Question about Pentax DSmobile Path-Through Scanner
Pentax DSmobile 600 scanner cuts off image
I have a problem with the scanner scanning at any document size other than custom. It scans fine with custom but is scanning a much larger area than I need for receipts. If I set it for something close to the receipt size or use one of the preset sizes, the scan is smaller but it cuts off the left hand side of the document - sometimes significantly.
I am using a Mac Powerbook G4 w/ OS X 10.4.11 and Image Capture as recommended by the scanner site. I have also tried it with GraphicConverter.
Any help would be appreciated.
Doug Eddy dougeddy@arczip.com
  • 3 Answers
Try recalibrating it. If you don't have calibration sheets, buy them at:
Calibration Sheets and Cleaning Kit $2.98 plus shipping.
http://www.opticsplanet.net/pentax-dsmobile-600-calibration-cleaning-kit-206717.html
Posted on Feb 20, 2010
A black line scans the lenght of the page
I have cleaned these by taking an alcohol pad, (one of the small individual square ones) and very carefully, using a paperclip to help apply pressure, wipe the glass scanning surface. After inserting it between the glass and the rubber roller, move the paperclip/alcohol pad back and forth between the two, let dry for a few minutes and try scanning again.
Feb 01, 2011 | Pentax DSmobile Path-Through Scanner
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
I need calibration paper for the DS mobile scanner
Jan 22, 2010 | Pentax DSmobile Path-Through Scanner
How to clean a DSmobile scanner. I am getting
Jan 21, 2010 | Pentax DSmobile Path-Through Scanner
I have a DS Mobile USB Pass through scanner but no CD. I downloaded the drivers but cannot figure out how to get to the calibration tools. I have windows XP service pack 3 installed. Works great if you...
Pentax does not provide the original software for download probably due to licensing restrictions. The TWAIN driver is located here : http://mobilesolutions.brother-usa.com/Support/Software/DSmobile/twain_usb.html
If you use a program like Adobe Photoshop, it will scan and calibrate using the "Import | TWAIN" option.
Apr 17, 2009 | Pentax DSmobile Path-Through Scanner
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Scanning with Canon Pixma MP450
I just did it then! With help from solution posted Feb 08 leave the acual scanner alone can be done from the computer. Steps:
1. Go to - start - control panel - printers & hardware - scanners.
2. Once inside the scanners folder just click once on the scanner icon (mine is called WIA Canon) so it is highlighted.
3. Then click on the toolbar 'File' > 'scan', then select the correct program from the list (mine was MP Navigator 2).
4. Use the MP Navigator program to select "scan photo/document", follow the instructions. At the bottom if the window that is open you can change the document type to PHOTO or DOCUMENT!
This is where the problem lies it is scanning the document as a photo which is why it is coming out as multiple documents.
Feb 06, 2008 | Office Equipment & Supplies
Can not load software for Pentax DSmobile scanner
This solution has helped a lot of people. The cause of the problem has
been known already and is explained clearly how to fix the issue on the
site link below.
'Invalid Drive during installation
Fixing Invalid Drive Error 1327
Sep 22, 2007 | Pentax DSmobile Path-Through Scanner
Pentax DSmobile Path-Through Scanner Logo
556 people viewed this question
Top Pentax Office Equipment & Supplies Experts
Johnny Massengill
Johnny Massengill
Abdul Mannan
Abdul Mannan
Are you a Pentax Office Equipment and Supply Expert? Answer questions, earn points and help others
