Lg wd-3274rhd washer/dryer
LE error message. Drum is free and rotates easily by hand. Machine produces two distinct sounds - hissing "sssss" (the drum does nothing) and a muted "angry bear" sound, about 20Hz "ghrrrrrrr" (the drum revolves).... then an error message appears.
The sears on-line does not provide ANY sensor for this machine.
I am in Ottawa, Ontario, Canada
  • ntms Jul 31, 2008
    The manual does not show how to open the beast and how to remove the stator, nor the position of the Hall probe. Canadian Sears calls the stator assembly a "motor assembly"- for all you to know - and can deliver it to Ottawa, Ontario, the capital of the country in ... just three weeks. Does anybody know where the detailed pictures are available?
  • the jman Jan 22, 2009
    how do you replace the hall sensor? What is the procedure?
Thanks for this post. My WD3274RHD suddenly developed the exact same problem with the same symptoms as mentioned! Replacing the hall sensor solved it. The part is also available at SearsPartsDirect.com, search for part number as 6501KW2001A.
Posted on Apr 22, 2009
Ntms reports: already fixed. Hall sensor identical with:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1268237&PPStack=1
was purchased and replaced. Please note: removing the rotor from the shaft requires some prying. It is a safe procedure.
Posted on Jul 31, 2008
  • 487 Answers
HI.
LG is a funny machine sometimes. Sometimes even their service manual does not show the parts you need.
In your case you have a motor (stator) problem.
! disconnect from power for 30 min and try again. Sometimes this resets the hall sensor.
According to service manual ( chapter 7)
• The connector in the LEAD WIRE ASSEMBLY is not connected to
the connnector of STATOR ASSEMBLY
Reconnect or repair the connector
• The hall sensor is out of order/defective.
Replace the STATOR ASSEMBLY
If this does not help take of your statot and see if the hall sensor can be clicked off. On the hall sensor is always noted the pat number. This you can try with sears. HERE is your service manual
Error code LE what does it mean
The LE error indicates that the Controller is having trouble communicating with the motor.
The most common cause for this is if something gets wedged in and the drum can't turn freely. Try turning it by hand to make sure it is free. The next most common cause is if someone spins the drum moderately fast with the washer turned off. I.e. if you give it a spin to make sure their isn't a sock stuck to the drum.. To fix this, unplug the machine and turn the drum counterclockwise 4 full rotations followed by 4 rotations clockwise at low speed. Plug it back in and see if that fixes it.
If that's not it, then there is a sensor called the Hall Sensor that could be the problem. I've never had to replace one of these and can't comment further.
GL
May 11, 2014 | LG WM-2277HW Front Load Washer
Wm2016cw
LE errors mean the motor is locking up and cannot turn the drum. If the drum turns freely by hand then it could be https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/406-200-684484-/LG-LE-MOTOR-ERROR-Motor-Stator-overheat-or-connection-error-WM2016CW
If that is not the problem then the motor needs replaced.
Apr 15, 2017 | Washing Machines
Drum starts to move then stops then Le appears and a slight hissing noise from direct drive motor. Looks like intemittant fault
The LE error message means "locked motor error" which means the control is not seeing the motor running.
The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
The sensor can be accessed by removing the rear panel and the rotor assembly. See the image below for help with this. Remember to unplug the washer first.
Make sure the rotor and drum rotate. Anything blocking the tub rotation might trigger an LE code.
Aug 11, 2011 | LG WD-1080FD Front Load Washer
Spinning Motor is overloading
Hi
Thanks for using FixYa. LE error is a communication error between the control board and the motor. In you LG washer the Hall Effect sensor board monitors the direction and speed of the motor and sends this information to the control board. Usually the issue is with this Hall Effect sensor going bad and should be replaced. However, to make sure it’s not a locked motor, try turning the drum with your hand. And, if you feel some resistance while turning the drum or the drum doesn’t move freely then the motor is locked and you’ll need to get it replaced. If it is fine then it is the Sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | LG WM-2277HW Front Load Washer
Where can I get the bolts for the spider ( inner drum )
Hello. Go to Sears Direct, enter your model number and look at the parts diagram for your machine. Find the bolts you need and order them. Joe
Mar 31, 2010 | LG WD-3274RHD Front Load Washer / Dryer
I START MY WASHER AND IT TELLS ME THERE IS A LE ERROR. IT LOOKS LIKE THE DRUM IS NOT SPINNING, JUST SLIGHT MOVEMENT. BY HAND I CAN ROTATE THE DRUM. ????
LE stands for locked motor error..
1 . check the connections to the Coil/Stator at the rear of the unit possible broken wire.
2 . Coil/Stator Assembly is defective hence no drive
Dec 15, 2009 | LG WM-2277HW Front Load Washer
My washer/dryer is leaking water as the drum is filling. Does not matter if it is hot, cold etc. I have already cleaned the filter..... HElp!!!!!
your tub fill tube hose that goes from the bottom of the wash tub to the load size control on the control panel may have a hole in it, its plastic
Aug 24, 2009 | LG WD-3274RHD Front Load Washer / Dryer
LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
Mar 08, 2009 | LG WM-2277HW Front Load Washer
Fe MEANING
It typically means that one of the water valves (that opens and closes to let the appropriate amount of water into the machine) is not functioning properly. It is frequently accompanied by a continuous flow of water into the machine (although with the drain pump also running you won't necessarily see any water building up inside the drum.) I believe the letters actually stand for "Fill Error."
Mar 17, 2008 | LG WD-3274RHD Front Load Washer / Dryer
LG WM1812CW PROBLEM
Just had this same problem on my LG wm1832CW machine. Sensor assembly was replaced and all is well..
Simple and fairly inexpensive to replace.
Oct 28, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
