Question about MSI K8M NEO-V Motherboard
Power cable configuration for MSI K8M NEO-V
I need to install mother board in new cassing, i need power cable configuration for MSI K8M NEO-V
  • 550 Answers
Http://global.msi.com.tw/index.php?func=proddesc&prod_no=159&maincat_no=1&cat2_no=171&cat3_no=7
the download page includes bios drivers utilities and MANUALS - the install guide
Posted on Jul 31, 2008
  • AlmostBob
    AlmostBob Jul 31, 2008
    'scuse me, left off a bit
    ..... the install guide and wiring diagrams are in the manual
How can i connect properly the power supply to the msi k8m neo-v... can u give me a picture of it? when the power supply wire's are connected to the mother board
It's honestly pretty hard to mess up. They're keyed. Just make sure it clicks. You'll likely have an extra power cable that doesn't plug into anything. It's normal.
Jul 25, 2011 | MSI K8M NEO-V Motherboard
Can my mobo msi k8m neo-v supports sata dvd rw? if yes then how to install dvd rw and sata driver?
If it as a Sata connector on this motherboard (looks as though ther should be one), it will support a SATA DDVRW. You should not need Sata drivers, but to be on the safe side, you can download them from here:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=159
check your oS first
Jan 04, 2011 | MSI K8M NEO-V Motherboard
Send me the audio driver for MS-7032 K8M Neo-V
open goole home page download Driver magician instal after update serch all drives click audio drive opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
Oct 24, 2010 | MSI K8T Neo-V (7032020) Motherboard
SWITHCHING MOTHERBOARDS
There will be writing on the motherboard in several places, look very carefully and then google
Everything should just plug in without a problem, each device (ide cable/sata cable/CPU/graphics card) uses different shaped plugs and sockets, they can only usually plug in there own sockets.
Unless you are going to a newer technology ( IDE to SATA or AGP to PCI-E graphics)
If it is the same CPU socket type your only small problem may be connecting the front panel wires (led/hdd/reset/usb/audio)
Aug 01, 2010 | MSI K8M NEO-V Motherboard
No Display
it is just a case where the supply to the processor is not proper! the processor is not getting power, you will see that the red colored hdd led will not light(blink) when u turn it on. so what you can do is try changing the SMPS and if it is not solved with that then try removing all the components and fix just the main items needed to start the system and check. it will start and then try installing one one extra components later at one point if it again goes into that state then that component must be creating the short change it and its done!
reply and revert back to rate!
Jul 21, 2010 | MSI K8M NEO-V Motherboard
Cant find online manual k8m neo-v motherboard can you help
the manual is located in the below address
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=159
Apr 21, 2009 | MSI K8M NEO-V Motherboard
Where to download the drivers
go to driversguide there your find every driver you want ?
Jan 25, 2008 | MSI K8M NEO-V Motherboard
MSI K8M NEO-V Motherboard Logo
258 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
