Question about Canon ZR100 Mini DV Digital Camcorder
Where is menu on switch
I cannot turn on the menu for this camcorder.
  • ericstone Jul 31, 2008
    Didn't know however that I was being charged $14 for this - thought it was about $10.
    Eric Stone
  • 2,098 Answers
According to the manual, the Menu button is on the rear of the camcorder, just below the battery. Pressing this button activates the menu, and using the dial on the lower left side of the camcorder allows scrolling and selection (press the dial in) of menu items.
Posted on Jul 30, 2008
  • old marine
    old marine Jul 31, 2008
    I wouldn't pay a thing. I'm not getting anything for providing this information.
No image or video that I can see even thru lcd
Common problem with this model , CCD requires replacement.
Feb 10, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
How do you switch tape speeds to LP on a Sony Handy cam TRV 240
You can set tape speed SP or LP in record mode only and can not change it in playback mode.
To set tape speed, turn camcorder in camera mode and go to Menu and set SP or LP in record speed option.
Jan 03, 2010 | Sony Handycam DCR-TRV240 Digital Camcorder
How do I download the contents of a mini disc on to my computer?
first you have to finalize it. to do this you have to plug
the battery charger cable into the camcorder. turn the camcorder on
and pull the switch so that you are in the mode where you can
watch your videos. THEN press the menu button and
you should see a finalize option under disk info.
dont finalize your disc until it is full or you cant record new things on it
Nov 05, 2009 | Canon DC220 DVD Camcorder
Ccdtrv608 sony handycam stuck in nightshot mode
Below image of CCD-TRV608 shows NightShot Button location, turn it Off for normal mode recording.
Mar 24, 2009 | Sony Handycam CCD-TRV68 Camcorder
Want to view my canon mvx330i camcorder through my tv
Open the front plastic cover to the right of the lens and expose the ports. The yellow one is the AV port. Press the MENU button on the left side and use the rocker switch above to display AV-PHONES, select AV, and press the MENU button to set it and close the menu. Turn both  the camcorder and TV OFF.
Connect the camcorder AV port to the TV RGB inputs (VIDEO + AUDIO L + AUDIO R) with the cable that came with the camcorder. It has a mini stereo plug at one end and three RCA plugs at the other.
Switch everything on, press PLAY on the camcorder (don't forget to make sure the cassette is wound back to the start). sit back and enjoy.
Dec 11, 2008 | Canon MVX330i Mini DV Digital Camcorder
Mitsuba mv300l
i live in wshington dc and i need a charger when i can find it?
i have a mitsuba camcorder panasonic
Dec 26, 2007 | Mitsuba DV5 Camcorder
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Playing MPEG's
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
Formatting memory stick.
You can use the MEMORY FORMAT functions to completely delete all images and options on the Memory Card, including protected images. * The format function restores the Memory Card to its initial state. * The Memory Card supplied with this camcorder has been formatted already. Attention If you execute the MEMORY FORMAT function, all images will be erased completely and erased images cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The sub menu will appear. 5. Select FORMAT from the list and press the ENTER button. 6. "ALL FILES ARE DELETED! FORMAT REALLY?" appears on the screen. 7. Using the MENU DIAL, select the item. NO : To return to previous menu YES : To start formatting. 8. Press the ENTER button. If you selected the YES, COMPLETE! appears on the screen when the MEMORY CARD formatting is finished. 9. To exit the menu, push the MENU button.
Video capturing size question
You have two choices for Video size when creating MPEG4's. 320 x 240 or 160 x 120. Use the following instructions to change the size. Digital Still Camera Mode 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to CAMERA mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY. 5. Press the ENTER button to enter the submenu. 6. Turn the MENU DIAL to highlight MPEG4 SIZE. 7. Press the ENTER button. The MPEG4 SIZE toggles between 320 x 240 / 160 x 120 with each push. 8. Press Menu to Save and Exit.
Canon ZR100 Mini DV Digital Camcorder Logo
52 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
