Question about Asko W6021 Front Load Washer
Asko W6021 won't start
My Asko W6021 washing machine won't start. The power indicator light is on, and when I hit the start button I sometimes hear the "click" that usually comes before the washer fills, but nothing happens after that. I think that one of the circuit boards may be fried, but I don't know how to get into the front access panel to investigate. I also read on here that it could be the motor brushes?
Can someone send instruction for how to get into the front panel of the machine? Any other suggestions for what to do and what may be wrong would also be appreciated :)
  • QueenVi Oct 01, 2008
    usually comes before the washer fills, but nothing happens after that. I also read here to replace the carbon brushes. I don't know what & where are the carbon brushes. Can anyone tell me how & where to order these carbon brushes & how much it cost?
  • TVCMI Feb 02, 2009
    MY W6021 HAD PROBLEM WITH DOOR NOT OPENING, JUST HERE CLICKS - THEN THE MACHINE WON'T RUN. TRIED UNPLUGGNING AND CHANGE SETTINGS AND PUSH START BUT NO SUCCESS. PLEASE HELP. TVC
    Sergeant:
  • 351 Answers
Change the carbons theres nothing wrong with the board
Posted on Aug 27, 2008
When I accidently push the start button when I mean to push the key button to open the door, the cycle will start again. Is there any way to stop it?
Push and hold down the start button again. The machine will stop. Turn to Spin (to drain the water that burped into the machine when you turned it on by accident). Hit start, let the drain and spin cycle complete. Hit the key button and you're all set.
Sep 24, 2011 | Asko W6021 Front Load Washer
My Asko W6021 won't start and the door won't open when buttons are pressed, although the power appears to be on (the red light comes on after power button has been pressed)..
Open the drain hatch at the bottom left of the machine. Open drain pump and check to make sure tat there are no foreign objects in drain pump. Object in the drain pump will prevent the unit from operating properly. If there is water still in the unit, you can use the drain hose to drain the washing machine. If you would like to open the door manually, disconnect power, remove screws holding red plastic handle in place. pull handle.
Mar 15, 2011 | Asko W6021 Front Load Washer
I have an asko w6021 washing machine that won't run. All it does is when the power on button is pushed, and nothing else, it makes a humming sound almost like it's in the middle of the wash cycle. Also you...
Open the hatch at the bottom left of the unit. If there is water still is machine, remove the drain hose and drain machine. Open the drain pump and check for foreign objects, make sure that the rotor spins freely and that there is nothing holding it. This will prevent the machine from working properly
Mar 13, 2011 | Asko W6021 Front Load Washer
My Asko W6021 washer doesn't run. The power light glows when the power button is on. When I press the start button the machine "clicks" twice after a few seconds but does not start. I replaced the fuses...
The question being incomplete I think you mean the motor is not turning , so check the output to the motor after the water flows in, if there is no action of the inlet water coming in , filling and voltage to motor, then the program controller is faulty. If voltage comes to motor but does not run then it canbe the motor , check the capacitor if this of the capacitor running.
Sep 29, 2010 | Asko W6021 Front Load Washer
The machine will not go on. It is stuck. It is a front loading Asko. I opened it and took out clothes by popping it open. Now nothing works.
Welcome to FixYa.
I wonder if you could elaborate and clarify on the issue and the events which led to it as well as the model number of your Asko.
When you say "machine will not go on. It is stuck", is there no power, no led indicator light or it just won`t start.
Specifically what you mean by "I opened it and took out clothes by popping it open".
Do you mean you opened via the button which "pops" it open, or did you pull the emergency pull cord or in fact force it open some how ?
Also when you state "Now nothing works" does this mean the unit has no power and will not come on or does it just mean there appears to be power, but will not start.
I should be able to assist you when I can speak directly towards your model as opposed to generalizing since even within the Asko brand there are many models to cover.
I`ll watch for your reply.
Regards,
Macmarkus :)
Sep 22, 2010 | Asko W6021 Front Load Washer
WASHING MACHINE WILL NOT START
check motor it may need cleaned and oiled, or it might be bad.
Apr 04, 2010 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
Asko washing machine
check the carbon brushes
May 15, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
757 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
