Question about Elna 2007 Mechanical Sewing Machine
I am trying to thread an Elna Air Electronic SU. Can you give me directions?
SOURCE: Elna SU missing stiches and breaking thread
it sounds like the needle hook timing is out. You need to get the needle in the lowest position and measure the gap from the needle to the hook point on the bobbin shuttle. It should be 1/4". You will need to remove the foot and foot plate to be able to see. I use a 1/4" drill bit as a gauge. If you need to adjust it, you will need to remove the free arm cover to the right of the foot and loosen the 2 allen head screws that hold the drive gear. Adjust the gap, tighten the screws and retry. Usually if the needle catches the thread to early, it will make a bad stitch and the upper thread will break. If it catches to late, it will make thread loops and the machine will skip stitches. Good luck, these are a good machine and worth fixing. Phil
Posted on Nov 13, 2008
rickead1
  • 1998 Answers
SOURCE: I need a manual.
well you could get the manual from this site http://safemanuals.com/user-guide-instructions-owner-manual/ELNA/6005-HEIRLOOM-EDITION-_M but i would go with this one instead its a bit easyier to get http://www.tradebit.com/filedetail.php/26965882-elna-6005-sewing-manual-instruction-manual if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Posted on Dec 15, 2010
Tally Girl
  • 1133 Answers
SOURCE: how to thread the bobin on a elna air electronic
I assume you mean when you wind a bobbin full of thread??
You take the end of thread from your spool through the tension device or an eyelet on top of the machine, then back to the bobbin on the bobbin winder and thread the loose end through a top hole on the bobbin. Click the bobbin in against the stop and press on the pressure foot to start to wind. Hold the top thread for a bit as the bobbin starts to fill and then once it has been covered by a row or two of thread, stop and cut of the loose end from top of the bobbin. Now continue to wind the bobbin until it cuts out as it fills against the stopper. Nudge the thread with a finger tip as it spools onto the bobbin to help get the bobbin filled top and bottom and not just in the middle. (bit like when you coil the garden hose onto the reel, it always wants to go in the middile only and then jams up LOL).
Also a really good idea to place your scissors handle into the top of the thread spool to slow/control it as the thread reels off it. This helps give an even tension on the thread going onto the bobbin which really helps with stitch quality later.
Posted on Mar 03, 2011
Tally Girl
  • 1133 Answers
SOURCE: I have a old Elna
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Posted on Mar 07, 2011
Tally Girl
  • 1133 Answers
SOURCE: how to thread bobbin on Elna SU
if you go to this solution
http://www.fixya.com/support/t1064475-elna_carine_electronic_sewing_machine
you'll see the threading diagram for an Elna SU, threading up is same on all the air electronic Elnas (the SU, TSP, 500, Jubilee and Carinas).
If clicking on the link doesn't work, then just select the text, control C to copy, the paste it into your browser address bar.
Trust this helps.
Posted on Oct 02, 2011
How do i fix a n elna su that will not stop after releasing the foot pedal
I'm guessing this is an Elna air electronic SU? If yes, then the problem is with the diagram inside the right side of the machine where your air control foot pedal tube feeds in. I havent' done this repair myself, I took mine to my favourite sewing machine technician. But if you are technically able, try joining the Yahoo Group called Elna Heirlooms, and then go through the threads there, there's been discussion on this repair before.
Dec 21, 2014 | Elna Sewing Machines
Hello. My 30 year old Elna electronic SU doesn't stop after I release the air pedal, from time to time. I have to tap two or three times on the pedal or simply turn off the machine to make it stop. Then,...
Sounds like the air electronic bellows sensor bit inside the machine is faulting, it can be repaired if you can find an old school Elna technician. Mine would do this too, and I did the same as you, worth putting up with as I love my AE SU machine.
if you are technical yourself and you do want to see if you can repair it, I would suggest joining the Yahoo Group called Elna Heirlooms, the members are very good at sharing knowledge on repairing the Swiss made Elna machines and I'm sure Ive read a thread on this fault.
Jul 04, 2014 | Elna 2007 Mechanical Sewing Machine
Manuel elna su air electronic
I have a manual for the SU Air Electronic if you are still looking? you can email me on tallygirl98 at yahoo dot com and I'll send you a scan
Jun 23, 2014 | Elna 2007 Mechanical Sewing Machine
The needle won't pick up bobbin thread on mu Elna Air Electronic SU
Has this just started after a jam up? As it's usually a symptom of timing being out.
However first check needle is in right way, flat shank to the back and threading is correct including the take up lever.
If no joy then mechanic service time
Apr 18, 2014 | Elna Sewing Machines
How to embroider with elna su electronic
There are a couple of Elna SU models, the Star Series SU is white with a blue top panel. Or the air electronic SU is a white machine and a dozen years newer (80's). Both have a disc elnagraph reader in a flap on top of the machine and sew a range of stitches involving either side to side stitch formation or side to side and forwards and backwards, albiet revolutionary when new but not what modern computerised embroidery machines can produce now. To use, you set stitch width and length dials to zero, then insert the black disc into the elnagraph ensuring you line up the disc with a little finger underneath. There should be a red marking on the disc and the shaft to assist with this. Press down until the disc clicks into place. Now turn stitch length to S for supermatic and width to 4 and sew. You can vary the stitch width to adjust stitch and the AE also has a little dial that elongates or closes up the stitch. Try machine embroidery thread for a silky stitch especially with satin stitch where the thread is close together. Also wing needles can be interesting when using the turkish hem stitch disc.
Dec 29, 2012 | Elna Sewing Machines
I had a zigzag problem with Elna SU Electronic Air, which I fixed with your solution, but some of the unfreeze liquid had gone down the bobbin winder hole and now the outer wheel on the right side wil
is the belt slipping now? You'll probably need to take off the top cover and see if you can clean up the spilt lubricant off the bobbin winder mechanisim and the drive belt on the right of this. The bobbin winder is friction driven, a rubber ring around a plastic barrel and when you click this over to the right the rubber ring drives off the main drive part of the machine.
removing the top panel is a bit tricky because you've got the handle there too, two screws unscrew it, then you need to manouvere the cover upwards and left to get it out of the bobbin feed part then tip it to the back of the machine to give you a view of the inners. You might want to subscribe to the Yahoo group called "Elna Heirlooms" as there's probably a prior thread on this there, lots of Swiss Elna owners who service their own machines, very useful place to visit.
May 15, 2012 | Elna Sewing Machines
How to thread bobbin on Elna SU
Please describe the type of bobbin you have. Is it held inside of a removable metal casing? Or is it a dropin type? Is the sewing machine what is known as a "freearm" which you can put a sleeve or trouserleg over or is it a flatbed type? When I know this I can help you further.(I used to sell sewing machines).
Jun 11, 2009 | Elna Sewing Machines
Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Sep 21, 2008 | Elna 8007
Elna 2007 Mechanical Sewing Machine Logo
32 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
