Question about Intermec CN3
No signal and gprs
At the top of the screen i tap on phone and it says no service, and next to that connectivity theres an x just under the 2 arrows and i know that my signal is good coz i have the same mobile provider on my other phone. please help! many thnx
1. open the battery case and unscrew the flap beneath. Verify your SIM card is properly seated.
2. At the bottom right corner of the "today" screen is the iConnect icon. Click it and verify "Phone" is checked under the "Enable" menu.
3. open the "Start" menu and navigate to Settings->WanInfo. What information is displayed in that program?
Posted on Aug 13, 2008
Internet crashes my htc Smart... Help?
The first time you use your device, the Connection Setup displays a notification message to inform you that it will automatically configure your device's data connections, such as 3G/GPRS/EDGE, WAP, and MMS.
  1. On the notification message, select Yes.
  2. If your SIM card supports multiple network operator profiles, the next message displays all network profile choices. Select the profile you want to use, then select OK. The Connection Setup configures your device's data connection settings.
  3. After the Connection Setup completes configuration, tap Restart. Tip: To choose the network operator manually, select Start > Settings > Connections tab > Connection Setup The GPRS/3G settings are preconfigured on your device when you applied for this service with your wireless network provider. If you need to add another GPRS/3G connection:
  4. Tap Start > Settings > Connections tab> Connections
  5. Under My ISP, tap Add a new modem connection
  6. On the Make New Connection screen, enter a name for the connection, select Cellular Line (GPRS, 3G) on the Select a modem list, then tap Next
  7. Enter the Access point name, then tap Next. You may obtain the access point name from your wireless service provider.
  8. When prompted, enter the user name and password. (Check with your wireless service provider if a user name and password are required to connect.)
  9. Tap Finish
Feb 09, 2012 | HTC Cell Phones
I wannt gprs pc setting but they can't found .
To connect to the internet using GPRS/3G, open the All Programs screen and then tap Settings > Wireless controls > Mobile network settings.
To setup an access point automatically, tap the switch beside the Automatic setup option to turn it on.
To create a new access point, tap Access Point Names. Press the MENU button and then tap New. Enter the access point details and then tap Save.
NOTE 1: An internet connection (GPRS/3G, etc.) is required to access this service. Your operator may charge for using GPRS/3G.
NOTE 2: To open the All Programs screen, please see the FAQ "How do I open the All Programs screen?"
NOTE 3: Contact your mobile operator to get the settings for your carrier, if neededsushafiq_8.jpg
Jul 24, 2011 | HTC F3188 Smartphone
How two use g p r s
If you need to add a GPRS connection to your phone, obtain the access point name and settings (including username and password if required) from your wireless service provider and add these settings to your phone by following next steps: Press HOME > MENU, and tap on Settings. Tap Wireless controls > Mobile network settings > Access Point Names. On the APNs screen, press MENU and then tap New APN. In the Edit access point screen, enter the APN settings. Tap the APN setting item to edit it. Press MENU and then tap Save to save the settings to your phone. This way you will connect using a GPRS connection.
Feb 14, 2011 | HTC Hero Smartphone
I have an i9 phone. I live in Australia and I am with Telstra. GPRS not subscribed keeps coming up when I try and go onto the internet. Need help please
I'm with telstra and used these settings. If you get stuck go to
www.i9forum.co.uk and register then go to the mms & sms section some phone do use a slight variation on this below.
Step 1 – WAP DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS >
Select an empty Account”
2. Edit the following parameters in the account
a. Account Name=Telstra WAP GPRS
b. APN=Telstra.internet
c. User name=[blank]
d. Password=[blank]
e. Auth. Type=Normal
Exit back to MAIN SCREEN.
