Question about Sharp Audio Players & Recorders
Sharp model cd-mpx850 mini component system won't play a disc all the way through. About 1 minute to 1-1/2 minute it will stop playing and a code TOC Read is displayed. I tried to reset and clear the codes but won't correct. Any ideas????
SOURCE: CD's won't play
I have an Emerson Audio System (MS3110) and the cd's won't play and the screen is displaying a message "TOC Read" . What does this mean? We've tried to reset it but it still does not work. The radio plays fine. Thecd's won't spin to play. Can you help?
Posted on Jan 11, 2008
robotek
  • 1512 Answers
SOURCE: Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Posted on Mar 16, 2008
zair
  • 82 Answers
SOURCE: Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Posted on Mar 29, 2008
  • 13433 Answers
SOURCE: When I slot a mini-disk
Try another mini-disc, if the disc is working fine, then there is a problem in the reader. You might have to replace it.
Posted on Jun 24, 2008
  • 4234 Answers
SOURCE: Sharp BA2100 3 CD mini component system - NO DISC
This is a relatively common problem when the optics get dirty. If you can reach the lens, try cleaning it using a cotton swab and alcohol. Don't bother with the "cleaning discs" available as all they can do is bruch off the dust. These lenses sometimes get a smoke or dirt film on them that the brushes can not celan.
Keep us posted.
Dan
Posted on Sep 17, 2008
I CANNOT GET THE CD DRAWERS TO OPEN ON MY SHARP MINI COMPONENT SYSTEM MODEL CD-DK890N
Chances are the loading mechanism is out of alignment. Very hard to realign this mech. even the manufacturer just replaces the entire mechanism when repairing.
Dec 08, 2013 | Audio Players & Recorders
I need a FM antenna X 1 (92LFANT1535A) for Sharp Mini Component System model CD-DK890N
Try these web sites:
http://search.aol.com/aol/search?&s_qt=sb&q=Sharp+mini+cd-dk890n+parts&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
http://www.partstore.com/Model/Sharp/Sharp/CDDK890N.aspx
Jan 20, 2013 | Audio Players & Recorders
Cd-mps660 sharp mini system will not play any cd-r
sounds like a codec issue.... what format are you burning to disc? are you able to connect your system to your computer? id try different formats on burning discs first. ive had this problem with other cd players and funny thiong is i have a really old denon cd player that that is bout my age or a lil older and im 31 that will play burned discs but yet alot of newer players wont and its all bout codecs and copyright protection these days so hopefully this will help you.... also try different brand of blank discs.
Oct 22, 2011 | Sharp Audio Players & Recorders
CD player will not recognise or play disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it not recognize or play disc.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Apr 05, 2011 | Sharp Multi-System Mini Component System...
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
THE SYSTEM SHOWS ME ER-CD01 AND ALSO THE PLAYER WONT PLAY THE CD, IT DOESN'T EVEN READ THE CD
this is a standard reset so if its a problem with the programming this should do the trick if it does not either your cd or laser lens is no longer doing its job properly
turn on the set-press the on stanby button,allow the set to enter demo mode. now press the power button while pressing the stop and eject button,clear all will display
hope this helps
Robb
Apr 23, 2010 | Sharp CD-MPX850 Shelf System
Sharp CD-DP2400 3-disc mini component system stops playing in first track
the rails on the laser slead need cleaned..the grease gets hard/dirty and stops it from moving skip it to track 16 to move the dirt off the track..
Oct 26, 2008 | Audio Players & Recorders
My radio
I have this system
Not working right now
gstudeny@comcast.net
Mar 29, 2008 | Sharp CDBA3100 Remanufactured Mini-System...
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
