Question about Electrolux Dishwashers
Electrolux built in ESL4115 Dishwaser:- Starts the programe briefly but stops with two intermittent audible signals when you open the door the cycle has not really started and there is water at the bottom of the dishwasher(when u refer to manual says the sink spigot is blocked or water drain hose has not been correctly laid or is bent). I have had this for just over 1 year working ok up to this point, tried to see if there is a blockage, taken pipes out doesn't appear to be any blockage also the pipe is not bent and it is all connected to the sink pipe and that is not blocked. any ideas? could it be a circuit board problem?
SOURCE: Neff dishwasher continuously attempting to pump out water
I have just encountered the same problem on my S5433 XO GB/13. Did you manage to get a solution.
Posted on Feb 01, 2007
  • 1462 Answers
SOURCE: have a trouble: dish-washer will not drain.
bear in mind first program action is drain but at this point there should be only a small amount of liquid in machine.check spigot is free by pouring a little water down it. blow thro drain hose to check free as well - you can get a fat blockage in drain hose. if both are free you may have a blockage in exit to pump.the only other maintenaince is to use a dishwasher 2-3 times a year
Posted on Mar 21, 2007
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Posted on May 09, 2008
SOURCE: Dishwasher going through full cycle
fish bone in the impellor
Posted on Aug 27, 2008
SOURCE: when starting wash cycle the dishwasher cda cw447
Try removing the inlet pipe, and refitting, might fix it, else likely that the
Inlet water soleniod failing/failed or tiny mesh filter (it does come out for cleaning) behind the inlet hose clogged. Temporaily bypass the aquastop water stop unit; it might be the culprit!
A replacement solenoid is usually only about £10 from, or ebay sellers (no connection with these but they are very good), fits in minutes (2 or 3 electrical spades ,and a posidrive or two) and usually fixes all water related problems. the noise you can hear is probably the solenoid trying to actuate, will be droning/buzzing sound.
could simply be stuck with some foreign matter in there that's got through the mesh filter but unlikely. they normally fail and sound terrible.
Don't throw your dishwasher away for the sake of a £10 part.
Good luck
Posted on Sep 12, 2009
Electrolux EIFLSI5IIW1 stops at 1 min left in cycle
I have solved same problem with washer Electrolux EWS1066. All cycles stops after starts with 1 min left on display and open inlet water valve. I think that was bad door interlock but it was a defective main controller. No damage visible on board than I heated PCD with heater gun mainly pointed to SMD parts. Now washing machine work good.
Oct 14, 2014 | Washing Machines
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
It starts cycle and stops after a few questions but when i open and close door it starts again and stops...
Hello & Welcome to FixYa
The problem appears to be with the door switch as initially it starts cycle and then the control senses open door so stops the unit completely. Take a hair dryer and blow some air on the door lock/switch assembly, if this won't help then replacing the door switch/lock assembly is recommended repair. Please get back to me if you have any other questions.
Dec 08, 2010 | Candy DFI Plan Built-In Dishwasher
Grit on dishes
Remove the top rotor and start a wash . when running, briefly open door and see if water is pumping out of hole where rotor was connected. If it is, your rotor is badly blocked.(clean properly) If not,a valve that should be opened is not.From there you will need professional attention.
Sep 25, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Bosch dishwaser
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Aug 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool DWF B00 W
Raise temperature of your water supply. Open door and press hi-temp srub,then energy saver, then reapeat this within 3 seconds. Close door and hit cancell.
Jun 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Electrolux Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
