Question about Danby DPAC8020 Air Conditioner
We have a Danby A/C unit, model DAC12344D and the unit is quitting and the E1 is flashing. What do we do? Can we get parts for this unit??
  • 231 Answers
E1 is a problem with air filter.
Clean or replace the air filter. Make sure filter is seated properly.
Posted on Jan 03, 2009
What is the problem for E1 and E2 Code
The E1 E2 flashing together (alternately) means that there is a loose sensor wire. The wire may have come loose during transportation to the store. The unit will need to be exchanged at the store where you purchased it or you will need to phone a service depot in your area to have it fixed. Contact our Customer Service Department at 1-800-26-DANBY to locate your nearest service depot.
Hope this helps.
Jul 05, 2011 | Danby Heating & Cooling
E1 CODE ERROR
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 30, 2009 | Danby DDR451 Dehumidifier
My DANBY Dehumidifier model DDR4588EE has been working ok until it showed a E1 error code and since then it does not work properly. Any ideas please?
Dec 30, 2009 | Dehumidifiers
My model DDR6588EE dehumidifier runs for a while and then stops displaying an E1. If I hit power button it will run a while and do the same thing. This also happens on Continuous mode. Is there some thing...
Dec 25, 2009 | Danby DDR6588EE Dehumidifier
I have a Danby Designer 8000BTU ac unit model# DAC8003D. The is a E1 flashing on the screen. How do I solve this?
Their manual says to clean the air filter. Unplug the unit (I suggest for aleast 1 full min.), and then plug back in. This is supposed to reset the unit.
http://www.danby.ca/cms/uploads/products/en_manual/DAC6003D%208003%209003%206300%208503%2010003%2012304.pdf
Check out this web site as it should show the manual for your unit.
good Luck
Jun 20, 2009 | Heating & Cooling
What does P1 mean on display?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
May 16, 2009 | Danby Dehumidifiers
My model is DDR4009EE, after it run for a while, the display changed from RH to "P1",what does "P1" mean?
My Danby DDR657EE shows P1 periodically also. So, I called Danby.
He also described other General Codes (applicable to most Danby Dehumidifier/Humidifier models):
E2 = Not draining
So, if you see P1 periodically (for brief periods), then it would be normal.
Also, here is a link to Danby's FAQ page for Dehumidifiers (which answers some common questions):
https://www.danby.com/faqs.php?cat=12
I hope that helps.
May 11, 2009 | Dehumidifiers
Danby Air conditioner
Check out the co. website, for that unit and codes for troubling shootings! Thank-you-very-much!
Aug 26, 2008 | Danby DAC8003D Air Conditioner
E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Jul 26, 2008 | Danby DAC8003D Air Conditioner
Danby DPAC8020 Air Conditioner Logo
306 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
