Question about HP Pavilion a305w (DM181AR) PC Desktop
Flashes off mode but nothing else then just turns off
please
  • jim millard Jul 30, 2008
    when you turn it on it just flashes a sign that says off mode
  • weesteviea Nov 20, 2008
    every monday my monitor says "off mode". it then will not turn on again untill wednesday. i have checked scheduled tasks, and it shows nothing set to run on a weekly basis. can any one give me any insight as to what is happening. any help would be appreciated.
    Scholar:
  • 195 Answers
Well Jim I hate to say it but you have to Install a fresh copy of Windows or Mac, what ever you have installed. The problem lies with your Boot Section, your computer can't read the sequence required to run your system. If you have an Installation disk for your windows or what ever, it will read that when you Re-Boot and take off from there. Sadly, if you have files you need to keep their lost unless your System Disk will let you repair instead of installing a fresh copy of windows. That should do the trick. If you don't use your windows disk, you have to have some type of Bootable Disk to read from. Good Luck.
Posted on Oct 28, 2008
Nikon d3100 stuck on flash mode
What do you mean by flash mode?
Have you read the manual how to use the camera?
If nothing from there helps, try connecting it via USB and check if there is firmware update. If even that doesn't help, try acessing menu and doing hard reset from there.
Mar 03, 2014 | Nikon D3100 Digital Camera
Electrical issue.
Access ECM on the data link connector . Turn ignition switch on(do not start). Turn diagnostic mode selector on ECM fully clockwise. Wait at least 2 seconds. Turn diagnostic mode selector on ECM fully counter clockwise . Self diagnosis in mode 2 Mil should flash. If the scan tool record s codes or the mil light will flash the codes
Feb 18, 2014 | 1997 Nissan Maxima
My camera say no flash because of micro mode how do i turn the flash on?
The Micro mode is used to shoot close up images. Turning on the flash in micro mode will result washed out over exposed images. Hence in most cameras, choosing the micro mode will automatically disable the built in flash. Some Camera will show the message, cannot use flash or flash cannot be changed because of the micro restriction. This is normal operation. If you wish to use flash, please use some other manual priority mode.
thanks for understanding.
Feb 18, 2011 | Vivitar ViviCam 8025 Digital Camera
The flash isnt working. if i try to take a photo with the flash on, nothing happens
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting.
Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
  1. When shooting MPEG movies.
  2. When shooting in the Twilight or Handheld Twilight mode.
  3. If shooting with the Burst or Multi Burst mode.
  4. Shooting with Sweep Panorama
  5. Shooting with the Fireworks or High Sensitivity mode.
  6. If an external flash is connected.
Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
  • If the issue persists, please reset the Camera and make sure that battery is fully charged.
  • If the issue persists after performing all the above mentioned troubleshooting steps, service is required.
If you feel that the above Troubleshooting steps helped you. Please rate my answer positively.
Thanks for understanding.
Jan 25, 2011 | Sony Cyber-Shot DSC-S500 Digital Camera
In my holga 120 cfn the flash doesn't go off when i press the shutter. the batteries seem fine and the orange light turns on, but when i press the shutter nothing happens. a couple of times it has worked,...
The flash would fire as per the requirement, in auto mode.
If the ambient light is enough then the flash will not fire.
In case you need to use the flash in bright conditions (e.g. For using as a fill flash) please repeatedly press the flash button (The one with the lightning symbol on it) till you get a lightning bolt symbol on the camera display.
Now your flash will fire on every shot that you click!
Please ensure that you revert back to the Auto mode once done.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will look forward to your feedback and positive rating.
Sep 19, 2010 | Lomo Holga 120 CFN Medium Format Camera
Ps3 in standby mode nothing else will happen
the red light will stay on allways and your controller is probably charging is why its flashin if u HAVE to turn it all the way off take out tha games and flip the switch in the back
Nov 15, 2009 | Video Game Consoles & Games
Flash is not working
You have to change the sitting to night mode and turn on the linght. If the linght turn on then please have a look to your mobile sincer may some dust cover it.
Nov 22, 2008 | LG Prada KE850 Cellular Phone
Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
Feb 13, 2008 | Nikon Coolpix 7600 Digital Camera
Strange flash problem...
Suggest you go through all the other menus to check whether you have the camera working in some mode which isn't compatible with flash. For instance, my Olympus (different model) won't allow you to select flash if you're working in super macro mode. A.
May 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
HP Pavilion a305w (DM181AR) PC Desktop Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
