Question about Canon imageCLASS D680 Laser Printer
Screen is black
The screen does not light up anymore. Unless you know excatly what you are doing you can't tell what you have just set the copier to do. Is there any easy way to replace the screen and is the parts available.
    Guru:
  • 1,049 Answers
  • NA NA
    NA NA Jul 31, 2008
    Did you find what your looking for?
Is there a way for me to set my copier to default print black and white? I know this can be managed by each PC but sometime folks forget so i would like to deafult all print jobs to B/W unless otherwise...
TO SET THE MACHINE FOR BLACK AND WHITE ALLL YOU NEED TO DO IS SELECT BLACK ON THE COPIER PRESS THE UTILITY USER KEY THEN PRESS COPIER BUTTON DEFAULT BUTTON THEN SELECT CUREENT SETTING
THIS WILL DEFAULT THE MACHINE TO COPY IN BLACK TO SET PRINTING IN BLACK YOU CAN SET UP THE DRIVER TO PRINT IN BLACK ONLY
Jun 03, 2011 | Konica Minolta Bizhub 222 Black and White...
CANNOT PRINT WITH COLORED
I would suggest going into your printer settings and adjusting the color printed to grayscale (black ink only). I cannot tell you how to get there unless I know your operating system, but if it is Windows 7, go to the start menu, click on devices and printers, right click on your default printer (which will have a green check mark), choose printing preferences, then under printer features select black ink only from the dropdown list.
May 27, 2011 | Brother Office Equipment & Supplies
I have a HP Laserjet 3500. I onlt want to print in black, and i have black toner. However i don't have anymore yellow toner. How do i set the printer to only print in black?
You can't print anything unless all your toners are in the printer and NONE of them are empty.
I understand what you are trying to do, but it won't work.
Dec 06, 2010 | HP Color LaserJet 3500 Printer
If I open the screen anymore than about 45 degrees, the light on the screen will shut off. The screen is still on, as is the laptop itself. I can tell because at a certain angle I can still see what I'm...
You problem most likely the video/power cable from the motherboard to the LCD screen/inverter. The inverter supplies high voltage to the CCFL lamp that provides the back-light.
This cable may only need reseating the connector on the motherboard or the cable is broken and needs replacing.
Parts are available on the Internet, try this WEB site :-
www.lcdparts.net
Sep 10, 2010 | Computers & Internet
DIM BACKLIGHT TOSHIBA L305D-S5924 LAPTOP
There are also another reason , the Back light lamp might be damaged also!
May 11, 2010 | Toshiba Satellite L305D-S5895 Notebook
My printer stopped printing COLOR
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. Perform a head cleaning If there are still gaps in the dot pattern, continue with another cycle. Perform up to 6 cycles if necessary.
Feb 04, 2009 | Lexmark Z640 InkJet Printer
Set for copier to make balck ink copies no color
on the lcd screen upper leftarea touch the area where it says auto color then set it to black. then touch add function copy settings scroll to the one that says standard setting it will ask you if you want to set the setting then set it in . the default screen now should stay in black
Jan 30, 2009 | Canon imageRUNNER C3170I Color Copier
Display doesn't work
LCD Ribbon Connector may have become dislodged or in partially disconnected somehow. You have to open up the case and reconnect the lcd.
Jul 03, 2008 | HP Jornada 720 Pocket PC
No color on xbox
i am having EXCATLY the same propblem except its color on my pc but on everyother tv ive tried its black and white except one but i dont know why
Dec 29, 2006 | Microsoft Xbox 360 Console
Canon imageCLASS D680 Laser Printer Logo
old marine
old marine
