Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 50PP9202 No Sound/Picture
I just replaced the two IC (STK392-120) and 4 resistors that tested open.
Now the unit will power up, in that the red power light will come on and remain steady, but there is no picture or sound.
When I use the remote the power light will blink, but I cannot get the menu to show up.
I checked two fuses labeled 1000 and 1300. Both checked good.
  • Mr_Luther Aug 02, 2008
    Convergence problem. At the top and bottom of the screen the colors were bowed inward toward the center and looked liked you should use 3-D glasses to watch.
  • acedogg Aug 03, 2008
    i got power but no picture nor sound. it only makes a small chirpping sound.
  • 125 Answers
This is a mayor job,
check the screen voltage, the filaments to the crt, the high voltage at least on 1 crt
Posted on Aug 08, 2008
  • Philips Master
  • 3,459 Answers
Its possible that the opto ic went south at the same time you had the convergence problems. This is fairly common for these sets. Check to see if they have a chip kit on www.magnavaoxhelp.com for your model.
Posted on Aug 06, 2008
What where your symptoms before replacing those ic's
Posted on Aug 02, 2008
I have a big magnavox tv that all of a sudden the picture went out with only sound. I tried everything possible from changing cables and calling my cable company to see if the problem was there but no
Your flyback has failed most likely...bad new is they are nearly impossible to find, This is a known issue on most of the models below. The site Tv Repair Kits can sometimes get replacements - but its not often.
This repair kit is known to work on Magnavox TV sets with the following Chassis/Model Numbers.
DPTV305 , DPTV305F , DPTV310 , DPTV315 , DPTV330 , DPTV330F , DPTV335 , DPTV340 , DPTV345, MAG01
Model Numbers
( 43PP9202/17 43PP920217 43PP9202/17F 43PP9202/84 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920201 50PP920217 50PP920284 50PP920284F 50PP920217F 51MP392H/17 51MP3964H/17 51PP9303H/17 51PP9363H17 51PW9303/17F 51PW936317F 55PP9352/17 50PP920217F 51MP392H17 51MP3964H17 51PP9303H17 51PP9363H17 51PW930317F 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F 60PW938317F 43PP9202/17 43PP9202/17F 43PP9202/84 43PP920217 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920217F 51PP9303H/17 51PP9363H17 51PW9303/17F 50PP920201 50PP920217 50PP920284 50PP920284F 51PP9303H17 51PW930317F 51PW936317F 55PP9352/17 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F )
Mar 29, 2012 | Philips Televison & Video
Tip
42PFL7422D/37 Flat Panel LCD TV no picture no sound
I HAVE A 42 INCH PHILIPS MODEL 42PFL7422D/37 TV.
MY PROBLEM IS THAT IT HAS NO PICTURE AND NO SOUND.
THERE IS A GLOWING BACKLIGHTING.
THERE IS A BLUE LIGHT WHEN I TURN POWER ON THE TV. NO CLICKING RELAY SOUND.
MY PROBLEM WAS IN THE SLAVE INVERTER BOARD.
THE IC CHIP WAS BLOWN - SEE PICTURE. THERE IS A BURNED, DARK BROWN MARK ON ONE OF THE CONTACT LEADS ON THE CHIP.
THERE ARE $20 FIX IT KITS THAT YOU CAN BUY ON EBAY TO REPLACE THIS TINY LITTLE CHIP BUT IT'S RECOMMENDED THAT YOU SOLDER VERY CAREFULLY. I TRIED, AND DAMAGED THE BOARD SO I BOUGHT A USED ONE.
REMOVING THE IC CHIP IS PROBABLY BEST DONE WITH A HOT AIR SOLDER GUN. THEY COST ABOUT 50-200 DOLLARS.
AFTER INSTALLATION IT FIRED RIGHT UP.
IN ADDITION TO THE JUST BUYING ANOTHER INVERTER BOARD, I ALSO TESTED THE MASTER INVERTER TRANSFORMERS. ON THE POWER SUPPLY BOARD, I TESTED THE DIODES, AND RESISTORS, AND CHECKED THE FUSE.
