Question about Refrigerators
Door insulation or lining has areas that are flat and leak air. I had two areas that I could slide a dollar bill out of on my RV refrigerator door. It is less than 4 years old. I stored it with the doors open and put a clothespin on the flattened sections and came back a week later. Now there were 5 or 6 flatten areas of lining, but where I put the clothespin, it stayed out ok. The lining looks in new condition other wise, and nothing was hitting it to flatten it out. It is almost like it is being sucked flat by heat or something.
  • 770 Answers
The best thing to do is to reform the gasket use a Hair Dryer to soften the gasket all the way around be carful not to melt it once it is good and warm then close the door and tape it shut fro 24 hours it will re-shape itself to the frame
Posted on Jul 30, 2008
Ice is wet when it come through.
Hey RO, I appreciate your inquiry!
Based off the information you have provided the ice coming from your Frigidaire refrigerator is wet when it comes out. The wet ice could be due to a water leak within the icemaker or an air leak within the gasket. Is there any visible water leak from the icemaker?
I would also suggest checking the door gasket and you can use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the freezer. Hopefully this information is helpful to you. -Matt
Jan 31, 2016 | Frigidaire Refrigerators
Leaking water on floor
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 08, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
My Samsung French Door, Bottom Freezer Model RFG297AARS was leaking into the refrigerator & pooling under the deli drawer.
Apr 05, 2015 | Samsung RFG297AARS Bottom Freezer French...
Water dripping from freezer to ref area
I doubt its from the freezer as u think but rather due to one of 2 things? the evaporator drain plug line is clogged with food and plastic debris thus the water backs up out of the drain line, this can be remedied with hot water, a blow dryer and a soft thing tubing line to clean it out, the other issue may be a bad door seals which is allowing moister condensation to build up inside if u open the door and can slide a dollar bill in between the door and frame body then close the door and if the dollar slides out real easlily u have bad seals or if u can feel air seeping out from anywhere on the door seal?
Mar 13, 2015 | Refrigerators
Water dripping from freezer into refrigerator. Leaking from cold air chase that comes from freezer to refrigerator. Drain line is clear. Leaks more if using ice maker.
Dec 16, 2014 | Refrigerators
Rfg293hars condensation coming from refrigerator
Freezer /fridge water in fridge
Oct 04, 2014 | Samsung RFG293HARS
My refrigerator model no fphb2899pf has frost build up in the freezer
Thank you for your post, friend!
From what you are describing it sounds like a possible water leak or air leak. The best way to check for any possible air leaks would be to test your gasket. You can test this by using a dollar bill. Place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket.
If the gasket is sealing properly you may want to seek assistance from a professional to properly diagnose and repair your refrigerator. Hopefully this is helpful. -Matt
Sep 27, 2014 | Frigidaire Refrigerators
Doors not sealed correctly on Maytag refrigerator
Door gaskets have a magnet that holds the door shut. Place a dollar bill between the gasket and cabinet and pull that dollar all the way around the door. You should feel some resistance, and if the bill is loose in any ares, heat that area of the gasket with a hair dryer. Once you have completed this on both doors, your problem should be resolved.
Jul 21, 2014 | Refrigerators
Temperature varies over time. Cleaned coils.
During hot summer months and frequent openings this will happen - it is normal for temperatures to vary when you add in warm food or open the your refrigerator often and for a long time, if it is not your case, then the next thing I could think of is that cold air is escaping, you have a leak somewhere - check your door gaskets using the dollar bill trick - slide in a dollar bill in different areas of the gasket, shut the door, pull on the bill, if there is no resistence and the bill slides out easily, you have a gasket leak.
Aug 17, 2009 | KitchenAid Refrigerators
Frost on upper dr and ceiling frigidare frost free upright freezer already installed door insulation kit & sealed heat exchanger entry into cabinet and drain line has trap
Check the door gasket for seal by closing the door on a dollar bill or some other stiff thin paper. As you slide it around the door it should have resistance.
Jun 28, 2008 | Refrigerators
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