Step 2 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP > SETTINGS > EDIT
PROFILE > SIM 1 or 2 > Select an empty PROFILE > EDIT PROFILE”
2. EDIT the following parameters in the account
a. Rename Profile=Telstra WAP
b. Homepage=http://wap.telstra.com/wap
c. Data Account=Telstra WAP GPRS
d. Connection Type=HTTP
Proxy Address = 010.001.001.181
Proxy Port = 80
e. User Name=[blank]
f. Password=[blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – MMS DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select
an empty Account”
a. Account Name=Telstra MMS GPRS
d. Password=[blank]
3. Exit back to MAIN SCREEN.
Step 4 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMS SETTINGS >
SERVER PROFILE > SIM 1 or 2 > Select an empty Account”
a. Rename Profile=Telstra MMS
b. Homepage=http://mmsc.telstra.com:8002
c. Data Account=Telstra MMS GPRS
Proxy Address = 010.001.001.180
Proxy Port = 80
f. Password=[blank]
Feb 12, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
How can i use jasjam as a modem
Thank you for visiting Fixya Forums
Using a Jazjam as a modem:
Notes
• Before activating Wireless Modem, make sure your device has a
SIM card installed, and you have set up a GPRS or phone dial-up
modem connection on your device. For more information about
setting up a GPRS connection, see "To set up a GPRS connection to
the Internet". For more information about setting up a phone dial-up
connection, see "To set up a dial-up connection to your ISP".
Also make sure you have connected your device to a computer (via
infrared, USB or Bluetooth).
• When you activate Wireless Modem, ActiveSync will be disabled
automatically.
To set up your device as an infrared or USB modem
1. On your device, tap Start > Programs > Wireless Modem.
2. In the Connection Type list, select how your device is connected
to the computer: IrDA if via infrared, or USB if through USB cable
connection.
3. To use your device as a GPRS modem, set the GPRS Access
point name. To do so, tap Menu > APN Setting and enter the
access point name.
4. Point your device at the infrared port of your notebook, or plug in
the USB cable adapter between your device and the notebook.
5. Tap Menu > Start.
6. The next thing to do is to add your device as an infrared or USB
modem onto your notebook.
To add your device as an infrared modem to your notebook
1. After you tap Menu > Start on the Wireless Modem screen
of your device, the Found New Hardware dialog box will then
appear on your notebook and will show that your device has been
detected as an infrared modem. In this dialog box, make sure that
Install the software automatically (Recommended) is selected
then click Next.
2. Wait for Windows to finish installing the infrared modem, then
click Finish.
3. You can now connect your computer to the Internet. Follow the
steps in “To dial up and connect to the Internet.”
To add your device as a USB modem to your computer
1. After you tap Menu > Start on the Wireless Modem screen of
your device, your computer will automatically detect that your
device has been connected. The Found New Hardware dialog
box will then appear on your computer.
2. In the Found New Hardware dialog box, select Install from a list
or specific location (Advanced) and click Next.
3. Select Search for the best drivers in these locations.
4. Insert the Getting Started Disc into your CD drive. Select the
Include this location in the search check box. Click Browse
and choose the CD drive and root folder where the modem driver
is located, then click Next.
5. Wait for the installation to complete, then click Finish.
6. Click Start > Settings > Control Panel.
7. Double-click Phone and Modem Options.
8. Click the Modems tab. Select the new modem from the Modem
list, then click OK.
Getting Connected
9. You can now connect your computer to the Internet. Follow the
Once the computer recognizes your device as a modem, you can now
use the computer to dial up and connect to the Internet.
1. On your computer, click Start > Settings > Control Panel.
2. Double-click Network Connections.
3. Click File > New Connection.
4. In the New Connection Wizard, click Next.
5. Click Connect to the Internet then click Next.
6. Select Set up my connection manually then click Next.
7. Select Connect using a dial-up modem then click Next.
8. Select the infrared, USB or Bluetooth modem that you previously
installed, then click Next.
9. Enter a descriptive name for this connection, then click Next.
10. If you are connecting to the Internet via GPRS, enter the
telephone number as *99#. Otherwise, enter your ISP‘s dial-up
phone number, then click Next.
