The UPS will not stay on. When I plug it in, I hear click on the inside of the system. When I press the red button, it beeps, switches to the red button, then goes off. I tried unplugging it, plugging it in without attachment, holding the on button for several seconds etc. Nothing seems to work. Thanks. Steve
if your model has a mute/test button, please press this for 3 or 4 seconds to stop the beep. The beep usually indicates an approaching power shutdown of the device and allows you to save any files that are currently in use prior to this shutdown.
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
1. Four beeps every 30seconds (On Battery LED will be illuminated) This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power. Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated) This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY) This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing) This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY This alarm indicates that an internal UPS faulthas occurred.
File Format: PDF/Adobe Acrobat - Quick View To turn on the UPS, press and hold the button until you hear the UPS beep ( ..... capabilities of the Powerware 9120 system to provide compatibility with ... lit.powerware.com/ll_download.asp?file=omm91203krev1.pdf
sounds like it is failing. When was the last time you tested its capacity? Test it to see how long the battery works. If it doesnt then get a new one or send it back where you got it.
1) Switch Off the UPS and unplug all Loads (like System, Monitor etc.) from UPS. 2) Switch Off the AC Power (Input Power to UPS). 3) Press the UPS Power Switch constantly unless you hear 2nd BEEP Tone. As soon as you are hearing 2nd BEEP Tone, Release the Power Switch. 4) This is COLD START of all APC UPS that will reset any internal problem. 5) If, however, the problem persists, contact APC.
