Scart Cables Hi I have been noticing very slight "ghosting" when playing a DVD on a panasonic home cinema. Would a high quality Scart help? Should it be flat? Does it need to cost a lot?
  • KenFaeAberde Jul 30, 2008
    I saw a Pure Scart for £29
    As I have a CRT TV do i need to spend so much?
    New Friend:
I can not play the Haier DVD player without the charger cord connectedto the wall. What cause that?
Posted on Jul 09, 2013
sserpentio
  • 88 Answers
SOURCE: lg da3520 home cinema system
you have probably to clean up your dvd player with a clean up CD. After that if your dvd player doesn't want to read a dvd but play a cd, your laser output must be to fix. you'll have to go to a specialist.
Posted on Apr 23, 2008
SOURCE: I have connected my Bush DS-A332B dvd player to my
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Posted on Dec 28, 2009
  • 12 Answers
SOURCE: is there an unlock sequence available for the LG
1. Turn on DVD player
2. Press eject to open disc tray
3. Enter 0000 on remote
4. Region code and edit box should now be displayed on DVD player
5. Enter 0 (for all regions) in the region edit box
6. Press enter
7. Power off for a few seconds
8. Repeat steps 1- 4 if you want to check new code
Posted on May 27, 2010
SOURCE: my samsung Digital Home Cinema Syst htz 220 cannot play in Nigeri
yes the link www.dvd365.net helped me to uncode the region code. However,the list doesnot have code for HZ220 but i used the option HTDL/M and it helped me.
Posted on Sep 01, 2010
SOURCE: Region Code unlock for Panasonic "SA-BT737"
hi my panasonic bluray dvd player sa-bt737 is not displaying the picture, the sound is working great but i cant watch the movie even though i can hear what is going on in the movie. it has worked great in the past but i dont no what has happened please help me
Posted on Jul 16, 2011
How to connect leads through home cinema system and virgin emdia box
Either use a good quality HDMI interconnect make sure that its gold plated check out this FixYa Tip here for further help
http://www.fixya.com/support/r4565785-1080i_1080p_cable_hdmi_version_need
Some home cinema systems still have a SCART lead instead of the HDMI the latter being the better option.
Dec 06, 2010 | Panasonic Televison & Video
I have put a scart lead from the av1 socket on the dvd (panasonic) to the cable box vcr connector on the back of the cable v+box and run a hdmi cale from the hdmi socket on the dvd to the hdmi2 socket on...
Ok, first thing first if you have a cable box and a dvd player both been connected with HDMI cables direclly to the TV you just need to run a cable from the TV were it says audio out into your receiver.
This way everytime you change from Cable box and DVD the audio automaticly will change as well.
Jul 15, 2009 | Electronics - Others
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
Cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Hook up
well u cannot hook almost any devices with the SC-HT500.
I have this homecinema system for 5 years now, and i had to buy another stand alone DivX player to hook it up, but can't get the sound in dolby from the standalone player since the panasonic SC-HT500 has only 2 analog stereo RCA ports (audio in) in the back and a scart (A/V out) and component video (Video out).
At that time it was a very good system, but since i have bought a Full HD LCD tv with 1080p capabilities, I realised that my home cinema system i.e the Panasonic SC-HT500 is kind of useless, in the sense that you cannot even change the player for another one since the whole spaker and power connections are made trhough a special cable from the subwoofer. :(
best solution is that put the system back in a corner and get a new system which is not an all-in-one system. Preferrable get home cinema systems that come with a receiver, separate dvd player and speakers and subwoofer hooked to the receiver.
you asked how to hook these devices to your tv,, well the panasonic dvd recorder is better if you connect it via HDMI cable if you can. In the other case, connecting them with a scart cable would be another solution.
Dec 02, 2007 | Panasonic SC-HT500 System
Televison & Video Logo
Top Televison & Video Experts
