Question about EliteGroup NFORCE 570 SLIT-A Motherboard
I'm not getting video neither keyboard
I just bought a NFORCE 570 **** - A Motherboard, I got everything connected properly including the PCI Express Video card however it is not
getting any video or keyboard response, nothing lights on. Any help will be appreciated
  • 84 Answers
Nothing less than a 600 watt power supply for the reason PCI-16 video cards need more power .
Posted on Jul 30, 2008
Looking for advice on a video card. Would a radeon hd 5750 run on c51gm motherboard
1) You have a PCI Express x16 expansion slot, for a graphics card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135010
(Orange)
A) 1GigaByte of graphics memory which is GDDR3. (It is GDDR3, not DDR3; trust me)
B) 800MegaHertz Core Clock
C) 1600MHz Memory Clock
D) API's - DirectX 11
Open GL 4.1
Shader Model 5.0
2) The motherboard chipset is an Nvidia GeForce 6100 - Northbridge, and an Nvidia nForce 410 - Southbridge.
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100_and_6150_series_chip_specifications
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_6_.286xxx.29_series
Nvidia GeForce 6100/nForce 410, came out 2005.
3) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The Northbridge chip of the motherboard chipset, handles the Faster capabilities of a computer.
Processor (CPU), Ram Memory, and HIGH-speed graphics.
AGP technology, and PCI Express technology, ARE HIGH-speed graphics.
Using a PCI slot for a graphics card, or using Integrated Graphics; is NOT high speed graphics.
(As you can see in the Motherboard Diagram, the PCI bus is controlled by the Southbridge chip. The Southbridge chip handles the Slower capabilities of a computer.
Means anything connected to the PCI bus, such as a graphics card in a PCI expansion slot; is handled by the Southbridge chip.
Integrated graphics also )
4) PCI Express came out 2004.
Went from PCI Express 1.0 version to PCI Express 1.1 version.
In 2007 PCI Express went to the 2.0 version. PCI Express 2.0.
Your motherboard, IMHO, uses the PCI Express 1.1 technology.
This is why I recommend a graphics card based on the PCI Express 2.0 technology. (For one)
PCI Express 2.0 is Backward Compatible, with PCI Express 1.1
A little iffy if it's PCI Express 1.0
I have seen a lot of problems crop up with users trying to use a graphics card, based on the PCI Express 2.1 technology; on a motherboard based on the PCI Express 2.1 technology.
That's why I recommended PCI Express 2.0
PCI Express 3.0 is supposed to overcome that, (Use on a mobo with PCI-E 1.1), but I have no real world knowledge, (Hands on), and no input from the 'outside'. (Internet/world)
5) You need at least a 400 Watt power supply. Don't have at least a 400 Watt? Time to move up.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1147669&Sku=U12-41529
Regards,
joecoolvette
Nov 20, 2012 | ECS C51GM-M Motherboard
Nvidia nforce 680i sli 7F with no video.
The Nvidia GeForce 8800GTX graphics card, requires using TWO 6-pin PCI Express power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
MINIMUM power requirement for using TWO 8800GTX's is;
1) Using one 8800GTX requires a 450 Watt power supply.
Must have a 12 Volt power rail capable of 30 Amp's.
(If more than one 12 Volt power rail, add the amperage of all, to arrive at the total Amp's)
Using TWO in an SLI mode requires 750 Watts minimum, and around 50 Amps.
Let me ask a couple of questions;
1) Does your Power Supply have the minimum required Wattage, and Amperage on the 12 Volt power rail? (Or rails)
2) Are you using a Power Supply, that has FOUR 6-pin PCI Express power cables?
3) Looking at the adapter power cable, shown on the right side of the above link;
IF, your Power Supply does Not, have the recommended amount of 6-pin PCI Express power cables; did you use -> TWO 4-pin Peripheral power cables, for -> EACH adapter cable?
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(Mistakenly referred to as a 'Molex' power cable. Molex was the first to design the connector. Name kind of stuck, like calling a adjustable open-end wrench, a Crescent wrench)
Why the line of questioning?
Computer unplugged from power, Anti-Static Precautions FOLLOWED, remove the power cables from the cards.
A) Is the connection end of either power cable burnt? (There should be FOUR cables) Look close.