AFTER ALL OF THE ABOVE, I UPDATED THE FIRMWARE BY GOING TO THE PHILIPS WEBSITE.
LUCKY FOR MY SITUATION IT WAS NOT THE MASTER INVERTER, MAIN , TCON, POWERSUPPLY, OR DAMAGED BONDING ON THE LCD PANEL ITSELF.
TOTAL COST $50.
GOOD LUCK!!!
on Dec 23, 2011 | Philips Televison & Video
THERE IS NO audio frm my fisher tad-9925.....the ic has just been replaced but still no audio.....cd is playing but cant hear anything
Its a little hard to diagnose over the computer.
I assume there is no sound from the amp EVER.
I assume you have tried other sources.
I assume the unit worked OK until the IC blew.
I assume you replaced the IC yourself?
Often, parts with the IC also fail. There maybe fuses that look just like little resistors along with the IC. They might be blown.
There are parts in the circuit to test if there are speaker problems called power resistors. These will frequently open circuit when the IC Blows - you won't be able to see anything visually.
If your stereo normally makes a 'Click' sound just before the sound comes on, and now there is no click, this indicates the repair of the IC is not complete yet - find the blown part.
Mar 22, 2010 | Fisher 9925 Shelf System
Phillips 52'' projection tv.Picture goes small then large then off
Your original problem was/is an "opto" IC (chip),which causes the power supply to regulate low when it fails. It is a 6 or 8 pin chip. Sounds as if maybe more has failed now. Switch mode power supplies are not for the faint of heart,or DIY. I recommend having it troubleshot by a tech.
May 31, 2009 | Philips 50PP9202 50" Rear Projection...
Philips magnavox 60" rear projection no sound no picture
That could be from
1) Faulty Lamp
2) Vertical/Horizontal Output IC
3) A Shorted IC driver
4) Blown fuse
5) Open resistors around the fuse
Keep all of these in mind and I would test the IC's first with a multimeter,IC's are transistors,usually having 3 legs and screwed into a heat sink,if they read 0 they are shorted. Also if you find something has gone bad,look around the component to see if there is an underlying problem as it will be frustrating and more expensive to find out after the first replacement.
May 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture just sound
This is exactly the answer I would have posted. Look at the expert's rating to determine his reliability.
Use the link provided and replace the kitted ICs and included resistors.
(4) answers from GURU experts is a tad overkill.
The liks provided will give you the step by step instructions to solve your picture problem.
Thanks for using FixYa!!
May 12, 2009 | Philips Televison & Video
Philips 50PP920217F remote/color
Requires convergence amp IC replacement ( two) and check
resistors in vicinity of IC's....fairly technical repair....Please read
some of my convergence solutions and let me know if you want
step by step instructions............................T.
Jan 23, 2008 | Philips 50PP9202 50" Rear Projection...
Blue color warps screen
Blue convergence IC bad....change both IC's and check
current limiting resistors for over-heating.....let me know if
you need more info..........................T.
Oct 21, 2007 | Philips 50PP9202 50" Rear Projection...
Philips 50PP9202 50 in. Rear Projection HDTV-Ready Television?
Hello Anthony14,
This is an indication the the red convergence amplifier has goone bad you will need to replace the convergence correction modules. Now before replacing these you may want to make sure that the bias resistors and the zener diodes are ok. The convergence ICs are part number STK329-110 or STK329-150.
I would suggest that you get a schematic and equipment to make the needed tests, or take the set to a shop to replace the bad components.
I hope this helps,
Thank you,
Shuttle83
Oct 14, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 50pp9202, no picture but sound is fine.
I have the 51 inch of this model and I have found that usually it give you some indication before going completely out. Like color problems, sound, or just video disappearing. Most of the time it will be the convergence amps going bad, but you should have seen some color distortion. If not then it could be the vertical output. TDA8177 needs replacing and check caps around and diode, If not this then look for open fuse in HV line to crt's. Also power supply fuse like 1900, 2004, 1300, etc.
Mar 26, 2007 | Philips 50PP9202 50" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
