Question about Honeywell Programmable Thermostat Heater
Honeywell RTH230B--Air Conditioner won't turn off!
I just installed a new Honeywell RTH230B last night. I programmed it according to the directions and had it set at 71 F for the evening. I woke up in a 59 F apartment. My air conditioner will not turn off when it reaches the correct temperature! What happened? I wasn't exactly sure which cycle rate to put, but I don't think that would cause this problem.
Thank you in advance for any help!
Tanya
5 Suggested Answers
  • 168 Answers
SOURCE: honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Posted on Feb 03, 2008
SOURCE: Honeywell thermostat RTH230B
After several months of calling Honeywell (actually someone in India), I found what seems to be the solution. I think I became such a pest (they had a lot of complains from me in their record) that they put me on hold and called someone at Honeywell Corp. The solution was to "reset the microchip". You do this by holding down the "Mode" button and while holding it down, take the batteries out for a couple of seconds (still holding down the Mode button) and then put the batteries back in and release the Mode button. 10 days have passed and it has been working perfectly. Hope this doesn'f jinx it! Good luck.
Posted on Feb 26, 2008
Destinova
  • 46 Answers
SOURCE: problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
Posted on May 27, 2008
SOURCE: Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Posted on Nov 25, 2008
  • 587 Answers
SOURCE: The thermostat worked correctly for months then
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need
Posted on May 10, 2010
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
My termost set to a/c, the fan auto, blow very well, but when I switch to heat and the fan auto, doesn't work, but if I put fan on work why?
the thermostat says to call for heat buildup in the work if its not cold enough the thermostat won't call for heat and I won't go on but when it gets cold and the thermostat set to the temperature you want or hire someone that doesn't cycle
Oct 12, 2014 | Heating & Cooling
Household steamer not heating at all
Well, first thing, just hook up service water and turn it on so the water heats up. Leave it long enough for water to get hot. If water doesn't get hot like should, then heating unit is malfunctioning. If it is getting hot after a while, you pull the handle trigger and water comes out, you have to wait long enough for the hot water to get to the head/trigger for it to go into the nozzles. If it was working ok before, and you were waiting for the water to heat, then then it should be working fine. Tell me what is happening if you wait for water to heat and get to the nozzles. I'm right here at my computer and we can get this thing going if the heater unit is good. Regards, Rigger.
Oct 07, 2014 | Heating & Cooling
Heat will not blow hot air model #310aavo48090oabjd serial #0205a42429
give name make of unit and set up of system oil/gas ect...
Oct 28, 2012 | Heating & Cooling
White Rogers digital thermostat displayed "lo".
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. After replacing the battery you need to do the reset operation. If you need further assistance please contact us at 1800-284-2925.
Sep 24, 2012 | Heating & Cooling
Flashing re co
Re Co stands for Recovery Mode. That means if you have programed your thermostat to be at say 72° at 5:00 then it should kick on in Recovery Mode several minutes before 5 in order to reach that temperature. This is normal and doesn't indicate that something is wrong, just that your thermostat is trying to reach or recover the programed temperature.
Feb 08, 2008 | Heating & Cooling
Heating & Cooling Logo
325 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
