Question about Sharp AL 1631 Copier
Sharp AL1631 I have a blinking red light. It kind of looks like this 8/\/\ My coworker can not find the manual but this copier is new ( less than 12mo) and won't work right. Can you help me?
  • vict_63nino Nov 18, 2008
    My AL1631 Shar keeps blinking showing code H4
  • mitch stein Dec 16, 2008
    I have the exact same problem, it is a jam flashing on the panel, i replaced the fuser already and checked the entire paper path for rouge paper bits. I also can only find one paper sensor right before the fuser, it seems there should be at least one more due to the long amount of space till it would exite the machine.
    Does anyone know if there is a second one and where it is located?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
If it looks like an m or w it means there is a paper jam somewhere, most likely the fuser.
Open right side and look inside the copier, where it gets hot.
do you see a crumpled pice of paper there?
you may have to remove four screws to get the paper out
Posted on Jul 30, 2008
Does the sharp al1631 have a hard drive
There is NO hard drive in the AL1631. I have worked on hundreds of these and can say with certainty there is no hard drive.
Thank You for using Fixya.
Oct 20, 2010 | Sharp AL 1631 Copier
What does the red flashing triangle mean?
If the triangle you are seeing is like a stack of 6 dots then this means your toner cartridge is due to be changed. You are out or nearly out of toner. If you have a local toner cartridge recharging shop they can usually refill these for around $50.00. I do about 10 of these every month.
Good Luck and Thank You for using Fixya.
WheatlandServices
Oct 12, 2010 | Sharp AL 1631 Copier
Replace crum-light does not go out-will not reset sharp al1631 copier
Press # * C *.. the machine will go into diagnostics. then enter 24, then press start, then enter 06 and start. If it isnt 06, then press 07. I would do them both since the developer is just going to pop up with a message soon.
Jul 26, 2010 | Sharp AL 1631 Copier
I need a drum cartridge for the 1631 copier
Sharp AL1631? If your drum light is on you can reset this drum light easily from the control panel. Just search for my tip on the issue by searching for Sharp AL series drum reset.
Mar 19, 2010 | Office Equipment & Supplies
I've lost my manual. Does the red light that
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Nov 19, 2009 | Sharp AL 1631 Copier
Roller Peplacement Al1631
A technician needs to reset that in service mode (code 24-07)
Mar 11, 2009 | Sharp AL 1631 Copier
Sharp 19" LCD blinking red light
Your tv needs servicing, it has developed some kind of circuit malfunction. You can send it too me for fast repairs and return. Or find a shop in your area.
e-mail me...
Feb 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp AL1631
change the toner
Feb 19, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
122 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
