Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Easyshere 5300 used printer to print off 3 photos and have not used it for 3 days now will not work checked connections but no light will come on or the screen will not light up
  • 4 more comments
  • cwfreeman Aug 20, 2008
    When I click on print I get "an error occured while loading your pictures. Error code 1-2067." And I can't go any further.
    I also have the Kodak Easy Share software, but I can't make it look in my desktop pictures file.
  • Anonymous Oct 26, 2008
    kodak easyshare 5300 keeps giving me an error code of 1-2067 every time i try to click "print pictures" from within the home center and then refuses to let me go any further. this printer is currently connected to an XP machine, but also has no drivers for Ubuntu. contacted kodak several times and was told they would provide drivers for Ubuntu, but to date they have failed to come through on their promise. printer does have drivers for all versions of Windows, Mac and UNIX, but no drivers for Linux. Got tired of waiting over two years for the drivers and was forced to have to use it on an XP machine rather than throwing it into the trash, but now it won't let me print pictures.
  • david eagle Dec 25, 2008
    I get the same code of 1-2067 and it will not let load photos to print
  • rasperryred Mar 01, 2009
    I have the same problem. clicking kodak home centre, nothing works message 1-2067 occured while loading pictures
  • LizMM Mar 03, 2009
    Just installed this software. It works fine for 3 users on same PC. Think it may be due to file path to My Pictures. Still working on it.
  • Anonymous Mar 15, 2009
    I have the same problem and I spent 4 hours on the phone with Kodak Tec Support and they are suppose to be researching what is wrong, and calling me back. I will post the results
  • 31 Answers
The error message appears due to a faulty dot net framework installation on the system.
Perform the below mentioned steps in order to fix the issue.
· Uninstall the Dot Net Framework 2.0 from the system from the add/remove programs section in add/remove programs if the OS is XP.
· Else you can also download the Aaron-Stebner's .Net Framework Setup Cleanup Utility from the website: http://www.raymond.cc/blog/archives/2008/12/02/uninstall-microsoft-net-framework -with-aaron-stebner-cleanup-tool/
· On this website, guide the customer click on the Hyperlink [Download .Net Framework Setup Cleanup Utility]
· Save the utility and run it. When given the list of options, choose Dot net framework 2.0.
·Follow the prompts to uninstall the .Net framework 2.0
·Restart the system.
·Download the .Net framework 2.0 from the website:
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5
· When prompted, save the file and then run it. [Don’t try to run the file without saving it; else you would get an error message
Error 0X80131107
Error Code 25015.
·After the installation of the .Net framework 2.0, check the AIO Home Center again.
Best of Luck
Saj
Posted on Nov 05, 2009
I have kodak 5300 printer with two error code 1 -2067 and code 3503 printer will not print off of the computor .It will always come up with code 1 when i try 5300 photo program
Posted on Aug 03, 2008
Kodak 5300 does not print
Here are the steps.
1.Please verify that the ink cartridges are intact and securely inserted into the printhead.
a.Lift the printer access door, then remove the ink cartridges from the printhead
b.Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
c.Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
2.Clean the printhead.
a.Press the Menu button of the printer.
b.Use the down arrow key and go to Clean Printhead.
c.Press OK button then select Deep Clean.
3.Print Demo Page.
Press Photo and Copy buttons at the same time for 2-3 seconds or until the printer starts printing then release the buttons.
If issue persists,the printhead on your printer require replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Sep 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EasyShare 5300- Won't print
I fumbled around a similar problem today. After printing photos you have to convert the printer to print to paper. If there is a green LED on the printer your are in PHOTO mode. Reach into the 4x6 printer and pull back the slide and the LED will go out. Now you can print on paper.
Mar 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 printer problem
I would suggest the following :
1) Remove the Kodak printer and all its software.
2) Disconnect the USB cable from the computer.
3) Reinstall the entire software applications for the printer just as if you were installing it for the first time.
4) When asked to connect the printer .. Use a different USB port .. even if you have to switch something out .. but do this step irregardless.
Now what I want to know is ..
1) Can you print from the computer?
2) Black still "gone" ?
Let me know
Feb 01, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 Series not a year old
try to do this first, try first to upgrade the firmware of your printer, by clicking help in your kodak AIO Home Center, then under General Links, click on maintenance, then under maintenance, click on firmware upgrade.
after the upgrade is complete, try to remove and then reseat both the ink cartridges. then calibrate your printer. and then clean the printhead deep clean. then print a demo page to see if there is any improvement in your printout.
but if your still experiencing the same problem
you can call to Technical Support of kodak 1-800-421-6699 7am to 12am ET
hope this will help
Sep 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Very light printing
Call Kodak and tell them you're problems. I was in same boat with new cartridges and still problems. My printer was only 9 month old and printed over 600 pages. I received my new printhead along with brand new cartridges and sample of 4x6 photo paper. However, having problems removing the printhead. New printhead came within 1 business day of calling Kodak!
Sep 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
5300 kodak printer
My solution was to dump the Kodak printer, and reinstall a 4 year old HP printer collecting desk in my house. WORKS GREAT! I fiddled around with the Kodak printer head and wiped/cleaned the insides, and it worked for a couple days. Then it started having the same problems again (see above.)
Apr 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Photo paper
1. Never put XtraLife paper from a printer dock in any inkjet printer. This paper is not made for inkjets. The ink will simply spill all over the place.
2. You can use any paper you wish that is inkjet paper but you must set the appropriate settings through the print manager if the paper is anything but Kodak inkjet photo paper. The 5100, 5300, and 5500 all recognize the backprint on the Kodak paper and automatically optimize the settings. Other brands of paper are not optimized in this fashion and therefore must be done manually through the print manager or software.
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Massage unsupport ink on lexmark X4270
Sadly, not all inks are created equal, and even inks that are claimed "compatable" are not allways safe. My HP photo printer worked great for 2 years, then I put in a "will fit" from a name brand office supply store, the printer nozzles plugged on the second print, never to print correctly again. My replacement printer is a Kodak 5300 all in one, chosen for low ink costs/ hi-output, and I get photo-lab quality, borderless prints day after day. (I'm a photographer/artist) I have run 6 color and 5 blacks for thousands of graphics, in a period of 2 months getting ready for a showing, with maybe 1 or 2 misprints.
Nov 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
533 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
