I'm not sure about setting up Linksys WRT54G2 Broadband Router in conjuction with desktop Sony Windows XP. I have a HP Pavillion dv6700 notebookWindows Vista) to configure the router so I can use it wireless within my home. I have tried by can not get it connected. The problem comes in when they say connect the blue ethernet cord to the pc(should this be going to the desktop or the notebook. There is only a data cable(green) and ethernet cable(yellow) that came with the router. There is no blue ethernet cable to connect the pc to the router as instructed.
I would also like to know what would be needed to use mu notebook anywhere.
the cable should go to any of the pc's u wish to configure the router with,then all you have to do is configure the router via internet explorer,just type 192.168.1.1 in your adress bar and use admistrator for both password and username(these are the defaults) the pc that u wish to set the router up must be set to dhcp(this is done by going to network connection settings selecting properties then where it says internet protocol(tcp/ip)
select properties and select obtain an IP address automatically(this will make router give you an ip adress)
What is the best NAS for about $300 (+, - $100)? I was looking at...
(More)
What is the best NAS for about $300 (+, - $100)? I was looking at http://www.bhphotovideo.com/c/product/629822-REG/Buffalo_LS_XH2_0TL_2TB_LinkStation_Pro_LS_XHL.html,I need 2 TB of space, about 40 MegaBytesPerSecond, bittorrent, dlna , and web (configuration) access.
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send
Machinery until you...
(More)
Machinery until you return to Dsna coude reset sharp ar-5316
My pro multi panel does not work in fs2004. Its lights up but none of the buttons or dials do...
(More)
My pro multi panel does not work in fs2004. Its lights up but none of the buttons or dials do anything either on the panel or in fs2004.
The electricity went out for about 2 hours. When it came back on, the computer would not turn on. ...
(More)
The electricity went out for about 2 hours. When it came back on, the computer would not turn on. No lights, no beeps, just dead. My router runs through that computer, and it is still working. Is it possible that it could be the power supply? I am hoping it is that simple. Thank you!
