Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner Doesn't finish cycle
My machine GU2455GTSQ0 doesnt complete it cycles. When you put it on the normal or light cycle with the heated dry the machine will continuously run until you turn it off manually. On the regular cycle mine gets stuck on 44 min and on the light cycle at 39 min. I have figured out that if you wash only it will get past that time and when you get close the end of the cycle you can push the dry button and it will go on to dry the dishes.
The machine appears to be washing properly just will not switch over from wash cycle to rinse and then dry. We had a repairman look at it and he could not figure out the problem.
Update as of 7/30 I now cannot get it to complete the wash cycle at all and now it is making very loud noise while washing. I have ordered a new electronic control and am hoping that solves the problem. Any suggestions would be appreciated.
  • 7 more comments
  • peggles68 Jul 31, 2008
    Well replacing the electronic control didn't solve anything.
  • Anonymous Aug 03, 2008
    Just purchased Whirlpool Quiet Partner I. On first use I selected the normal cycle, the machine kept on running on the wash cycle for over 2.5 hours. I had to manualy drain the unit. This dishwasher is going back to the store.
  • rayng2 Aug 12, 2008
    We have had our Quiet Partner 2 for 2 yrs now. It first has the problem of blinking Clean light. After press a sequence of reset button. It is now stuck in the washing cycle unless I turn it off manually.
  • cindy714 Aug 27, 2008
    I have the same problem. it makes noise starting at 44 minutes. it stays on this time longer than it should.
  • mvanderhoof8 Dec 19, 2008
    i am having the same problem and its brand new!!!!!!!!!!!!!!!!!!!!!!!!!!!! i am sooooooooooo mad
  • ReneBoi Mar 03, 2009
    Almost like I have the same problem. My dishwasher wash and drain and wash and drain continuously. It never switches to Rinse.But it doesn't make any noises. I hope any of you guys have the solution for this particular problem.
  • Anonymous Mar 08, 2009
    Yep, mine too. It kept washing and washing, until I finally realized it wasn't switching to rinse or dry, and turned it off.
    But mine is Quiet Partner 1 with a model number DU1055...
  • Klknnthl Mar 10, 2009
    The machine won't switch through cycles and must be turned off manually. Other wise it seems to run fine as long as you manually work it through the cycles.
  • joelfarnum Oct 14, 2013
    Did you get this fixed? I have the same problem and even the exact times (39mins & 44mins).
FIX YA IS A JOKE I WOULD LIKE TO BURY THE ************** WHO CREATED IT!
Posted on Feb 05, 2010
My Quiet Partner II is less than a year old. When It was new it ran the wash cycle for a long long time AND the bottom was filled with dirty water when it was finished. I unscrewed the washer from counter top and shook 3 or 4 times untill it finally started operating properly.. that did the trick. Now its making a light but loud grinding noise when it washes.
Posted on Sep 01, 2008
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
SOURCE: Soap film on dishes
Hard water "filming" is caused primarily by the higher deposit content in hard water clogging up the jets and nozzles. Therefore, there is not the normal pressure for washing or rinsing. This can be eliminated by turning on the dishwasher, while it is empty, and waiting for it to fill and go into it's wash cycle. They open the door and add 3 cups of white vinegar and finish running through the cycle. This will open the nozzles and jets to their full capacity. After that, use a rinse aid for sure.
Posted on Feb 07, 2008
  • 57 Answers
SOURCE: top sprayer not turning, dishes in top rack not
check the holes to see if blocked with foodstuff like sweetcorn etc
Posted on Jun 24, 2009
SOURCE: dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
Posted on Jun 30, 2009
  • 677 Answers
SOURCE: whirlpool dishwasher QUIET PARTNER II doesn't
it is not your dishwasher that is the problem it is actually your hard water. the minerals from hard water dry and leave a white/residue. www.dishwasherfilter.com has a new product out just for this annoying problem. it filters out the hard minerals before they enter your dishwasher. it will leave your dishes crystal clean after the first load guaranteed. it is very affordable and comes with a mone back guarnatee also.
Posted on Aug 22, 2009
My delay light has come on and I cant get the dishwasher to start. The delay light goes out after the time has expired but if you try to move it to the start position the light comes on again
The Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). The Control will flash the Clean LED 7 times repeatedly and will disable the Start/Resume key until cleared.
