysons are very expensive and arent made to just be taken apart
Sep 11, 2009 | Dyson Vacuums
My dyson D17 is making an incredibly loud noise, like grinding, when the bottom brush rotates.
Remove the bottom cover plate and rotate the brush by hand. Look for things that make noise like stones caught in the brush path, bad brush bearings, bad drive belt.
Aug 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
370 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
