Question about Indesit Washing Machines
Indesit WIE127 Washing machine which flashes error code F08 when it goes to spin. Can this be fixed. What do I need to do to mend it?
    Problem Solver:
  • 8 Answers
I HAVE THE FAULT CODES FOR SOME INDESIT MACHINES THEY ARE ONLY SUPPLIED TO THEIR ENGINEERS BUT A MATE OF MINE WORKED FOR INDESIT/HOTPOINT (ONE COMPANY NOW) UP UNTIL A MONTH AGO , HOWEVER ,THEY ARE AT WORK & I WONT BE IN UNTIL FRIDAY IF YOU CAN HANG FIRE UNTIL THEN I MIGHT JUST BE ABLE TO HELP YOU OUT!
Posted on Jul 30, 2008
Start machine and let's water in for few seconds then makes screeching noise and stops code F08 on display any ideas to what may be problem
Indesit or Hotpoint washing machine flashing 8 times or displaying error code F08 usually indicate "Heater relay can't be activated" or "heater relay stuck".
The heater relay on these machines (as at time of writing) is on the pcb, the main control board at the back of the machine. Sometimes they can get jammed, and freed with a gentle tap. Other causes of this fault listed are "check pressure switch, heater & module connections". Therefore this isn't an easy diy fix and if you don't know what a relay is or looks like it's best to get in an engineer for this fault.
Some descriptions on various models also still say "heater relay", or "heater relay can't be activated", or "heater relay stuck", but also add, "check pressure switch connections for heater, wiring and module connections".
May 06, 2015 | CDA Washing Machines
Indesit 1200 spin wie127 what does the error code f-08 mean.
helo sir
F08 means Wash Heater Relay Stuck (signalled in presence of empty) or pressure switch
stuck on Full (simultaneously empty and full)
• Check the efficiency of J3 connector contact on the card
• Check pressure switch status checking J3 wiring connector pins 2 and 4
ohm continuity (it must only be present with tub empty) and pins 2 and 3
ohm continuity (it must only be present with water in the drum) and pins 2
and 1 ohm continuity (it must only be present with water in the tub above
normal level, at least halfway up door glass).
• Check wiring J3/pressure switch
• Check connection of heating element J3 connector pins 5 and 6.
• Replace pressure switch
• Replace Card
Jul 12, 2008 | Indesit Washing Machines
Indesit WIE127 is blinking
it needs resseting have you got the hand book as it will tell you how to if not let me know and i will look though mine and tell you how
Dec 07, 2011 | Indesit Washing Machines
Hi I have a hotpoint wf630 washing machine and it keeps flashing error codes f08. Could you tell me what this codes means. many thanks, Stuart
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items.
REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
John C
Mar 09, 2011 | Washing Machines
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
Fault code h20 flashing on indisit wie127 washing machine
H20 is indicating a problem with the incoming water supply to washer.
Check the inlet hose/s for kinks or other restriction, ensure that you have a good pressure to the washer, make sure tap/s are fully turned on.
If all o/k,then could be a problem with the inlet valve/s
Please rate my solution.
Thankyou.
Jan 21, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit w127 error code f-08
Error F08 is indicating that the heater relay is stuck or cannot be activated or the contact has welded in the relay.
The only thing u can do yourself, is to check that the heater is o/k, if u can determine that it is , then u have no option other thancalling an engineer.out.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Indesit W 123 Front Load Washer
F08 keeps flashing
probably heater relay cannot be actived, you will need an engineer.
Nov 18, 2008 | Indesit WA 125 Front Load Washer
Washing Machines Logo
1,013 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
