Question about Canon PIXMA iP90 InkJet Printer
Printing nice but very light
I've not used my IP90 in several months. It would not print - well it would barely print and not in correct colors. I had experienced this on my older i70 and flushed the ink cartridges with alcohol and then did deep cleaning a few times and installed new cartridges. Did the same now on my IP90 and it's printing nicely. The test print looks fine, but the color is just not very rich - it's very light - almost as if it were printing at 50% resolution? I know this printer is capable of beautiful rich, deep color and I'm not getting it. Ideas??
  • 1 more comment
  • glenmoyer Jul 30, 2008
    I just purchased brand new cartridges and installed them after the cleaning. Not old ink but thanks for the help.
    I'm on a Mac OSX 10.4.9 and I've gone into preferences, print & fax, and found the IP90 but the when I go to printer settings thee are no controls like you mention. Nothing shows under 'installable options". Should I be looking elsewhere?
  • glenmoyer Jul 31, 2008
    I've narrowed the problem down to software, not the printer. I printed a document from MS Word and there found the printer setup preferences. I was able to adjust the printer output to 'fine' and the results are perfect.
    The document I was trying to print originally was done in InDesign CS. I went back and tried to print it and again got the less than satisfactory results. On a hunch, I saved one of the pages from this document out of IDCS to a pdf file. When I opened and printed the pdf file, again, perfect results. Clearly then the issue is with the printer settings - or lack thereof within InDesign CS. I've searched and found nothing like those available thru MS Word.
    If anyone here has an idea about the IP90 and InDesign CS feel free to comment, but I think I've solved the problem - except for when I want to print from InDesign - wthich is what most of my publishing work is done in.
  • Canon Master
  • 19,396 Answers
Did you try going into printer settings and checking for printer relotion settings. If the printer is set to a low resolution value or to fast print the color will be dim.
Check also that you are using correct paper type settings.
By the way the IP90 is a basic printer.
Posted on Jul 30, 2008
    Guru:
  • 1,894 Answers
The ink may have become very old. i would suggest you to make a refill again.
  • dewan nafees ahmed Jul 30, 2008
    yes.. as said by ginko i would suggest you to check for the printer settings.
    the default settings will be in text mode. change it to text with image or image
    that may help you.
My Canon iP90 has been working perfectly but now won't work at all. Nothing. Not a bleep. The green light's on and I've done all the utility checks and they're fine. I've tried turning...
Hi.
If you had done utility check and they are fine, had you try printing on a stand alone not using a computer. if you can print on a stand alone, there is no problem on the hardware side of the printer because u were able to print on a stand alone. you can focus now on the software side by uninstalling and re installing the driver of the printer and that should work.
Jun 10, 2011 | Canon PIXMA iP90 Mobile Printer
Color ink not printing, I have replaced the color ink, I have run all "cleaning" programs etc. When I print a page with some color or colors are a very faint gray. Any help ? No codes, flashing lights etc,...
It sounds like you have a severly clogged print head. The nozzles are likely gummed up and need to be cleaned. To do this, you need to inserta new set of OEM cartridges. Run the deep cleaning utiliity a half dozen times and then the alignment utility. This should clear the problem.
You have most likely been using aftermarket/reloaded cartridges with inks that do not meet the manufacturer's specifications. I would take them back to the vendor and ask for either a refund of replacements. If you are going to continue to use these cartridges, I would take out the OEM cartridges, reseal the two openings on the cartridge ( use electrician's tape) so that they can be used to clear the nozzles should they again become clogged with aftermarket ink.
Let me know if this solves your problem.
Mar 04, 2010 | Canon PIXMA iP90 InkJet Printer
Red is printing very light and streaking. The other colors print
1.clean the printer head using printer service utility
2.Buy a new catridge and fix it
note: if you are not use the printer the ink will be dry.so it cant able to print
Feb 12, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
My Cannon iP90 has not been used for about a year. I replaced the ink cartridges, performed a partial and full clean. Printed text is barely readable -- to light printing in black or in color.
The ink dries in the printhead and you need to replace it, QY6-0052-000 runs around $60.00 now, leaving it set is the roughest on these printheads.
Nov 23, 2009 | Canon PIXMA iP90 Mobile Printer
Paper comes out looking a shade darker, almost dirty.
9 out of 10 times this is caused by dirty contacts. It can also be caused by some electrical charge getting to the paper as it goes through the printer or a faulty (weak) power supply board. Your first check should be to remove all of the consumables and clean all metal contacts with an alcohol wipe or similar. Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | HP Color LaserJet 2600n Printer
Black Ink won't print on my Cannon ip90 Printer
Here's the link to the transcript..
http://www.fixya.com/support/c36778-black_ink_print_cannon_ip90_printer
Please post your comments there if you are not able to reconnect to the session with me..
Mar 20, 2009 | Canon PIXMA iP90 Mobile Printer
Scanned pictures are printing with different colors
Are the ink cartridges refilled or compatible? They may be defective.
Are they installed correctly (not in the wrong slots)?
** Note that even if they are replaced it will take SEVERAL pages before the quality returns
Mar 11, 2009 | Canon PIXMA iP90 Mobile Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Printing pictures
i have a kodak g600 printer the transfer light dont come on so i cant transfer to pc what can i do.
Mar 31, 2008 | Kodak Easyshare Printer G600 Thermo...
My ip90 Canon printer only prints in purple
Try selecting an option in the printing properties to print in grayscale or black and white (you usually only have either one or the other). This will utilise ONLY the black cartridge, the color will remain dormant which should make your prints come out in black and white - if not, your black cartridge, or the space between the bottom of the black cartridge and the paper is contaminated with color ink. Good luck!
Sep 07, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 InkJet Printer Logo
237 people viewed this question
old marine
old marine