11. Under Internet Account Information, you may not need to
enter a user name and password when using GPRS. Just click
Next to proceed.
12. Click Finish to exit the wizard.
13. The Connect dialog box then opens. Click Dial to dial up and
To end the modem session
• On the Wireless Modem screen, tap Done or tap Menu > Stop.
(Please give me a big thumbs up when you rate my answer, thanks.)
Jan 28, 2010 | i-mate JasJam Smartphone
Air tel GPRS setting for HTC P3452
Click Start >> Settings, go to connections tab, tap on connections and click on Add new Modem connection, enter the name of connection as airtelgprs, in the select a modem, select Cellular Line (GPRS) and tap Next. In the Access Point name type airtelgprs.com and tap next. Leave everything blank in the next screen and ckick on Finish. Restart the phone and the settings would be saved.
Sep 29, 2009 | HTC Touch P3450 Smartphone
GPRS not subscribed? T-mobile help?
must follow exactly for full help topics i offer a cd with all settings for every provider along with hundreds of java games wallpapers and mp3 ringtones. if interested submit 10 us dollars to digitalunderground23@yahoo.com. will send as soon as payment is eceived in padded envelope first class mail. SMS Messaging: 1.) From the main screen tap the SMS Text icon. 2.) Tap SMS on the Messages menu. 3.) Tap SMS settings on the SMS menu. 4.) Tap either SIM1 or SIM2 on the SMS settings menu, whichever SIM you are setting up at this time for SMS messaging. 5.) Tap Profile settings on the SIM1(2) message settings menu. 6.) Tap on any unused profile to select it, then tap the Edit button on the bottom of the screen. 7.) You should be on the Profile name menu with the name field already highlighted. Go ahead and tap the Edit button at the bottom of the screen. 8.) Tap in the following text between the quotes in the Profile name editor: ?T-Mobile? Next tap the Options button at the bottom of the screen. Next tap the Done button. You should be back on the Profile name menu with the new name. 9.) Tap the area below the profile name. The top of the menu should change to read SC address and the bottom of the screen should show a numeral keyboard. Tap in the following text between the quotes in the SC address editor: ?+12063130004? Next tap the OK button at the bottom of the screen. 10.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. You are done setting up SMS messaging for T-Mobile. You can continue to tap the Back button on the bottom of the screen until you exit out of all the menus to the main screen, or simply press the On/Off button once to get back to the main screen. At this point you can test SMS messaging by sending yourself a text message, or continue with other setup of the phone. The next sections will show you how to set up MMS messaging as well as an internet connection if you are paying for T-Mobile?s internet access services. One note about internet services, as a T-Mobileweb customer you can get full access to anywhere on the internet if you install & use a Java based web browser such as Opera Mini instead of the internal browser of the phone, and as of this writing you don?t need to be on their much more expensive internet plan, the simple $5.99 T-MobileWeb plan will work! You can get Opera Mini here => MASTER Download List Our next step will be to set up the data connections you will need to use. If you are not going to use the internet or will only be accessing T-Mobile?s T-Zones, then you only need to set up the first data account service we will name T-Mo MMS, otherwise if you want to access the full experience of the internet, please set up both data account service connections outlined in the next section. Don?t worry if at any time you exit from one of the menus and find yourself back at the slidelock screen, simply just slide unlock the phone and continue from where you last left off! Data Account Services: 1.) Setting up regular data account services for MMS & T-Zones access. 2.) From the main screen tap the Service icon. 3.) Tap Data account on the Services menu. 4.) Tap GPRS on the Data account menu. 5.) Choose any of the profiles in the current list and tap the button. 6.) You are now on the Edit screen. 7.) Tap the area just below Account name, then tap Edit at the bottom of the screen. 8.) Tap in the following text between the quotes ?T-Mo MMS? Tap the Options button at the bottom of the screen. Tap the Done button. 9.) Tap the area just below APN, then tap the Edit button at the bottom of the screen. 