Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
Refirdge & freezer is warm
About 3 years old and the damn thing just wont keep stuff cold in the freezer - but pop can froze in the lower portion of the refrig area.
Lowest temp in the Freezer is about 35.
I cleaned the coils and vaccumed everything - no change.
Please advise if anyone have a solution to the low temp in the freezer and the ice dispenser no water problem.
Posted on Oct 06, 2008
Gbscohbxercc referigerator freezing food
Could be a defective cold control.
Nov 28, 2013 | Refrigerators
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
Greetings: I have a 4-5 yr old Whirlpool up-right
lucky to get five years out of any white good
time to do the math
replacement cost of failed components
benefits of a new up-right Freezer
Feb 28, 2017 | Whirlpool Freezers
Warm refrigerator and freezer
May be a bad defrost timer and the evaporater is froze up with ice. Clean dust buildup from the condenser under or behind the unit. Always give the model number
May 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Top portion offreezer is warm bottom is cold
Sounds like the defrost heater is bad . Part number WR51X10055 . You will need to remove the 2 or 4 screws , holding the lower portion of the inside rear freezer panel . The heater , is attached to the bottom of the coils , held on by 2 screws . You should also replace the defrost thermostat , Part number WR50X10068 . This is the 1 " cylinder , clipped to the top of the coils , with a blue and pink wire attached to it . This bimetal (defrost thermostat) , cuts the heater off , when/if the temp behind the panel gets to 140 degrees , therefore , keeping the food from defrosting .
Oct 22, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
GE Fridge/Freezer Having to turn temp up just to keep it cold
From your comment. It's not that you have to defrost the parts, that's what they're called. "defrost timer", "defrost t-stat" and "heat element". Defrosting the whole fridge for a few days actually will clear the ice blockage if that's it but it will return in a couple weeks if the "defrost cycle" isn't doing its thing. A fridge typically goes into some form of "defrost cycle" to keep it "frost free". As an example, every 12 hours the compressor turns off and the evap. fan turns off then a heat element turns on to melt the light coating of ice on the "cooling coils". Once about 1/2 hour goes by the heating turns off and the cooling turns back on again. This repeats over and over to keep the ice from building up too much. If that cycle is broken, the ice will build and build till the whole coil is a block of ice. Then the air can't flow around it to provide cold air for the whole unit. It acts basically like putting a large block of ice in the freezer and keeping the doors closed... without a fan to move the cold air only the very lower portion of the freezer is cold, the rest is warm.
Dec 30, 2006 | GE GTH18KBR Top Freezer Refrigerator
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
116 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
