Question about SanDisk Sansa e250 MP3 Player
MTP OR How do I switch from MTP to the mass data storage option, it's set on MTP right now, the booklet said goto settings and find the USB option or something like that, but I have gone to settings and see nothing that helps with that.
  • 8,596 Answers
After careful research I have discovered the the manual is wrong - sorry - you are out of luck
Posted on Aug 14, 2008
I have exactly the same problem. How do you get to the USB options? Help, Somebody"
Posted on Aug 01, 2008
Blackberry curve 8330 cellphone will not show up as connected when connected with USB cable to my macbook pro. One suggestion to solve this was to turn off MTP setting. Where is this setting found?
Hello!
You must enable Mass Storage on the device.
Go to Options -> Memory -> Mass Storage Support. Make sure the field is enabled.
Try again and see if it pops up on your Mac. If it doesn't, go to the Blackberry website and download the Blackberry Desktop software. Try connecting through that.
Hope this helps!
Apr 13, 2011 | Computers & Internet
When i try to connect my phn with pc .it does not show any option mass storage ,pc suit etc,its only start charging.i also set connectivity setting on data cable.but i am not able to connect my phn please...
Open device manager on pc goto to ports section while mobile attached with usb there should be Mobile port line right click it choose uninstall remove usb restart computer reconect usb and mobile everything should be ok
Mar 03, 2011 | Samsung i8910 OMNIA HD 16 GB Black Cell...
Not enough space
You should have your Sansa player set to MTP (Media Transfer Protocol) when you are using it with any of the supported subscription (ie) iTunes, or Rhapsody music services. The main purpose of MTP is to transfer media files and associated metadata to/from devices, with optional additional support for reading and setting of device parameters such as special DRM-related device parameters for restricted content. Otherwise, you should set it to MSC (Mass Storage Class), which is the normal USB mode for storage devices like thumb drives, and camara SD memory cards.
See this tip posted here Tips on MP3 connection problems..
MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP3 players and cameras to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management (DRM) protected content. MP3's downloaded form services like Rhapsody and Napster will only function in this MTP mode. Things to do if you are getting not enough space mesage.
1. Turn device OFF. 2. Facing the hold switch slide it to the right so an orange color would show putting the device on Hold. 3. Connect the device to the PC.
If you added songs to the device in MSC mode, then you switched to MTP mode, you will not be able to see the songs added in MSC mode and vice versa, though the space used on the player will still reflect their presence. Switching modes should make the files show up. For example, switching back to MSC or MTP mode.
For older players - e200v1, c200v1, c100, m200 - the files become hidden files if the modes are switched. An easy workaround is to edit the folder options to show hidden files.
STEP 1 - Edit the folder options of the computer to show the hidden files
Windows XP: 1. Double-click My Computer. 2. Under the Tools menu, select Folder options, then click the View tab. 3. Under Hidden files and folders option, select Show hidden files and folders. 4. Uncheck the Hide protected operating system files (Recommended) check box. 5. Click Apply, then click OK.
Windows Vista: 1. Double-click Computer. 2. Click the Organize button on the upper left corner. 3. Click Folder and search options. 4. Click the View tab and select Show hidden files and folders. 5. Uncheck the Hide protected operating system files check box. 6. Click Apply, then click OK.
SOLUTION 2 - Perform a Check Disk.
STEP 1 - Switch to MSC mode 1. On your Sansa player, switch the USB mode to MSC. 2. Connect the Sansa player to the PC.
STEP 2 - Perform Check Disk 1. Locate the Sansa player under My Computer. 2. Right-click the removable drive associated with the Sansa player, and select Properties. 3. Click the Tools tab, and then click Check now. 4. Click to select the Automatically fix the file system errors and Scan for and attempt recovery of bad sectors check boxes. 5. Click Start.
SOLUTION 3 - Format the player in MSC mode or MTP mode.
Jan 16, 2011 | SanDisk Sansa m240 MP3 Player
How to transfer the data through data cable
there are two functions using the usb cable .on your phone go to connectivity and then usb connection .for transfer of data to your memory card select mass storage option.then connect the usb cable to your pc.it will show a window[the one when we insert a pen drive] select the open folder and then u can drag ur file to the folders or copy the mobile files to the pc.
for internet service select the data transfer on your phone .then goto the internet club icon of the lg suite create a profile of your net setting.next goto phone and modem settings in the control panel and select the lg modem option and click ok so finally a window will display for net connection for further clarification you can refer the help option of the lg pc suite..
Mar 20, 2010 | LG GM200 Cell Phone
Can't get the right usb connection on my mp3 to download music.
Win Xp -> Go to Start-Control Panel - System - Device Manager - Last on the list is MTP player, click on it and select upgrade driver - i will choose myself - i there will be two options ( MTP player and USB mass storage device ) Pick Usb mass storage and then OK. Then your MP3 player is visible in My Computer
Jun 08, 2009 | Sony Walkman NWZ-S616F MP3 Player
I installed my sony NWZ as MTP device, but now i want to go back to simpler UMS (standard usb connection) ive tried removing the mtp drivers from device manager, but it always just auto installs... Can...
Since there's no easy option in the Walkman's settings to switch back and forth between MTP and UMS, there's a little trick to un-do the MTP drivers so that the unit becomes a straight USB Mass Storage drag/drop unit. You have to go into Device Manager (Windows XP), find the Walkman in the Portable Devices group, right click, then select Update Driver. Then select "No, not this time", then Next. Select "Install from a list or specific location (Advanced) then Next. Select "Don't Search, I will choose the driver to install", then Next. (Be sure to check the box beside Show Compatible Hardware) Highlight USB Mass Storage Device, then Next. (To revert back to MTP, just do the same thing but choose MTP instead of USB Mass Storage Device.) Personally, I'd never go back to the MTP mode. Having the Walkman seen by the computer as just another USB mass storage device allows the drag/drop transfers to go much faster
May 05, 2009 | Sony NWZ-A829 Digital Media Player
How to download songs,images and other stuff to your phone instructions/manual
use mass storage to move your files heres how
try these drivers www.pcleeds.com/ install the drivers on their drives page there is also the theme manager for viewty there then remove the cable from your phone goto settings connectivity and set you phone from data suite to mass storage then plug your usb back in the phone should now be found as a mass storage device then just download whatever you want to your pc then transfer then to your phones memory card and install your games or apps from there
Mar 17, 2009 | LG KU990 Viewty
try these drivers www.pcleeds.com/drivers.html install the drivers then remove the cable from your phone goto settings connectivity and set you phone from data suite to mass storage then plug your usb back in the phone should now be found as a mass storage device
Mar 08, 2009 | LG KU990 Viewty
Songs
try this...........download the songs to your pc
unplug your usb cable first goto into settings phone settings connectivity USB and change it from data service to Mass storage then plug your phone back in and it should be found.
as a mass storage device then just copy your downloaded songs to the mass storage device...
if you pc asks for a driver it can be found here www.pcleeds.com/drivers.html
Feb 25, 2009 | LG KU990 Viewty
"Please insert a disk into drive.. "
  • u can install lg internet kit from " wowlg.com" then u can connect with ur USB for connectivity,
  • for connecting internet u need to select 'com port' option instead of mass storage .
  •  or if u want to trfr data from mobile to PC or vice versa u can selecrt the option of mass storage , then automatically ur h.set wil restart,u wil get the option USB "ON" on ur mobile. u wil get new link in ur PC "removable device " in option My computer, open that to trfr data.
Oct 22, 2007 | LG Shine KE970 Cellular Phone
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