10.) Tap in the following text between the quotes ?wap.voicestream.com? Tap the Options button at the bottom of the screen. Tap the Done button. 11.) Both the User name & Password areas should remain BLANK. If they are not blank, then tap on each one and Clear what is in them so they are both blank. 12.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the arrows to move the selection so it has Secure, then tap Done. 13.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 14.) Tap Back button on the bottom of the screen. Tap Back button again on the bottom of the screen. You should now be on the Services menu. 15.) Tap WAP on the Services menu. 16.) Tap Settings on the Internet services menu. 17.) Tap Edit profile on the Settings menu. 18.) Tap either SIM1 or SIM2 on the Edit profile menu, which ever SIM you are setting up at this time for MMS messaging. 19.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but profile 8 is usually the first not already filled. 20.) Tap on Profile 8. Tap Edit profile. 21.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen. 22.) Clear the current text, then tap in the following text between the quotes ?T-Zones? Tap the Options button at the bottom of the screen. Tap the Done button. 23.) Tap the area below Homepage, then tap on the Edit button at the bottom of the screen. 24.) Clear the current text except for ?HTTP://?, then tap in the following text between the quotes after the HTTP:// ?wap.myvoicestream.com? Tap the Options button at the bottom of the screen. Tap the Done button. 25.) Tap the area below Data account, then tap Select at the bottom of the screen. 26.) Tap GPRS on the Data account menu. 27.) Scroll down the list until you come to T-Mo MMS, the data account set up earlier under the Data Account Services section. Tap on T-Mo MMS to select it. 28.) Tap the area below Connection type, then tap Select at the bottom of the screen. 29.) Tap on HTTP, then tap on OK at the bottom of the screen. 30.) Tap the area below Proxy address, use the numeric keyboard at the bottom of the screen to tap in the following numbers, ?216155165050?. The result should look like 216.155.165.050 under Proxy address. 31.) Tap the area below Proxy port, use the numeric keyboard again to tap in the following numbers ?8080? to replace the current 0 value. 32.) Tap the OK button on the bottom of the screen. 33.) The areas under both User name & Password should remain BLANK. If they are not blank, select each, and Edit them by clearing all text. 34.) Next tap the Done button at the bottom of the screen. 35.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 36.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken back to the Select profile screen where a big green check mark will be beside the newly saved T-Zones profile. 37.) Tap the On/Off button once to exit to the main screen. 38.) If you ONLY want MMS and T-Zones access without the full internet connection, you can now skip down to the MMS Messaging section and continue setting up MMS messaging; otherwise continue below at step 39 to set up a second data account service which will be used for your internet connection. 39.) Setting up a 2nd data account service for full internet access. 40.) Tap the Service icon on the main menu. 41.) Tap Data account on the Services menu. 42.) Tap GPRS on the Data account menu. 43.) Choose any of the profiles, other than T-Mo MMS, in the current list and tap the button. The profile right under it would be fine. 44.) You are now on the Edit screen. 45.) Tap the area just below Account name, then tap Edit at the bottom of the screen. 46.) Tap in the following text between the quotes ?T-Mo Internet? Tap the Options button at the bottom of the screen. Tap the Done button. 47.) Tap the area just below APN, then tap the Edit button at the bottom of the screen. 48.) Tap in the following text between the quotes ?epc.tmobile.com? Tap the Options button at the bottom of the screen. Tap the Done button. 49.) Both the User name & Password areas should remain BLANK. If they are not blank, then tap on each one and Clear what is in them so they are both blank. 50.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the arrows to move the selection so it has Secure, then tap Done. 51.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 52.) Now that you have set up a second account service for internet use we can adjust the WAP settings for T-Zone to use this faster and less restricted internet gateway. 