The computer says unable to intialize subsystem please update the driver of your display system
    Scholar:
  • 67 Answers
Reboot the PC and press F8 go into the Safe Mode.
Once your in the Safe Mode reboot out and login normally.
Make sure you don't set the Video Card higher than what the Monitor can handle otherwise you'll see that message.
Posted on Jul 30, 2008
Unable to intialize graphics system when I go to run the game. I'm running on windows 8. what do I need to do?
Its quite an old game, Step one is running it in Compatibility mode. Try xp.
Other then actually getting into the game files and editing what needs to be updated for it to run on Direct X 11, well... Good luck with that.
Apr 09, 2014 | Atari Chris Sawyers Locomotion for Windows
Igxprd32 display driver stop responding is flashed on my computer when i play games on my desktop .what can i do to fix that problem so that i can play games on my desktop
This is a problem with the GM965 chipset display driver. you need to search for the updated display driver for your computer/laptop and then install this to your system.
steps:
  • Right click on 'My Computer' and select 'Properties'
  • In Properties screen, select 'Hardware', and then 'device manager'
  • Look for 'Display Drivers/Adapters', and then look for your display drivers (e.g. Intel(R) GM965 chipset display).
  • Right click on the name of the display driver and choose 'Uninstall'.
  • Reboot your computer.
  • Go to http://www.update.microsoft.com
  • Choose Custom Update option
  • you will see microsoft page checking for updates for your system
  • once it has detected that your display driver is missing or needs to be updated
  • you can click in Hardware link on left side of screen and it will show you the old version of your display driver
  • simply install this one and you are done.
Oct 19, 2010 | Computers & Internet
When i try and install nhl 2006 i get a message 3d acellrator card did not intialize properly and that i should update my drivers
Graphics card may not be on game compatablity list.
Check games specs at Manufactures web site.
Get updates driver from Graphics card maker.
ATI.com + nVidia.com are most common unless Graphics on Motherboard - which in most cases are not updatable.
You may have add a graphics card if graphics on motherboard -check your system specs-
Most major computer manufacturers use ALL IN ONE motherboards to build thier systems - something to be aware of for gaming.
Apr 04, 2010 | ZT Group CISNET A7050 PC Desktop
Computer won't allow sound through the speaker
It is important to note the several components (Both hardware and software) must be properly installed and configured for the Sound Subsystem to work properly. I will attempt to list some of the major areas of concern and hopefully point you in the right direction (I am assuming that your system is less then 3 years old and that you are running Windows XP, much of this will apply to Windows 7 as well).
It is important to note that you should be able to hear sounds from your computer’s speaker – this is where I would begin trouble shooting.
  1. First, ensure that your sound logic is not ‘muted’.
  1. The PC Sound Logic must be properly recognized by the ‘Plug and Play’ Subsystem of the CPU/Mother Board to function correctly.
  1. If the “Sound, Video and Game Controllers” area is empty, then most likely your problem is that your system does not have the correct ‘device drivers’ for the Sound Logic that is installed.
  1. If the Plug and Play Subsystem has properly indentified and installed each of the “Sound, Video and Game Controllers” modules, then test the functionally by going to the
If you do not hear anything and you have confirmed that Mute is not selected and the sound level is high, then:
1. Confirm that you are using the latest device drivers.
2. Go into Device Manager and delete all of the components under the “Sound and Audio Devices” Icon.
3. Reboot your system and allow the Plug and Play Subsystem to rediscover and install each of the sound components.
4. Confirm that all of the Sound components are installed.
5. Retest your Sound Subsystem by using Step #4 above.
If the problem persists, then it is time to suspect the possibility of faulty hardware or a faulty Mother Board.
I hope this helps,
RojoSho
Jan 07, 2010 | Audio Players & Recorders
Display driver problem in windows 7
Go to the Intel Homepage :
Click "Graphics" then select your software in the right-hand pane.
Choose your operating system as "Windows Vista (32 / 64)".
Save the file to your Desktop or to a USB stick.
Install the software onto Windows 7 OS and run the compatibility
program.
Nate P.
Jan 26, 2009 | Microsoft Windows Vista Ultimate Edition
SYSTEM SOFTWARE MISSING!! on display - the maps just needed update - now the 'missing system software' is displayed ,, I thought it was the map updates needed to be updateed so I went to the Garmin website...
I had the same problem with my nuvi 200. I contacted Garmin via phone (toll-free number) and the tech was very helpful. He said that this happened when I was updating because the program was interrupted while the update was in process. The problem is because I needed the USB drivers for updating--don't know how they got deleted but once he sent me an email with the instructions and attached zip file to reinstall the drivers and reset machine, everything is good to go again.
Nov 21, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Audio
try updating your audio driver...insert your driver cd provided- right click on my computer, go to properties, device manager, audio, then again right click on audio codecs and update..!!
Oct 28, 2008 | Microsoft Windows XP Home Edition
Pcl xl error , subsystem:kernel, Error: Illegal tag
Change paper to plain instead of UNSPECIFIED in the printing properties. The printer hates the UNSPECIFIED setting.
Jul 26, 2008 | HP LaserJet 1320n Printer
LG Combo Drive
Try uninstalling the current driver, then applying the updated driver, worst case scenerio is you get the current driver again
Jan 29, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
No post (blank screen) after intial driver install Acer 1716 LCD monitor
Please clarify something for me, after installing drivers, system reboots, and you have no POST information or startup screens at all?
Dec 15, 2007 | ATI RADEON 9550 Graphic Card
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
