FixYa.com
Tags:
RCA G2G Gear 5
Old RCA TV S-Video problem
By kcw573 - usenet poster
I have 1991 RCA TV with an S-Video connection.  I long ago lost the
manual and RCA has not been responsive so I am hoping someone here can
help.  Simply put, when I try to connect the TV and a new DVD player
via S-Video I do not get a picture.  The composite connection works.
I was wondering if there is any sort of trick one must use with these
old sets in order to use the S-Video capabilities.  I've tried two
different cables so I doubt it is a cable issue.  Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 11, 2005
FixYa! (100)
Janice
Janice - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
My brother's RCA TV uses channels 91, 92 and I think 93 for
video inputs. Check those. As someone else mentioned, you may
have to switch between video and s-video in a set-up menu.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
FixYa! (100)
Bray
Bray - usenet poster
Rating: 0%, 0 votes
You might not be able to have connections to the s-video and composite
inputs at the same time.  What channel number or input does the tv need to
be on to show the s-video input?  It can be different than the channel
number/input used for composite.  Hook the dvd player up using compsite
video connection and make sure you don't ahve to turn on the s-video output
on the player.  One of those ideas should help sort it out for you.
Solution #3
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
In article <148ce309.0311100759.33a2d @posting.google.com>, danmark @yahoo.com (Dan Markham) wrote:
you dont have both composite AND svhs cables connected at the same time do
you? Sometimes one takes presidence over the other.
Also some tv's require an audio signal to be present in addition to the
s-video connection to make it work.
Solution #4
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
"I have 1991 RCA TV with an S-Video connection. I long ago lost the
help. Simply put, when I try to connect the TV and a new DVD player via
S-Video I do not get a picture. The composite connection works. I was
wondering if there is any sort of trick one must use with these old sets
in order to use the S-Video capabilities. I've tried two different
cables so I doubt it is a cable issue. Thanks."
You might also check your DVD player's setup menu to see if there is a
option to select the output type.
Solution #5
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
You probably need to change the Input from "Input 1" (which is shared
between Component and Composite) to "S-Video".
- Jordan
Solution #6
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
On Mon, 10 Nov 2003 16:09:41 GMT, Darrel Christenson
Note that if something is conected to the composite input then the
S-video in is disabled.
 . Steve .
Solution #7
Not Rated (0)
Horner
Horner - usenet poster
Rating: 0%, 0 votes
You might try seeing if you can find the manual on line. Also, my
6-year-old RCA receives S-video input on 00 (also used for the 2nd
VCR).
Can you Help with these Monitors problems?
Monitors
22" flatron (W2252TQ)...
I have two problems. I was... Answer This...
Monitors
broken pins in monitor cable
I broke off a pin by accident... Answer This...
Monitors
Dead Monitor
Hi, I bought my parents an HP... Answer This...
RCA G2G Gear 5" TFT Display with /S-Video...
RCA G2G Gear 5" TFT...
Hi, anyone have an idea on how... Answer This...
G2G Gear TDLP-50 TFT Display...
Hello I have been... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