53.) Tap the On/Off button once to return to the main menu. 54.) Tap the Service icon on the main menu. 55.) Tap WAP on the Services menu. 56.) Tap Settings on the Internet services menu. 57.) Tap Edit profile on the Settings menu. 58.) Tap either SIM1 or SIM2 on the Edit profile menu, whichever SIM you are setting up at this time for SMS messaging. 59.) Tap T-Zones on the Select profile menu. 60.) Tap Edit profile on the T-Zones menu. 61.) Tap the area below Data account on the Edit profile menu, then tap the Select button at the bottom of the screen. 62.) Tap GPRS on the Data account menu. 63.) Find and tap on T-Mo Internet on the Data account menu. 64.) Tap the Done button on the bottom of the Edit profile menu. 65.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 66.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken back to the Select profile screen where a big green check mark will be beside the newly saved T-Zones profile. 67.) Tap the On/Off button once to exit to the main screen. 68.) Continue below with setting up MMS messaging. MMS Messaging: 1.) From the main screen tap the SMS Text icon. 2.) Tap MMS on the Messages menu. 3.) Tap MMS settings on the MMS menu. 4.) Tap Server profile on the MMS settings menu. 5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up at this time for MMS messaging. 6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but profile 8 is usually the first not already filled. 7.) Tap on Profile 8. Tap Edit profile. 8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen. 9.) Clear the current text, then tap in the following text between the quotes ?T-Mo MMS? Tap the Options button at the bottom of the screen. Tap the Done button. 10.) Tap the area below Homepage, then tap on the Edit button at the bottom of the screen. 11.) Clear the current text except for ?HTTP://?, then tap in the following text between the quotes after the HTTP:// ?216.155.174.84/servlets/mms? Tap the Options button at the bottom of the screen. Tap the Done button. 12.) Tap the area below Data account, then tap Select at the bottom of the screen. 13.) Tap GPRS on the Data account menu. 14.) Scroll down the list until you come to T-Mo MMS, the data account set up under the Data Account Services section. Tap on T-Mo MMS to select it. 15.) Tap the area below Connection type, then tap Select at the bottom of the screen. 16.) Tap on HTTP, then tap on OK at the bottom of the screen. 17.) Tap the area below Proxy address, use the numeric keyboard at the bottom of the screen to tap in the following numbers, ?216155165050?. The result should look like 216.155.165.050 under Proxy address. 18.) Tap the area below Proxy port, use the numeric keyboard again to tap in the following numbers ?8080? to replace the current 0 value. Then tap OK. 19.) The areas under both User name & Password should remain BLANK. If they are not blank, select each, and Edit them by clearing all text. 20.) Next tap the Done button at the bottom of the screen. 21.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be taken back to the Select profile screen where a big green check mark will be beside the newly saved T-Mo MMS profile. You are done setting up MMS messaging for T-Mobile. You can continue to tap the Back button on the bottom of the screen until you exit out of all the menus to the main screen, or simply press the On/Off button once to get back to the main screen. At this point you can test MMS messaging by sending yourself a picture message. Internet Access: If all you want to use for internet surfing is the phone?s built-in browser, and you have set up the data account service for the internet in the earlier setup, then you are ready to surf the internet by simply tapping on Service from the main menu. Then tapping on WAP and using the various options to navigate the internet like Homepage, Input address, etc. However, this won?t provide as robust an internet experience as a Java based internet program such as Opera Mini 3.1 or 4.1, or another java based internet browser. If you do decide to install a Java program for browsing the internet, there is one more setting which must be changed prior to using the Java internet browser. Java Internet Settings: 1.) From the main menu tap on the Java icon. 2.) Tap Java settings from the Java menu. 3.) Scroll down and tap the area just below Java SIM1 (SIM2) profile, which ever SIM you are currently setting up. 4.) Use the arrows to scroll the setting until T-Zones appears in the box. 5.) Tap the OK button at the bottom of the screen. Now you should be completely set up for SMS, MMS, as well for internet on the T-Mobile network if you have a T-Mobile internet plan!
