Question about LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television
Shadow down left hand side of screen
There is a black shadow down the left hand side of the screen about a quater of an inch from the left towards the center of the screen?
Is it an LCD or DLP? The Model below suggests it is an DLP. Sounds as if you have the dreaded light tunnel collapse common to all LG DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps. Good Luck.
Posted on Sep 25, 2008
4 year old vizio 42 inch tv lcd. While watching tv, the screen started dimming. There is a 4 inch shadow all along left side of the screen and the 1 inch line shadow going down the middle of the screen.
Maybe a power supply or related issue but at 4 years of age the set has reached its life span----parts will be hard or impossible to find.
If you got four years I would retire it and recycle it and then replace it.
May 14, 2012 | Televison & Video
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
I have a 37in. vizio flat screen. It has a black shadow in the left center of the screen. It's there at all times.It's about 7in.x 3/4in.it runs vertical.any ideas?
wish the news was better for you, the convergence chip or the color engine has faulted and burned the screen This will be an expensive repair unless it has extended warranty
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Vizio L37 Television
I have a dark shadow down one side of the screen
replace light tunnel = use service manual for procedure....T.
Dec 13, 2008 | Samsung HLP6163W 61" Rear Projection...
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Screen Problem Television Set
Need some more details the problem you describe could be anything from a simple convergance problem or the light tube going bad in a light engine, one problem about $80.00 to fix the other, slightly over a $1000.00
Mar 19, 2008 | Televison & Video
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
IBM Infoprint 1352 Laser missing an inch of test on the left hand side
could be, but first take out the cartridge then look inside the unit there is a black roller, kind of spongy or hard rubber, is the black part towards the right? grab it and give it a tug and see if you can SLIDE it to the left if so then it needs to be replaced, that is your problem.
It could also be the fuser, are the copies on the left coming out smudged or with a grainy shadow? then it's the fuser.
Oct 11, 2007 | IBM Infoprint 1352 Laser Printer
Open Questions:
LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television Logo
495 people viewed this question
Computer Repairing
Computer Repairing
