Question about Casio FX-300W Plus Calculator
Incomplete numbers on screen of fx100w
All of a sudden, the screen of my calculator is showing up incomplete numbers i.e the 0 and all other numbers are showing up partially, i.e 3 and 7 both show up as 1 and the calculations are not working either.
  • Anonymous Nov 22, 2008
    Incomplete numbers on lcd screen.
    Regars
SOURCE: Not sure which mode my calculator might be in...
are u sure that ther is no "prank" app running that one of your freinds may have put on?
Posted on Jan 20, 2009
  • 7 Answers
SOURCE: calculator won't show decimal places
Haven't heard of it giving nearest whole numbers before. But have you tried pressing SHIFT and then SETUP (upper right hand corner next to ON button) and then pressing 2 (LineIO)? Or perhaps you're in different MODE?
Posted on May 03, 2009
  • 7 Answers
SOURCE: Trying to find standard deviation on the calculator
I took statistics last semester and I don't really remember how, but after you enter your data, you press SHIFT, then STAT (on the 1 key), then I think it's under 5 (VAR), and maybe Xon-1? Eh, funny how long you remember this stuff for....
vladp995
  • 81 Answers
SOURCE: My Casio fx-85v Super - fx solar power calculator shows a erratic
Yeah I had the same problem, you need to open your calculator and check if all the screen cables is alright, i had just put sellotape on the back of the screen from inside so that the screen hold better, and it works for me if for you not maybe something broken in the schema but try it. The thing I know for sure the problem is in the screen or from where it get the data the schema. Tell me if it's working
Posted on Jul 07, 2009
  • 7993 Answers
SOURCE: the calculators screen is not fulling showing the
Hello
If it is too dark
Try reducing the contast as follows
1.Press [2nd] key and release it
2.Press [DownArrow] and release it
3. Keep repeating the sequence until contrast is adequate.
If it is too light increase contrast
To increase contrast Do the same but press [UpArrow] instead of [DownArrow]
Hope it helps
Posted on Sep 08, 2009
It jams with a M
M is for Memory. If the M shows, the memory location contains a stored value. To make the M disappear, store a value 0 in the register.
0 STO M.
Jan 22, 2014 | Canon P170-DH Calculator
BA II plus gives approximate answer for FV calculations
The 107,186.37 is what the future value would be if the interest per month is 0.58%, which is 6.96% per year. Try the following:
2nd [CLR TVM] 1 2 N 7 I/YR 1 0 0 0 0 0 PV CPT FV
As for rounding, you can change the calculator display to any number of digits (up to a limit, of course) by pressing 2nd [FORMAT] and then a number specifying the number of desired digits after the decimal point or 9 for floating decimal.
Mar 14, 2012 | Texas Instruments BA-II Plus Calculator
How do I set the decimal place on the calculator - cleaning crew moved it
At the top left of the calculator, you will see a sliding switch that is labeled: DECIMAL A,0,2,4,6,F. Move the indicator to the "0". This will remove all excess zeros. The numbers represent how many decimal places the screen will show.
Feb 28, 2011 | Sharp EL-2630P Calculator
Ok so my math hw only gave me the degree, minute, sec format of the angle. How do i input it in the fx 155 es to work out and find the rest of the angles, sides, etc?
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
This showed you how to enter angles in DMS or DD. For the rest 'find the angles, etc.' you should refer to your trigonometry manual: You have the definitions of the trigonometric ratios, the sine law, the cosine law to resolve triangles.
Feb 24, 2011 | Casio FX-115ES Scientific Calculator
What function should it be on to get a whole number answer for division problems EX: 15 divided by 2
15 divided by 2 isn't a whole number.
If the calculator is showing a fraction and you want to see it as a number, press the S--D key to switch between symbolic and decimal values. To have all results appear in numeric form, press SHIFT MODE 2 to select the LineIO mode.
If you want to set the calculator to show only whole number, press SHIFT MODE 6 0 to select FIX 0 display mode.
Feb 22, 2011 | Casio FX-115ES Scientific Calculator
My calculator shows 0.00000000 instead of 0 every time. How should I fix it? All the functions works properly, but there are too many zeros for me.
At the top left of the calculator, you will see a sliding switch that is labeled: DECIMAL A,0,2,4,6,F. Move the indicator to the "0". This will remove all excess zeros. The numbers represent how many decimal places the screen will show. I have the manual for this calculator if you need it. LBrown18062@hotmail.com
Jan 03, 2011 | Citizen CX80 Scientific Calculator
Time problems
Sorry to say it but the DMS key is to convert between Degrees, minutes, seconds and decimal degrees (angle units). This cleared here is how to use the DMS key on this calculator.
Jan 14, 2010 | Casio FX-115ES Scientific Calculator
Decimals wont show
You need to change the display format.
Press the [MODE] key a certain number of times until the screen displays Fix, Sci, Norm on one line, and 1 2 3 on the next line, with 1 under Fix, 2 under Sci and 3 under Norm.
Press 1 (Fix) followed by a number (1,2,3, etc.) This second number will set the number of decimal digits. In other words, if you press 1 (Fix) 3 all your results will have 3 decimal digits. If you choose 0, your results will not show decimals.
Hope it helps.
Thank you for rating the solution.
Dec 04, 2009 | Casio FX-300MS Calculator
When I put X^(1/3) into Y=, and go to nDeriv, and find the derivative at X=0, the calculator gives me 100. I (and a few math teachers) have done this many times by hand, and we all get undefined as an...
The derivative of the cubic root of x is, as you wll know, equal to (1/3)*x^(-2/3). Its limit as x approaches 0 is undefined. However the calculator uses approximate representations of numbers to calculate. And you can never be sure what it is going to give as results near singularities (poles of functions).
Calculators with Computer Algebra Systems can do better. To show you this, I am enclosing a screen capture showing you the correct result.
On this screen I defined a function u =f(v) where u is the derivative of cubic root of v. I stored 0 in the dummy variable v, and I evaluated the function u at v=0. You can see that the result displayed is undefined.
That this result is deemed correct seems to me just a matter of convention. We do not know, we cannot know, or we dont care to know? It will not make any of us lose sleep.
Hope it helps.
Nov 10, 2009 | Texas Instruments TI-84 Plus Silver...
Casio FX-300W Plus Calculator Logo
74 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