May 28, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
AIRTEL GPRS settings for HTC Touch P3452
THIS SHOULD HELP U......
On Windows Mobile 6.x, the steps to configure are as follows:
1. Activate Airtel Live by sending the following SMS to 121: MASALA ACTIVE.
2. The service takes atleast 3-4 hours to get active. Restart the phone and resume configuring.
3. Tap Start -> Settings.
4. Select Connections Tab and tap Connections.
5. Select Advanced Tab, tap Select Networks button to bring up Network Management.
6. Under "Programs that automatically connect to the Internet should connect using:" drop down, tap the New button.
7. In the General Tab, type the name of the settings as Airtel Live
8. Select Modem tab, tap New...
9. Type the name of connection as Airtel Live, select the modem as Cellular Line (GPRS) and tap Next.
10. Type Access Point Name as airtelfun.com and tap next.
11. Leave username, password and domain blank and tap finish.
12. Select Proxy Settings tab. Tap "This network connects to the Internet". This should enable the next check box option.
13. Tap "This network uses a proxy server to connect to the Internet".
14. Type the proxy server as: 100.1.200.99 and then tap Advanced...
15. Tap HTTP, leave the server as 100.1.200.99 and change the port to 8080
16. Similarly tap WAP, Secure WAP and Socks, type the server as 100.1.200.99 but leave the port to defaults. These are optional settings.
17. Tap OK to close the Advanced proxy setup screen.
18. Tap OK to close the New connection screen.
19. The network management screen should now list the new connection you have created in the drop-down. Tap OK to close this screen
20. Tap OK to close the connection screen.
Now you are ready to fire your favourite browser. I have tested this on PIE as well as Opera 9.5 and it works for me.
If PIE reports "Request not authorized by the WAP Gateway", you will need to change the user-agent to anything you can think of using "Advanced Config" tool (thanks to dsixda for suggesting this). I had set it to HTCP3452_Mozilla/4.0 under Advanced Config -> Internet Explorer -> User Agent Custom Base.
I think Airtel has intentionally blocked Mozilla/4.0 user-agent on WM phones. It may be that they cannot restrict Windows Mobile based phones from accessing websites on standard HTTP. On other phones I had tried, I could not get other sites to work with the same settings.
Enjoy Airtel Live for free.
Mar 23, 2009 | HTC Touch P3452 Smartphone
I can not connect my ASUS P320 MTNL GPRS What are SETTINGS for this on my ASUS P320?
I had the same problem in tamil nadu BSNL, all you have to do is put your sim card in another mobile Like Nokia or Motorola, since they are listed with the operators and subscibe for GPRS, once your connection is through, remove the sim and put it back to your ASus PDA, it works fine.
Give it a try
L.S.Sidduram
Mettupalayam, Tamilnadu
sidduram@gmail.com
Mar 02, 2009 | ASUS Computers & Internet
Airtel GPRS ACTIVATE?
Dear friends, before I begin with the details of Airtel Live, I wish to thank everyone at XDA-Developers for working on ROMs, fixes and the support that is being provided here.
Special thanks to dsixda for producing Onyx 3.0 because of which my HTC Touch Elfin (P3452) rocks even more.
Now regarding Airtel Live service: Airtel Live is free GPRS service that Airtel provides to its customer with a catch i.e. as per Airtel, you can only access http://live.airtelworld.com for downloading latest ringtones, games, wallpapers, videos etc.
If you call Airtel Customer Support to get Live on your HTC Touch, they tell you that it is not supported on any Windows Mobile phone and suggest you to go for Airtel Mobile office, full GPRS service for a monthly rental of Rs. 499 (USD 12).
After googling and fighting with Airtel, I managed to get the correct settings and I am able to run Airtel Live as well access most of the websites on standard HTTP protocol (SSL is not supported). Google Maps also works for me.
Apr 19, 2008 | HTC Touch P3450 Smartphone
Computers & Internet Logo
219 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
