Question about Gigabyte Slot 1 GA-BX2000 Motherboard
Motherboard/gigabyte GA-BX200. connection to frot panel?
Cable connection from motherboard to front panel
what way cable plugs are put in?
3 Suggested Answers
  • 154 Answers
SOURCE: gigabyte motherboard connection front panel to motherboard?
Have you reseated them properly? Did you have the power connected still when you took them out and put them back in? If you had power still plugged in you have probably fried the ports.
Posted on Jul 26, 2008
charcois
  • 763 Answers
SOURCE: how to connect usb cables inthe front panel to motherboard Gigabyte GA-6VM7A+
from your case there are wires to put it on the motherboards pin. you can check your motherboard's manual on where to insert the designated wires to the correct pins.
thank you for using fixya
CHARCOIS
Posted on Nov 10, 2008
I have gigabyte ga-g41mt-s2p mobo does anyone have picture of correct cable connection layout, so I can check visually if I have connected the cables correctly
You can download "GA-G41MT-S2P" Manual and all the cable connections are in the Manual.
FYI
As for the Front Panel ATX casing cables connections, the "white" cables are the -ve polarity & the "coloured" cables are the +ve polarity.
Hope it helps.
Jun 26, 2011 | Gigabyte GAG41MTS2P motherboard
Installed new motherboard (Gigabyte GA-G41M-ES2L), I cannot figure out where to plug the blue & white wire coming from the main power button on the front of the computer on the motherboard. Please...
hello tami_hennacy
unfortunately the wiring color for computer cases are not standard. so blue and white does not mean much. you need to look at the connection on the tip of the wire to see if it is labeled so you can locate the corresponding connection point on the mother board. Gigabyte motherboards have a very good step by step discretion of all connections.
if it is not labeled then you need to oped the case front panel and see what the other end of this pair of wires is connected to.
hopefully this has helped
good luck
Dec 30, 2010 | Gigabyte GA-G41M-ES2L Motherboard
Reconnnecting wires from on my Gigabyte GA-7ZX motherboard
you can check the MB pinout diagram from their website. The powersupply connector generally of a unique size and you can easily identity by the pin numbers and safely connect it, as you cannot insert it in a wrong direction.
Nov 17, 2017 | Gigabyte GA-7ZX Motherboard
Front panel connections
I went to dogpile.com typed in "gigabyte ga-7dx" for the search, looked for the gigayte web site, clicked on the link and the page popped up. I selected to download the manual and can now read it. Just follow these steps and i'm sure you will have the manual too. It is all there. Best of luck.
May 29, 2009 | Gigabyte GA-7DX Motherboard
Where are the places of each jack??
Below is a link to the Manual for this Motherboard. Page 24 contains a diagram of where to plug in the front side led's and switches..
http://www.gigabyte.com.tw/Support/Motherboard/Manual_DownloadFile.aspx?FileType=Manual&FileID=15447
Pick any location except for the American server, it doesn't seem to want to download properly.
There you go, thank you for choosing Fixya!
Mar 20, 2009 | Gigabyte GA-6OX Motherboard
How to connect usb cables inthe front panel to motherboard Gigabyte GA-6VM7A+
look in manual for the computer case ..will identify which cables are for which front panel source..then in manual (online or paper) you route to your motherboard for USB/sound etc.... good luck
Nov 10, 2008 | Intel Motherboard
Gigabyte motherboard driver
The problem is not with *********** Board. Check the front panel audio connectors inside your CPU are connected to *********** Board properly.
Sep 28, 2008 | Gigabyte GA-N680SLI-DQ6 Motherboard
Gigabyte motherboard connection front panel to motherboard?
Jul 26, 2008 | Intel Motherboard
Motherboard GA-BX2000
go here.....page 37 onwards
http://europe.giga-byte.com/FileList/Manual/motherboard_manual_bx2000_1002_e.pdf
Jun 04, 2008 | Gigabyte Slot 1 GA-BX2000 Motherboard
Gigabyte Slot 1 GA-BX2000 Motherboard Logo
230 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