To clear and reset the control press in this order: Heated Dry ? Normal ? Heated Dry ? Normal and then let the unit run for 1-2 minutes and then press Cancel and let the dishwasher complete the cancel cycle. The dishwasher should operate normally again unless it does not detect a temperature rise in the main wash cycle.
It could be caused by a Heater circuit problem if it continues to stop and flash the Clean light.
It could have one of the following failures:
Open in heater.
Open connection or component in heater circuit.
Faulty heater drive circuit on control.
It can also be caused by the wash pump not pumping water past the heater efficiently.
Oct 11, 2016 | Kenmore Dishwashers
Tip
Dishwasher Clean Light Flashing or Blinking Seven Times
Whirlpool and Whirlpool-made Kenmore Dishwashers are equipped with a fault detection feature within the control software to help the user and most especially the technician diagnose a problem when it occurs. One of the common faults is indicated by a pattern of seven (7) flashes or blinks made by the Clean light indicator. It occurs when the control detects a failure in heating up the water to at least two (2) degrees Fahrenheit above the initial temperature during the first eight (8) minutes of the cycle.
The control monitors the temperature of the water both at the start and at the end the first 8 minutes of the cycle. It will not allow the machine to advance to the next cycle if the necessary end temperature of the water is not reached; instead, it will shut down the machine and will not allow the user to operate it unless the error is cleared. But the error will continue to appear until the problem is addressed.
The error can be cleared by pressing the Heated Dry button then the Normal button in sequence twice; that is, Heated Dry, Normal, Heated Dry, Normal. The user will then be able to restart the cycle but the error will eventually come up again and will not get the cycle completely done.
In order to complete the cycle, make sure water is being fed properly to the machine, the washer impeller is not stiff or stuck, and the float bulb is not stuck in the up or full position. Once all of these are ensured, preheat the water to at least 160 degrees or cool it down to below 62 degrees Fahrenheit before feeding it into the machine. These extreme temperatures will bypass the water temperature detection step and automatically proceed to the next step and complete the cycle.
The technique described above is not intended to address the problem which can be a failure of the heating circuit, water system, pump,or wash impeller. But rather to bypass the water temperature detection step and complete the cycle. The user is advised to determine the reason why the water is not able to heat up. Service of a qualified appliance technician is recommended if the user is not technically inclined to perform the necessary troubleshooting and repair. Disconnect power to the machine prior to servicing to avoid the risk of electric shock that may result to physical injury, disability, or even death.
on Apr 26, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My kenmore dishwasher doesnt heat during drying
The heating element is burned out or the heating circuit is fubar.
Sep 08, 2016 | Kenmore Dishwashers
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Whirlpool quiet partner II stops running or won't complete it's was cycle, sometimes is will wash for a few minutes and stop or it will stop before the water even starts to flow.
I had the same problem with my dishwasher. After hearing that the motherboard was the problem I decided to take a closer look. There were two capacitors (1000 microfarads, 6.3 volts) that looked a little suspect. The tops of capacitors should be flat...these looked like soda cans that had been left in the freezer. Got on eBay, located the capacitors for roughly $3 and $4 shipping, for approx total of $10. Soldered the two new capacitors into the motherboard and put it back together. As soon as I closed the door, the dishwasher started draining the water. When I ran a Normal cycle it completed successfully. Saved myself over $120!
Aug 02, 2013 | Whirlpool Gold Dishwasher with Quiet...
I have a Whirlpool Quiet Partner II dishwasher and it is stuck in the clean mode the light continuous blinks
THat means that something is wrong with the water temp. It is either not hot enough when it fills or the heating element that increases the temp it bad. To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Feb 22, 2013 | Dishwashers
I have a Kenmore elite dishwasher M#665.13419k701, when you run the cycle it shuts off after about 10 seconds and the normal wash light blinks. what can i check??? Thanks. Israel
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a Kenmore dishwasher you appear to have a concern with the cycle interuopting and the "normal" light flashing.
I'd suggest you first try entering a diagnostic/test...to do so is as follows. Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic may take approx. 15-20 minutes to complete. Let it proceed through to completion and let me know what happens and we can go from there.
Regards,
Macmarkus :)
Aug 19, 2011 | Kenmore Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
2,925 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
