Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
GE Profile Harmony Clutch probs./Invertert PCB history
Wish I never purchased these POS machines! But since I own them now, the washer is reading "clutch not mechanically engaging with the basket properly" and "The inverter PCB has a history of not running properly". Now what? Thanks for your help :)
  • mistzyhayes1 Nov 15, 2008
    The clutch is not mechanically engaging with the basket properly...someone please help
  • 725 Answers
Your inverter board is operating 7 degrees over the max temp...
Clear this error be exiting the service mode and run set up ...
if it comes back you will need to replace inverter board....
let me know if you need more help...
Posted on Sep 13, 2008
It reads error is reading or writing improperly, replace main PCB
disconnect washer from dryer and unplug washer for a few seconds. plug it back in and you should get the congrats screen,don't hit the ok button hit start/stop button and power button at the same time. it should bring you back to your home screen.
Sep 23, 2013 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Have a message on GE Profile Harmony washer that say " a problem has been detected with the unit" help?
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Jan 15, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
GE Profil washer will not turn on. There is
unplug it from the wall for 1 min plug back in and this will reboot the pcb controller
Sep 01, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
My ge profile harmony will not spin and drain
I AM NOT A MECHANIC (THOUGH I WISH I WERE), BUT IT SOUND LIKE YOUR BELT OR MOTOR COUPLING. I DON'T WANT TO TELL YOU WRONG. I AM NEW AT THIS STUFF. I HAVE BEEN AROUND WASHERS ALL MY LIFE TO KNOW WHEN THEY BREAK DOWN AND NEED TO BE REPAIRED, BUT MY DAD (WHO DIED IN 2006), SPENT MOST OF HIS LIFE REPAIRING MINOR PROBLEMS ON WASHERS. GOOD LUCK.
RODNEY
Apr 29, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony 4.0 -Broken Clutch Coupling
if your under warrenty always call for service repairing it yourself voids your warrenty
Jan 15, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
587 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
