Question about Refrigerators
Problem with cooling fan miele fridge freezer KF 888 iDN-1
  • slix2316 Sep 26, 2008
    the fan isn't working in my fridge and it keeps freezing up
  • Anonymous Oct 04, 2008
    same problem
  • 1462 Answers
SOURCE: Refrigerator warm, frost in freezer
take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
Posted on Apr 24, 2007
  • 17 Answers
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Posted on Dec 10, 2007
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
landsend
  • 1066 Answers
SOURCE: haier fridge- freezer fine, fridge not getting
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
  • 10865 Answers
SOURCE: frige light on not cooling,freezer fan working but not freezing
Hello there. Let me see if I can assist you.
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on May 27, 2009
The fan on my Miele fridge freezer is not working, how do I rectify this issue
Check first input power supply of fan if its OK then problems can possible in the fan motor . you can check pre fuse by a tester with continuity method
Jul 21, 2016 | Miele Refrigerators
How do I set the temperature for miele fridge freezer pigeon pair kfn 9753 iD?
Wait for it to cool
while it dies you will see flashing bars
wait
it will cool
Feb 24, 2015 | Miele Refrigerators
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
Miele kf 3855 s-6 fridge part not working. Where is the thermostat?
The PCB is probably the temperature controller and most likely uses electronic temperature sensors in the refrigerator and freezer sections. Not having seen this model before, I'm guessing, but perhaps there is a problem with defrosting such as a clogged defroster drain tube, and the insulation between the freezer and refrigerator is iced up. This could also coat the refrigerator temperature sensor in ice if it is on the divider between the two compartments, thus fooling the controller into thinking the refrigerator is too cold. A manual defrost or drain tube inspection should rule this out.
Jul 16, 2017 | Miele Refrigerators
I have a KFN 9753 fridge-freezer about over 3 years old. The fridge is not cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Miele Refrigerators
The fridge is freezing. This happend after a hot summer and the internal fan was on almost a month. It started to freeze before the fan was put off. Thermostat is my suspect, but I can't understand that it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Miele K8952SDED Refrigerator
My Miele frost free fridge freezer is accumulating ice and water below the two trays in the fridge. What to do, please?
Call Service. 1-800-999-1360 (US) or the Canadian number. Most likely the circulation fan and/or damper flap could be out of whack.
Jul 12, 2010 | Miele Refrigerators
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
