Question about PSB Alpha Sub Sonic 5 Subwoofer
PSB Subsonic 5i Keeps Blowing Fuse
Hi... my PSB Subsonic 5i keeps blowing its fuse as soon as I turn it on. Any ideas on what might be wrong and how I might fix it?
  • frankad2 Sep 26, 2008
    I just unplugged the cable to my psb subwoofer and blew the fuse. Can you replace them or should I bring to the shop?
  • taffos64 Feb 24, 2009
    Similar prob, but i just want to change the fuse, it blow off during a voltage change :(
    does anybody know how or just what are the fuse, i dont recognise it
2 Suggested Answers
SOURCE: PSB Subsonic 6i
Check the power cable.
Posted on May 24, 2008
I have a 2009 Toyota Corolla. Recently the wiper fuse started blowing. The Fuse keeps blowing as soon as the ignition is turned on.
could be anything and without a look myself i couldnt tell you try disconnecting the wiper switch and see what happens is about the best i can come up with was thinking of the self park but with motor disconnected and it still blows ?? thats that out the equation .
Jan 08, 2017 | Toyota Corolla Cars & Trucks
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
88 toyota pick up v6 keeps blowing efi fuse
you may have a short of some kind, when a fuse blows repeatedly it is no good just replacing, you are being told that something is wrong with the equipment.
You will almost certainly have to visit a technician for a diagnosis. It is unlikely to be something that an inexperienced end user can sort out I am afraid.
GOOD LUCK
Oct 26, 2015 | 1988 Toyota Pickup
Fuse keeps blowing
Once a fuse blows & you replace it-- ONE Time--
then you stop
You go to wiring diagrams of the circuit with the
blown fuse & start your testing
Aug 11, 2014 | 1994 GMC Sonoma
Mazda 626 ac fuse keeps blowing
Try unplugging the compressor then put in a new fuse. If the fuse does not blow, the problem may be the clutch on the compressor.
Jul 29, 2012 | 1997 Mazda 626
The Wiper fuse keeps blowing? Any Ideas?
Does the fuse blow as soon as you turn on the switch? Or do the wipers operate for a bit then the fuse blows? Will the wipers work in intermittent mode? Can you move the wipers by hand? Unless other wiring work has been done (eg radio replaced) I suspect the wiper motor is toast.
Jun 25, 2012 | Chevrolet Cobalt Cars & Trucks
I have no green power light on my subsonic 5i which screws do i remove to replace a fuse inside
Make sure you the plug eorks before you do anything. Plug in a lamp or something. The fuse is inside where you plug the input.
Sep 01, 2010 | PSB Alpha Sub Zero Subwoofer
Fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Jun 17, 2009 | Garden
Humminbird fishfinder keeps blowing 5v fuses .Power ok to base but as soon as you attach fishfinder fuse blows
Most probable component that has gone bad and capable of blowing the 5V fuse would be:
  • voltage regulator IV or transistor;
  • reverse protection diode;
  • zener diode;
  • shorted capacitor.
As the 5VDC normally supplies the logic circuitry, perhaps diagnosis and tests should be focused within that area.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 24, 2008 | Humminbird GPS
AMp keeps blowing fuses
http://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
Hi You can refer to my detailed solution above...if you still have issues please feel free to contact.
Thanks
Feb 15, 2007 | Kenwood KAC-7202 Car Audio Amplifier
PSB Alpha Sub Sonic 5 Subwoofer Logo
724 people viewed this question
Top PSB Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Terry Weaver
Terry Weaver
Are you a PSB Audio Player and Recorder Expert? Answer questions, earn points and help others
