Question about JBL CREATURE II Computer Speakers
Europe-to-usa power supply problem?
I bought my speakers about 8 months ago, in Europe. Never had a problem using them. I recently moved back to the United States. I plugged in the speakers with an adapter, and hooked everything up. The power-on LED on the subwoofer is lit, but the leds on the satellite speakers are not. There is no sound at all from the speakers. What gives? Is this a problem with the power supply, maybe?
Thanks!
Sarah
  • Anonymous Jul 30, 2008
    same
Hello Sarah, I brought mine in Europe too and found out that they are rated for 220 VAC while in the US you will need a 110 VAC power adapter so if this is your case you need to buy a replacement.
Posted on Sep 08, 2008
Whirlpool electric dryer 220V bought in USA and brought it to Europe Serbia. I was told that USA 220V and Europe 220V is not same. I did not plug it in yet can someone tell me what to do. Thanks
the voltage is approximately the same,the difference is the frequency of incoming power as power delivered in the USA is at 60 Hz. and power in Europe is at 50Hz. so some electronic parts will not operate on this frequency,you might be able to purchase a power/frequency inverter unit but not sure on this,talk to your power provider as they may have the answer to this
Dec 04, 2012 | Whirlpool LER4634J Electric Dryer
Macintosh aoc monitor refresh rate
Europe has different power supply parameters than the USA, Obviously you discovered the voltage difference, hence the transformer, but the USA sends AC voltage at 60 cycles per second while most of Europe is at 50 cycles. You need a converter, not a transformer, if your monitor is capable, you may be able to set it to operate on the different frequency from display settings, or the monitors internal menu
Oct 17, 2012 | Apple Mac Mini Desktop
We have bose 9 speaker system from usa 110v it was my fathers we have brought it back to spain which is 240v can you help ie transformers
Probably every electrical supply store in Europe sells tranformers for American (110V) gear.
Google "240 - 100 transformer Europe"
What's a Bose 9? You mean 901? Before you try to use it get the manual from Bose.com and wrap your head around it's requirement for exclusive use of any amplifier.
Mar 08, 2011 | Bose Wave Radio
What should the input power supply be
The input is USA 110 - 120 Volts AC, Europe, 230 - 250 V AC.
A lot of adapters will work on anything from 90 V AC to 250 V AC, it is clearly indicated on the actual unit itself, if you look. If it is, it can be used anywhere.
Apr 06, 2010 | Maxtor OneTouch III Mini Edition 120GB...
Will a TV made for Europe perform OK in the USA using a step-up transformer ??? Are the channel frequencies the same ??
NOT unless it is a DUAL frequency Standard, as Europe is PAL & SECAM, USA is NTSC. Also the HERTZ is different too 50Hz Europe, 60Hz USA, so really NO. IF it would work, it would have an international power supply, meaning it was usable any where in the world. and also it would have a multi tuner. Otherwise it will NOT go.
Mar 15, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Using a USA bought pc LCD monitor in Europe?
It's correct! Most (!) of the lcd monitor adapters are Auto-ranging, 90 to 265 VAC, Also the 50Hz (Europe) and 60Hz difference isn't a problem anymore for nowadays monitors, even not with build in power supply monitors.
But be sure that it's really capable of autoranging, ask your dealer or check out the specifications on the box or the website of the manufacturer of your choice!
Nov 07, 2009 | HP Pavilion F1703 17" LCD Monitor
Can the garmin 72 gps bought in usa be used in europe and are
GPSs can be used anywhere in the world with the correct maps for you particular area installed. They use the same satellites.
Oct 30, 2009 | Garmin GPS
Best way to use US-Bose SA3 amp in Europe ?
Bose say you should pay to get it converted because over time the slightly different power cycles can effect it, however it will still works fine if you change the voltage with an adapter - like I did!!!
Dec 12, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
RCA DRC8052N DVD Player
Press title then hit 01-It takes you to the first chapter in the movie
Nov 15, 2007 | Televison & Video
JBL CREATURE II Computer Speakers Logo
310 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