B) Remove the cards from the PCI Express x16 slots.
Look down into the PCI Express x16 slots at the contact pins. (With a light)
Burnt?
How about the gold plated contact pins on the cards?
There HAS to be TWO 6-pin PCI Express power cables, for EACH card.
There HAS to be TWO 4-pin Peripheral power cables used for EACH 6-pin PCI Express adapter power cable.
A 6-pin PCI Express power cable requires TWO 12 Volt wires. (Yellow)
Using just one 4-pin Peripheral power cable will cause burning.
Not right away. Takes time.
Everything chilly? I'm 'barking up the wrong tree'?
http://www.motherboards.org/imageview.html?i=/images/mobot/motherboards/10420.jpg
Okay, now look at the capacitors on the motherboard.
To the left of the Processor socket are 6 solid Polymer capacitors.
If one of these babies is bad, YOU will know it. They explode.
More of a concern is to look at the other capacitors.
The Electrolytic Capacitors.
More specifically, they are Radial Aluminum Electrolytic Capacitors,
Example,
http://www.panasonic.com/industrial/electronic-components/capacitive-products/leaded-electrolytic.aspx
Visual signs of failure for bad Electrolytic Capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
LOOK CLOSE. Use a light. A slightly bulged top, or a capacitor on a hard lean, may be hard to see if this is your first time.
Everything 5by?
Then your Power Supply cr@pped out.
Each PCI Express x16 slot is capable of providing 150 Watts.
Each 6-pin PCI Express power cable is capable of providing 75 Watts.
[ PCI Express;
http://en.wikipedia.org/wiki/PCI_Express
Scroll down, read under the bold subheading - Power
A LOT of power is required for the two cards alone, and I do not even know what mobo, processor, ram memory, fans, optical drive/s, and harddrive/s, you are running.
Appreciate it if you would post back with your findings.
Post in a Comment.
Regards,
joecoolvette
Jul 25, 2012 | Evga nForce 680i SLI (122CKNF68)...
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
Models of motherboard with socket 775
To many to name but here are a few.
Asus P5Q Pro Turbo Intel P45 Socket 775 Motherboard - Socket 775, ATX, Audio, Video, PCI Express 2.0, USB 2.0, RAID
Biostar G41-M7 Motherboard - Socket 775, Intel G41, MicroATX, DDR2, PCIe, USB 2.0
EVGA nForce 750i SLI Motherboard -NVIDIA nForce 750i, 45nm Support, Socket 775, ATX, PCI Express 2.0, SLI Ready, Gigabit LA, USB 2.0, Serial ATA, RAID
Jun 01, 2010 | ASUS Maximus Formula Motherboard - 45nm...
I bought this motherboard: ASUS M2N68-AM SE2 Motherboard CPU Bundle - AMD Athlon X2 7550 2.50GHz OEM Processor, Geforce7025/nForce 630a, mATX Motherboard back on June 30, 2009 from www.tigerdirect.com....
I guess this is happening because of the CPU getting heated, Kindly check if the CPU heatsink and the fan is seated properly. Also check if there is any power issue, try to connect the system to another wall socket
Oct 01, 2009 | ASUS M2N68-AM SE2 Motherboard
No video output
I'm glad resetting the CMOS fixed it. (Posted as solution so you can rate the response.)
Mar 22, 2009 | EliteGroup NFORCE 570 SLIT-A Motherboard
Complience of motherboard and video card on new PC
remove the GFX and try onboard or try chainging ram slots...
Mar 14, 2009 | Evga e-GeForce 9800 GX2 DDR3 PCI-Express...
Motherboard boot up problem
Try clearing the cmos bios on the board there is a jumper on it
Jan 02, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
No any video signal from the video card
When you power on your computer do you hear any system beeps from the PC speaker? When the computer is turned on it will run through a system check and one of the things it checks for is the presence of a working video card. One beep typically means everything checked out ok and your graphics card is working and it will continue to boot. If you are getting past that initial test I would next look at the monitor and see if it can handle the signal that is being sent to it. Are you not getting any of the boot up text display?
May 31, 2007 | Gigabyte ATI RADEON X550 , (256 MB) PCI...
EliteGroup NFORCE 570 SLIT-A Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
