Contrary to the repair manual; you do not need to remove the steering wheel. Remove the bottom dash panel below the steering wheel and then the bottom black steering wheel cover (3 screws). You will see a 1/8 inch hole and pin below the lock set. Put the key lock in the neutral position and push the pin and remove the ignition lock set. Put the new lock set in the neutral position and insert it. Turn it to the off position which resets the lock pin.
