,next time send the brand name and full model number off of the fridge,you can remove the back panel and use a regular house fan to keep the compressor cool until you get the new motor,when it dies did you check to make sure there's still 120 volts going down to it?if this has a computer board in it the board could be bad.when the compressor comes on the fan should also come on they are wired in series,usually the fan either works or it doesn't and you can check it with a meter for ohms,it either reads good or bad,and your ice maker drops ice like every two hours and that's only a few cubes.what is the problem your having?
SOURCE: Ice maker not dropping the ice once it is frozen.
yes there is.if the harvest rake is on top of the ice as though it tring to push the ice out,then could be the heater but its very rare.if the harvest rake is kind of level with the ice maker top[horizontal]then it could be the thermostat in the ice maker or a inner ice maker switch or icemaker moduel.it can be tricky.heres an eazy thing to try.it only cost you time.take icemaker out of frezer and rinse out ice in sink,dry and reinstall.if frezer temps normal[close to 0 degrees]then should make ice in 90 min's or so.i hope thats helpful. God bless ,tom
