Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Remote doesn't work?
My hard wired in wall remote will not activate any functions on my fan. I have checked for power and all is fine. It worked great for 2 years then just stopped completely. I do notice that the red indicator light on the remote will barely glow for a second or two when a button is pushed. If you push the same or any other button again it will not glow at all. After 5 minutes it will work again but just once. How can I check the fan and the remote to see which is the problem?
  • larry426 Dec 05, 2008
    My remote doesn't work. I've changed batteries and the remote light still isn't coming on and it doesn't activate the fan. Purchased and installed less than 6 months ago.
I have two hampton bay fans in the family room one works with the control the other stop working it dosent start it worked for about two years but it appears as the control dosent get it started. Also the other one dosent move much air they are very slow
Posted on Sep 13, 2008
I have the same problem!!!
Posted on Aug 26, 2008
Just installed a heller ceiling fan with remote, it works fine from the remote but the light nolonger works from the light switch
All the switch on the wall does is turn the power on/off. You have to do everything from the remote with the wall switch on.
Dec 27, 2013 | Hampton Bay 24002 Ceiling Fan
Connecting wires
You are just missing one wire to all the circuits. The ones that work are good ... add the one wire that is not hooking up to the others to complete a serial circuit.
Mar 30, 2017 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
Purchased state street brushed nichole hunter fan 52" with remote control installed working fine. cannot turn off and on by wall switch only remote control can this be fixed
Something got wired wrong when it was installed. The wall switch should still be able to function even with the remote control option. Especially if, the batteries were dead in the remote. Check the wiring sequence again, comparing with the installation (wiring) instructions.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Hunter Heating & Cooling
Ceiling fan is all wired up and on ceiling but light doesn't come on or fan doesn't spin. I have checked connections and tested for power. Is there a switch or anything on receiver that needs to be...
Jerry, from what you said, I assume you have a remote controlled ceiling fan. If that's the case, check the batteries in the hand held and the receiver, to make sure they are charged. Also, make sure they are installed properly. The Owner's Manual should have a reference to setting or resetting the codes for the remote control (Hand Held & the Receiver). Check those to make sure they are matching. And don't forget, the wall switch must remain ON for the fan to work, even with the remote control. The remote simply overrides the wall switch, when in operation. You may have to use the pull chain to start the fan motor the first time, then the remote can take over from there.
Good luck. I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Heating & Cooling
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Hunter Fan - Remote
Most likely the fan turns on with a wall switch and then as long as the power is there [ wall switch left in on position], the remote works
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Lights are on all the time, fan doesnt work, remote does not work
I have changed the remotes on 5 Hunter fans in the last 3 months. They have a problem with how some of them mount, that makes them drop down and vibrate loose. If you do not have a wall switch for it, you may want to go to pull chains, or just replace the remote. It is NOT the controller you hold in your hand, but the part in the fan. (never the easy way right?) The remote is not hard to change, but you DO have to let the fan hang from the holder on the ceiling bracket, It gets too heavy to hold while you change the remote.
All but one of the remotes I have changed, came from a mass market type of builder/handyman store, and they have just replaced the part at no charge.
Dec 21, 2008 | Hunter 52" Ceiling Fan With Light And...
Remote control ceiling fan
Possibly a bad circuit board in the ceiling fans remote function. I would suspect that the circuit board has a thermal issue where once warm it works fine. The most common fault that I have seen is a bad solder connection on the board. Pull the board from the fan and check all solder connections for cracks or dull solder. If you see any of these then reflow the solder connections. If this does not work you probably will need to order a new board from the manu.
Jan 26, 2008 | Dryers
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
183 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
