Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Cant turn on
How is ram removed and cleaned?
    Scholar:
  • 180 Answers
You mean from a lap top or desk top?
Posted on Jul 31, 2008
Where do i find manual for asus z92m ?
Remove the power supply, remove the battery, remove the RAM and remove the hdd.
Plug in the power supply and press the power button, it should complain as there is no RAM or hdd. Unplug the power supply, replace the hdd and RAM then power it up and press power on.
Jul 29, 2014 | ASUS Z92M Notebook
Acer aspire T180 wont start screen says no signal input computer is beeping cant tell beep code possibly 2 long beeps repeated or just one long beep repeated
Remove the side panel and remove the RAM.
Clean the RAM slot with dry brush or cloth.
Clean the RAM.
Fix the RAM back in the slot.
Close the cover and Start the PC
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 13, 2011 | Acer Aspire™ T180 PC Desktop
It does not switch on. if i on it, the disply only on but nothing is happened. it cant be regoganised by the computer.
Try this Remove the RAM & clean The RAM Slot & Clean RAM also then refit the RAM in the same place it may get Solved. If does not then show it to you System Engineer.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 18, 2011 | Computers & Internet
Moved computer to new location now I cant get it to boot, it shows poer but wont boot
there is some issue with connectivity or ram may be disturbed. For that remove the ram from motherboard and clean and reinsert the ram. Before that you check cables because you are saying someone removed cables on motherboard. plug all cables and try this
Jun 19, 2010 | MSI 865PE Neo2-V Motherboard
I cant get the system booting process.
Reset your bios settings pull cmos cell from motherbord for 10 minutes then put it again it's position .Then pull out ram then refit again it.
then check .
If still issue then Change ram may be your ram has issue.
if after change RAM memory same issue then you have to repair your motherbord.
Also check key bord num lock key if it on and off after satrt computer then it is screen resolution issue.
For that when you power up the computer press F8 key then enter in enable vga mode .
Then change display proeprty settings change scren resolution to 1024*768 then aaply and ok.then check.
Also refix processor and processor fan .
Clean all dust from mtherbord and all parts.
Aug 22, 2009 | EliteGroup NFORCE 570 SLIT-A Motherboard
Switched on pc monitor says no signal? The fans and hard drive are spinning but nothing happens ive tried putting xp disc in but thr drive flashes a couple of times then stops.How can i start my pc or cant...
check the memory card, or the ram?! removed the ram ram from the slot? clean the slot of the ram and clean also the memory card by an eraser?!
check also the video card?!!
Feb 26, 2009 | ASUS P5VD2-MX SE Motherboard
Turn on computer-wouldn't boot
This beeping sound is usually due to the ram, either it is bad or dirty. Get somebody to check it or open the case and remove the ram, clean it with a dry cloth and reseat it back. If you cleaned it and it still is doing the same thing, then the ram may be faulty and will need to be replaced.
Hope you solve this issue.
Thanks for using Fixya,
Lolita
Dec 05, 2008 | HP Compaq Presario 6310US (DA201A#ABA) PC...
Cant get My dell Dimension b110 to boot no display on moniter!
Which Ram u r using ( DDR, DDR2) , and whats the make of u r PC, as per my understanding Ram is not compatible, is old RAM is still working.
Nov 01, 2008 | Dell Dimension™ B110 PC Desktop
No display
try to clean the RAM with an eraser and then put it back on if still no display remove the video card and clean it with an eraser aswell
hope that helps
Sep 15, 2008 | Jetway (MINIQ 860TWIN) Barebone
Turning on computer
ram faulty
if two ram installed remove one and see and then remove other one and replace by the first one you removed and clean ram before reinstalling in slot.
this will solve your problem
Jul 29, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
Alun Cox
