Question about LG WM-2077C Front Load Washer
Clunking noise when water is trying to drain
When the water is trying to drain, there is a terrible clunking noise. I have already cleaned the pump filter. The water doesn't appear to be draining, but I did not let it go long as I was afraid of doing further damage.
Hate this machine. Maybe this time I'll just finally kick it to the curb!
  • 489 Answers
You may have something inside the drain pump and the pump fins are just knocking the large debris around.  You will need to disassemble the drain pump to see what's inside it.  This will require a call from a qualified LG technician.
Posted on Sep 29, 2008
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Car won't start and starter is only making clunking noise
You can take out the spark plugs, keep track of your spark plug wire order, try to crank it over see if the engine turns over.
Check voltage on your new battery, some need to charge when new.
check for corrosion on the battery and starter cables.
Sep 29, 2012 | 1991 Saturn SL1
Elna 2800 making noises when flywheel engaged
if the machine is new & it's already making noises, the I'd suggest taking the machine back & getting another
Mar 26, 2012 | Elna Sewing Machines
Hi my asko fron load washing machine model W621 wont drain properly anymore and makes a clunking sound as it tries to spin are u able to tell me what possibly could be wrong with it & if its worth...
Not to worry, please check from the drain hose from beneath and open the hose. Look for dirt inside for clogging into the valve/drain pump. Remove and clean the valve/pump if there is dirt. If not during the spin the valves must open and drain. if not check for the controller section for fault. The clunk noise could be misalignment of the suspension or the damper unit. tighen or replace. Hope you try . Good day
Aug 13, 2010 | Asko W6021 Front Load Washer
Clunking noise from water pump side
I would check the front motor mount, it maybe worn out. It bolts to the engine block and down by the radiator bottom.
May 16, 2010 | 1997 Volkswagen Jetta
Really bad clunking sounds while printing
The commonest cause of blurry print is oscillation of the print head running along the track. This is usually due to contamination of the grease by dust etc. Wipe the track clean and try a print. If the blur has gone, you've found that problem - but you will now need to re-lubricate the track. A light lithium grease is ideal.
If the blur has not gone, the clunking noises might or might not be associated. You now need to take off the printer top cover to have a look at what is going on. To help you with this, download the Service Manual from:
http://www.mediafire.com/?m6ouftizois
Report back what you find.
Jul 03, 2008 | Epson Stylus 830U InkJet Photo Printer
LG WM-2077C Front Load Washer Logo
198 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
