Question about Philips DECT 2252S Cordless Phone
Philips dect245 searching problem
Phone is still on searching nothing happen if i do registered or unregistered, could some help
  • 15bluebayou Aug 02, 2008
    Tried registering nothing, tried taking out batteries still no good, still searching, think its a dustbin job, pity it was a good phone
  • 71 Answers
1. try to reset handset. try sw reset in the manual .
2. try to clear the base. unplug power cord, press and hold "page " key , and plug the power cord , after 5 to 6 second release page key.
3. Register again.
4. If there is still searching , open the base and handset, to check ,if the antenna is broken or not.
Posted on Jan 21, 2009
I have philips se4502b/17 cordless phone but it remains on searching mode i tried my best to register it but not succeeded
Sorry this comes late, but we just went through this problem with our unit, but I hope this helps someone else out there.
We had the same problem. To fix this, you need to do a few things and hopefully it will work for you.
First, do you have the PIN that came standard on the phone? The standard PIN for these phones is 1234. Go to the advanced settings, and then REGISTER, and put the PIN in and allow it to go through the "registering..." mode. It even may beep and say "unregistered" but don't give up hope, If this happens, unplug the unit from your outlet and wait a few minutes, plug back in, and place the handset on the base. It should then work.
Mar 28, 2011 | Philips SE4502B/17 1-Line Cordless Phone
Unregistered Telstra V580a handsets
same problem here T.T really urgent
Aug 14, 2009 | Lands Phones
The handsets are displaying 'UNREGISTERED' and not working!
UNREGISTERED means the phone has not yet been set up to work with any particular base. I don't have any Phillips phones, so I can't tell you the procedure, but it should be outlined in the owners manual. Look for registering your handsets.
Jul 31, 2009 | Philips Lands Phones
Philips dect 122
Normally , one base can register 4 hanset in EEPROM setting. The model, Maybe you can try press the "page" key, then plug the power cord , after 5 to 6 second , release "page" key. Try to register handset again.
Dec 13, 2008 | Philips DECT 2252S Cordless Phone
Philips CD245 Cordless Twin
just one phone displaying unregistered
Sep 28, 2008 | Philips DECT 2252S Cordless Phone
Unregistered, registering a new base, faillure....
IF YOUR HANDSET WAS WORKING AND THEN STOPPED WITH "UNREGISTERED":
If lowercase unregistered is in main display and a reg. appears under the left soft key:
Press the left soft key below REG. and then press and HOLD the button on the top of the base station until the two indicator lights on top of the base station turn off. Wait until handset signals with beeps and registered. You are done
THIS IS FOR FRESH OUT OF THE BOX REGISTRATION OF UNREGISTERED HANDSET
Press REG Register shall be highlighted.
Scroll to Register. Press Select.
Enter the system PIN (Default: 0000). Use
CLEAR to correct typing errors.
Press ENTER to confirm.
• Your handset starts searching for the base.
Press and HOLD the round button on top of the base unit until the two
indications turn off.
• If registration is successful, the signal icon
Jun 22, 2008 | Philips VOIP8411B/37 IP Phone
Phillips dect2152
If you bought the base and handset together they should already be registered. If not then the instruction manual is downloadable here: MANUAL
The relevant section is on page 16 - here is a copy:
4 handsets can be registered to the base station. A handset
can only be associated with 1 base station.
�� To register another handset
First enter registration mode by unplugging and
plugging back in the power adapter to the
electricity supply.
Handsets registering / unregistering ( )
�� To unregister the handset you use
enter the RC code*
�� To unregister all the handsets (except the handset you are using)
enter the RC code*
Once the menu is selected, enter the RC* code written under the base and press
to confirm.
Warning : If you wish to associate a non-Philips handset to the DECT 211 or DECT 215 base
stations, make sure that these handsets are GAP compliant otherwise they will not operate properly.
*RC code
(Registration
Code) is
written under
the base.
Warning : Once unregistered, the handset is no longer operational.
Please rate my assistance this should be a fixya!
Mar 29, 2008 | Philips DECT 2151 Cordless Phone
Cordless Phone problem- uanble to use!
Solution:
Unplug base unit
Remove both batteries from the phone(s)
wait 60 seconds
Plug in base unit
Replace batteries in phone(s)
Press speaker icon on base usnit for 5 seconds
Press menu
Select adv adv settings
Select registration
Enter 0000 then press ok
should go from waiting, to searching, then to 'welcome'
press ok...
should be up an running!! :-)
Feb 21, 2008 | Philips CD1503B/17 Phone
VOIP321 is unregistered
I had a similar problem. I unregistered the main handset & then when I attempted to re-register it, I had the same issue (handset attempts the registration process & eventually fails). I tried everything including pressing the "Reset" button on the back of the basestation & downloading firmware version 1.0.4.80 (started with 1.0.4.50). Turns out I had to press & hold the "Page" button on the basestation while the handset is attempting the registration process.
This info is in the manual. I know, I should have read the manual first. But at least I'm not alone; the guy at Philips told me to return the product because it must be defective.
It appears that the registration process is a security process/exchange between the basestation & handset. I'm not certain how standard this process is (i.e., whether differing manufactures utilize the same security protocols). If not, it is likely that other manufacturers' handsets cannot talk to the basestation. I mention this because you said you registered the main handset multiple times, so it sounds like you are familiar with the registration process.
Nevertheless, this might help others who decide to spend their weekend pressing the "reg" button a bzillion times, watching it fail as many times, & looking for answers on
Nov 08, 2007 | Philips VOIP3212 IP Wireless Phone
Philips DECT 2252S Cordless Phone Logo
714 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
